RO3101E-1
RO3101E-1
    RFMI
    SMD-6
    陶瓷谐振器 433.92MHz ±50kHz ±32ppb SMD-6
RO3101E-1 数据手册
RO3101E-1 • • • • • • • Designed for European 433.92 MHz Remote Control and Security Transmitters Very Low Series Resistance Quartz Stability RoHS Complies with Directive 2002/95/EC (RoHS) Compliant Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified 433.92 MHz SAW Resonator The RO3101E-1 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 433.92 MHz. This SAW is designed specifically for remote control and wireless security transmitters operating in Europe under ETSI I-ETS 300 220 regulations. Absolute Maximum Ratings Rating Value Input Power Level 0 dBm DC voltage 12 VDC Storage Temperature Range -40 to +125 °C Operating Temperature Range -40 to +105 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Center Frequency, +25 °C Sym Absolute Frequency Tolerance from 433.920 MHz Insertion Loss Quality Factor Temperature Stability Frequency Aging Unloaded Q fC Notes Minimum Typical Maximum Units 433.970 MHz ±50 kHz 2.2 dB 35 °C 433.870 fC IL 1.4 QU 8280 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model SM3030-6 Case 3.0 X 3.0 Units 1228 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 17.5  Motional Inductance LM 53.5 µH Motional Capacitance CM 2.5 fF Shunt Static Capacitance CO 2.5 pF 53.2 nH LTEST Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity 750, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3101E-1 (R) 12/07/2021 Page 1 of 3 www.rfmi.co Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 750 YWWS A 2 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. fC = f O , T C = T O 0 G C 1 Temperature Characteristics Connection 1 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) Electrical Connections -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K N Power Dissipation Test O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm ©2010-2014 by RFM Integrated Device, Inc. RO3101E-1 (R) 12/07/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3101E-1 (R) 12/07/2021 Page 3 of 3 www.rfmi.co
RO3101E-1
物料型号为RO3101E-1,是一款设计用于欧洲433.92 MHz远程控制和安全发射器的表面声波(SAW)谐振器。
以下是该物料的详细信息:
器件简介: - 该SAW谐振器提供固定频率发射器的可靠、基模、石英频率稳定。
- 专为在欧洲ETSI I-ETS 300 220规范下运行的远程控制和无线安全发射器设计。
引脚分配: - 该SAW谐振器是双向的,可以以任何方向安装。
- 两个端子是可互换的,未编号。
- 端子1、3、4、6为NC(无内部连接),端子2和5为终端。
参数特性: - 工作频率:433.92 MHz - 插入损耗:1.4 dB(最小值)至2.2 dB(典型值) - 品质因数:空载Q值8280,50欧姆负载Q值1228 - 温度稳定性:转换温度10°C至35°C - 频率温度系数:0.032 ppm/°C² - 频率老化:第一年内绝对值≤10 ppm/yr - DC绝缘电阻:≥1.0 MOhm
功能详解: - 该谐振器符合2002/95/EC指令(RoHS)。
- 封装符合ANSI/EIA-481标准。
- 湿度敏感度等级为1。
- 符合AEC-Q200标准。
应用信息: - 典型应用电路包括低功耗发射器应用和本地振荡器应用。
- 推荐回流焊温度曲线:预热150~180ºC,持续60~90秒;升温至150ºC时间至少30秒;加热220ºC,持续50~80秒,峰值260ºC(10秒)。
封装信息: - 封装尺寸:SM3030-6 Case 3.0 X 3.0 - 标准卷带数量:7英寸卷带500件/卷,13英寸卷带3000件/卷。
注意:该设备对静电敏感,处理时需注意防静电措施。
RO3101E-1 价格&库存
很抱歉,暂时无法提供与“RO3101E-1”相匹配的价格&库存,您可以联系我们找货
