RO3104C-1
RO3104C-1
    RFMI
    SMD-8
    陶瓷谐振器 303.825MHz ±50kHz ±32ppb SMD-8
RO3104C-1 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • RO3104C-1 Ideal for 303.825 MHz Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS 303.825 MHz SAW Resonator Compliant The RO3104C-1 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount, ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of local oscillators operating at approximately 303.825 MHz. This SAW was designed for AM transmitters in automotive-keyless-entry applications operating in the USA under FCC Part 15, in Canada under DoC RSS-210, and in Italy. Absolute Maximum Ratings SM5050-8 Case Rating Value Input Power Level DC Voltage Storage Temperature Absolute Frequency Temperature Stability Frequency Aging dBm 12 VDC °C 260 °C Sym fC Notes IL 1.3 Unloaded Q QU 9800 50W Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| Motional Resistance Maximum 303.875 Units MHz ±50 kHz 2.0 dB 40 °C 1300 10 25 10 1.0 ppm/°C2 ppm/yr M RM 15.6  µH Motional Inductance LM 79.7 Motional Capacitance CM 3.4 fF Shunt Static Capacitance CO 3.3 pF LTEST 83.9 nH Test Fixture Shunt Inductance 757, YWWS Lid Symbolization Standard Reel Quantity Typical fC DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum 303.775 Tolerance from 303.825 MHz Insertion Loss Quality Factor 0 -40 to +85 Soldering Temperature (10 seconds / 5 cycles max.) Characteristic Frequency (+25 °C) 5X5 Units Reel Size 7 Inch 500 Pieces / Reel Reel Size 13 Inch 3000 Pieces / Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. Copyright © 2007 by RFM Integrated Device, Inc. RO3104C-1 (R) 06/11/2021 Page 1 of 3 www.rfmi.co Electrical Connections Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B 8 A 2 3 1 NC 2 Terminal 3 NC 4 NC NC 50  Source at F C 5 NC 6 Terminal 7 NC 8 NC Low-Loss Matching Network to 50  NC 1 2 3 8 NC 7 NC 4 6 5 NC NC Typical Application Circuits Typical Low-Power Transmitter Application 8 D 7 7 P INCIDENT P REFLECTED E C 757 YWWS 1 Power Test Connection Modulation Input 1 200k  +9VDC C1 47 L1 (Antenna) 6 2 6 5 G 1 3 5 7 4 4 2 8 3 4 6 5 C2 ROXXXXC Bottom View F RF Bypass 470 Typical Local Oscillator Application Case Dimensions Dimension A B C D E F G Output 200k  Min 4.8 4.8 mm Nom 5.0 5.0 2.39 2.08 1.17 0.64 2.54 Max 5.2 5.2 1.7 2.69 Min 0.189 0.189 Inches Nom 0.197 0.197 0.094 0.082 0.046 0.025 0.100 +VDC C1 1 2 3 8 7 4 6 5 C2 ROXXXXC Bottom View 0.106 +VDC L1 Max 0.205 0.205 0.067 RF Bypass Equivalent LC Model Typical Test Circuit 0.05 pF* The test circuit inductor, LTEST, is tuned to resonate with the static Co = Cp + 0.05 pF Cp capacitance, CO, at FC. *Case Parasitics Electrical Test Rm Lm Cm Temperature Characteristics 7 From 50  Network Analyzer 6 8 4 2 To 50  Network Analyzer fC = f O , T C = T O 0 0 3 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) 5 The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. 1 -200 -80 -60 -40 -20 -200 0 +20 +40 +60 +80 T = T C - T O ( °C ) Copyright © 2007 by RFM Integrated Device, Inc. RO3104C-1 (R) 06/11/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. Copyright © 2007 by RFM Integrated Device, Inc. RO3104C-1 (R) 06/11/2021 Page 3 of 3 www.rfmi.co
RO3104C-1 价格&库存
很抱歉,暂时无法提供与“RO3104C-1”相匹配的价格&库存,您可以联系我们找货
