RO3164A
RO3164A
    RFMI
    SMD-4
    陶瓷谐振器 868.35MHz ±200kHz ±32ppb SMD-4
RO3164A 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • • RO3164A Designed for European 868.35 MHz SRD Transmitters Very Low Series Resistance Quartz Stability Surface-mount Ceramic Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 868.35 MHz SAW Resonator The RO3164A is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 868.35 MHz. The RO3164A is designed specifically for remote control and wireless security SRD transmitters operating under ETSI EN 300 220-2. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation +5 dBm DC Voltage Between Terminals ±30 VDC -40 to +85 °C 260 °C Case Temperature Soldering Temperature, 10 seconds / 5 cycles maximum SM5035-4 Electrical Characteristics Characteristic Sym Frequency, +25 °C fC Tolerance from 868.35 MHz 868.150 Typical IL QU Unloaded Q QL 50 Loaded Q Temperature Stability Minimum fC Insertion Loss Quality Factor Notes TO Turnover Temperature Turnover Frequency FTC Frequency Aging Absolute Value during the First Year DC Insulation Resistance between Any Two Terminals |fA| RF Equivalent RLC Model RM Motional Resistance Motional Capacitance Shunt Static Capacitance Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) 868.550 Units MHz ±200 kHz 2.0 dB 40 °C 6600 800 10 fO Frequency Temperature Coefficient Motional Inductance 1.3 Maximum 25 fC kHz
RO3164A 价格&库存
很抱歉,暂时无法提供与“RO3164A”相匹配的价格&库存,您可以联系我们找货
