RO3316E
RO3316E
    RFMI
    SMD-6
    陶瓷谐振器 ±75kHz 319.508MHz ±32ppb SMD-6
RO3316E 数据手册
• • • • • • Designed for 319.508 MHz MICs Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 RO3316E RoHS Compliant 319.508 MHz SAW Resonator The RO3316E is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 319.508 MHz. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation (See: Typical Test Circuit) +0 dBm DC Voltage Between Terminals (Observe ESD precautions) ±30 VDC -40 to +85 °C 260 °C Case Temperature Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Sym Center Frequency, +25 °C fC Tolerance from 319.508 MHz Insertion Loss Quality Factor Temperature Stability Frequency Aging Minimum Typical Maximum Units 319.433 319.508 319.583 MHz ±75 kHz 2.0 dB 35 °C fC IL 1.6 50 Loaded Q QL 3400 Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 10 DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Notes SM3030-6 Case 3.0 X 3.0 15 25 ppm/°C2 ppm/yr 1.0 M Motional Resistance RM 20.2 Motional Inductance LM 216.33 µH Motional Capacitance CM 1.147 fF Shunt Static Capacitance CO Lid Symbolization (Y = Year, WW = Week, S = Shift)) 1.85 25.9 2.05  pF 8B, YWWS CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. Copyright © 2016 by RFM Integrated Device, Inc. RO3316E (R) 09/21/2021 Page 1 of 3 www.rfmi.co Temperature Characteristics Electrical Connections B Pin 1 2 3 4 5 6 NC Terminal NC NC Terminal NC C 8B YWWS A 2 5 E F 4 3 0 -50 -50 -100 -100 -150 -150 -200 -80 -60 -40 -20 H 6 1 5 2 4 3 D fC = f O , T C = T O 0 G 6 1 The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. Connection (f-fo ) / fo (ppm) The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. -200 0 +20 +40 +60 +80 T = T C - T O ( °C ) I Characterization Test Circuit Admittance Capable Network Analyzer J K L N K Power Dissipation Test N O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 *Case Parasitics ROXXXXC Bottom View 2 3 5 4 C2 RF Bypass Cm Copyright © 2016 by RFM Integrated Device, Inc. RO3316E (R) 09/21/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. Copyright © 2016 by RFM Integrated Device, Inc. RO3316E (R) 09/21/2021 Page 3 of 3 www.rfmi.co
RO3316E 价格&库存
很抱歉,暂时无法提供与“RO3316E”相匹配的价格&库存,您可以联系我们找货
