RO3300E
RO3300E
    RFMI
    SMD-6
    陶瓷谐振器 ±75kHz 403.55MHz ±32ppb SMD-6
RO3300E 数据手册
• • • • • • • RO3300E Designed for 403.55 MHz MICs Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified RoHS 403.55 MHz SAW Resonator Compliant The RO3300E is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 403.55 MHz. Absolute Maximum Ratings Rating Value Units 0 dBm 12 VDC Input Power Level DC Voltage Storage Temperature Range -40 to +125 °C Operating Temperature Range -40 to +105 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Center Frequency, +25 °C Sym fC Absolute Frequency Notes SM3030-6 Case 3.0 X 3.0 Minimum Typical Tolerance from 403.55 MHz ΔfC IL 1.0 Quality Factor Unloaded Q QU 8117 50 Ω Loaded Q QL Temperature Stability Turnover Temperature TO Insertion Loss Frequency Aging RF Equivalent RLC Model MHz ±75 kHz 2.0 dB 40 °C 25 fO fC FTC 0.032 Absolute Value during the First Year |fA| DC Insulation Resistance between Any Two Terminals Units 403.625 768 10 Frequency Temperature Coefficient Turnover Frequency Maximum 403.475 ≤10 1.0 ppm/°C2 ppm/yr MΩ Motional Resistance RM 10.5 Ω Motional Inductance LM 33.5 µH Motional Capacitance CM 4.6 fF Shunt Static Capacitance CO 4.2 pF 36.9 nH LTEST Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity 719, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2015 by RFM Integrated Device, Inc. RO3300E (R) 12/07/2021 Page 1 of 3 www.rfmi.co Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 719 YWWS A 2 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 G C 1 Temperature Characteristics Connection 1 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 ΔT = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50 Ω Network Analyzer 5 2 4 3 To 50 Ω Network Analyzer K L N K N Power Dissipation Test O N M M 50 Ω Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50 Ω P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k Ω +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k Ω C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm ©2010-2015 by RFM Integrated Device, Inc. RO3300E (R) 12/07/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2015 by RFM Integrated Device, Inc. RO3300E (R) 12/07/2021 Page 3 of 3 www.rfmi.co
RO3300E 价格&库存
很抱歉,暂时无法提供与“RO3300E”相匹配的价格&库存,您可以联系我们找货
