RO3118A-1
RO3118A-1
    RFMI
    SMD-4
    陶瓷谐振器 318MHz ±50kHz ±32ppb SMD-4
RO3118A-1 数据手册
• • • • • • Designed for 318.0 MHz Transmitters Very Low Series Resistance Quartz Stability Surface-mount Ceramic Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RO3118A-1 RoHS Compliant 318.0 MHz SAW Resonator The RO3118A-1 is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 318.0 MHz. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation (See: Typical Test Circuit) +0 dBm DC Voltage Between Terminals (Observe ESD Precautions) ±30 VDC -40 to +85 °C 260 °C Case Temperature Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Sym Center Frequency, +25 °C fC Absolute Frequency Insertion Loss Temperature Stability Frequency Aging Typical 317.950 IL 1.5 Unloaded Q QU 12000 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum fC Tolerance from 318.0 MHz Quality Factor Notes SM5035-4 Maximum Units 318.050 MHz ±50 kHz 2.0 dB 40 °C 2000 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 19.8  Motional Inductance LM 118 µH Motional Capacitance CM 2.1 fF Shunt Static Capacitance CO 2.9 pF 79 nH Test Fixture Shunt Inductance LTEST Lid Symbolization (YY= Year, WW = Week, S = Shift) 763, YYWWS CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3118A-1 (R) 09/21/2021 Page 1 of 3 www.rfmi.co Electrical Connections Equivalent RLC Model The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. C Terminal Case Ground Case Ground P L Terminal C C C S C M C R M = 0 .0 5 p F (C a s P a r a s t c s ) = S A W S ta t c C a p a c ta n c = C S + C P P S M Temperature Characteristics The test circuit inductor, LTEST, is tuned to resonate with the static capacitance, CO, at FC. ELECTRICAL TEST fC = f O , T C = T O -50 -50 -100 -100 -150 -150 -200 -80 -60 -40 -20 Case -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) To 50  Network Analyzer From 50  Network Analyzer 0 0 (f-fo ) / fo (ppm) Typical Test Circuit The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. T o p V ie w S id e V ie w B C B o tto m V ie w E ) ) 1 A POWER TEST P INCIDENT 50  Source P at F C REFLECTED CW RF Power Dissipation = Low-Loss Matching Network to 50  2 Terminal G 1 ) NC NC D Terminal P INCIDENT - P REFLECTED I Typical Application Circuits I Typical Low-Power Transmitter Application H H +9VDC Modulation Input J H 200k  C1 47 K L1 (Antenna) L C2 RF Bypass RO3XXXA Bottom View 470 Dimensions A Typical Local Oscillator Applications Output +VDC C1 +VDC L1 Millimeters Inches Min Nom Max Min Nom Max 4.87 5.00 5.13 0.191 0.196 0.201 B 3.37 3.50 3.63 0.132 0.137 0.142 C 1.45 1.53 1.60 0.057 0.060 0.062 D 1.35 1.43 1.50 0.040 0.057 0.059 E 0.67 0.80 0.93 0.026 0.031 0.036 F 0.37 0.50 0.63 0.014 0.019 0.024 G 1.07 1.20 1.33 0.042 0.047 0.052 C2 RO3XXXA Bottom View ©2010-2014 by RFM Integrated Device, Inc. RO3118A-1 (R) 09/21/2021 RF Bypass Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3118A-1 (R) 09/21/2021 Page 3 of 3 www.rfmi.co
RO3118A-1
物料型号是RO3118A-1,它是一款单端口表面声波(SAW)谐振器,封装在表面贴装陶瓷外壳中。
器件简介表明,RO3118A-1用于318.0 MHz发射器,具有非常低的串联电阻、石英稳定性、符合欧盟RoHS指令。
引脚分配是双向的,两个端子是可互换的,没有编号。
参数特性包括中心频率为318.0 MHz,频率容差为±50 kHz,插入损耗为1.5至2.0 dB,质量因数从12000到2000不等。
功能详解显示,RO3118A-1提供可靠的基础模式石英频率稳定。
应用信息包括典型的低功耗发射器应用和本振应用电路。
封装信息为SM5035-4,电气测试和功率测试电路图也提供。
还包含了温度特性曲线和PCB足迹尺寸。
最后,还提供了推荐的回流焊接曲线。
RO3118A-1 价格&库存
很抱歉,暂时无法提供与“RO3118A-1”相匹配的价格&库存,您可以联系我们找货
