RO3104D-1
RO3104D-1
    RFMI
    SMD-6
    陶瓷谐振器 303.825MHz ±50kHz ±32ppb SMD-6
RO3104D-1 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • • Ideal for 303.825 MHz Transmitters Very Low Series Resistance Quartz Stability Surface Mount Ceramic Case with 21 mm 2 Footprint Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RO3104D-1 RoHS Compliant 303.825 MHz SAW Resonator The RO3104D-1 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 303.825 MHz. This SAW is designed specifically for AM transmitters in wireless security and remote control applications operating in the USA under FCC Part 15, in Australia, in Japan, and in Korea. Absolute Maximum Ratings Rating Value CW RF Power Dissipation (See Typical Test Circuit) DC Voltage Between Terminals (Observe ESD Precautions) Case Temperature 12 VDC °C 260 °C Sym fC Nominal Frequency Temperature Stability Frequency Aging Minimum 303.775 Typical 1.4 9500 Unloaded Q QU 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| Maximum 303.875 Units MHz ±50 kHz 2.0 dB 40 °C 1400 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 16.7  Motional Inductance LM 82.8 µH Motional Capacitance CM 3.3 fF Transducer Static Capacitance CO 3.4 pF LTEST 80.4 nH Test Fixture Shunt Inductance Lid Symbolization Standard Reel Quantity 3.8 X 3.8 IL DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Notes SM3838-6 Case fC Tolerance from 303.825 MHz Insertion Loss Quality Factor dBm -40 to +85 Soldering Temperature (10 seconds / 5 cycles max.) Characteristic Frequency (+25 °C) Units 0 759, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. © 2007 by RFM Integrated Device, Inc. RO3104D-1 (R) 06/11/2021 Page 1 of 3 www.rfmi.co Electrical Connections Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. Power Test Connection 1 NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 50  Source at F C P INCIDENT Low-Loss Matching Network to 50  P REFLECTED 1 6 2 3 5 4 Typical Application Circuits B C 1 A G 6 2 5 3 4 E H Typical Low-Power Transmitter Application 6 1 5 2 4 3 Modulation Input 200k  +9VDC C1 (Antenna) 1 6 D 47 L1 I 2 3 5 4 J C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Case Dimensions Dimension A B C D E G H I J Min 3.60 3.60 1.00 0.95 2.39 0.90 1.90 0.50 1.70 Output 200k  +VDC mm Nom 3.80 3.80 1.20 1.10 2.54 1.0 2.0 0.6 1.8 Max 4.0 4.0 1.40 1.25 2.69 1.10 2.10 0.70 1.90 Min 0.14 0.14 0.04 0.033 0.090 0.035 0.75 0.020 0.067 Inches Nom 0.15 0.15 0.05 0.043 0.10 0.04 0.08 0.024 0.07 C1 +VDC L1 Max 0.16 0.16 0.055 0.05 0.110 0.043 0.83 0.028 0.075 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass Equivalent LC Model 0.05 pF* Typical Test Circuit Co = Cp + 0.05 pF Cp The test circuit inductor, LTEST, is tuned to resonate with the static *Case Parasitics capacitance, CO, at FC. Electrical Test Rm Lm Cm Temperature Characteristics The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. 6 1 5 2 4 3 To 50  Network Analyzer 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) From 50  Network Analyzer fC = f O , T C = T O 0 -200 -80 -60 -40 -20 -200 0 +20 +40 +60 +80 T = T C - T O ( °C ) © 2007 by RFM Integrated Device, Inc. RO3104D-1 (R) 06/11/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. © 2007 by RFM Integrated Device, Inc. RO3104D-1 (R) 06/11/2021 Page 3 of 3 www.rfmi.co
RO3104D-1 价格&库存
很抱歉,暂时无法提供与“RO3104D-1”相匹配的价格&库存,您可以联系我们找货
