RO3073A-16
RO3073A-16
    RFMI
    SMD-4
    陶瓷谐振器 ±32ppb 315.05MHz SMD-4
RO3073A-16 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. RO3073A-16 • • • • • • Designed for 315.050 MHz Transmitters Very Low Series Resistance Quartz Stability Surface-mount Ceramic Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 315.050 MHz SAW Resonator The RO3073A-16 is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 315.050 MHz. This SAW is designed specifically for remote control and wireless security transmitters. Absolute Maximum Ratings Rating Value CW RF Power Dissipation (See: Typical Test Circuit) +0 dBm DC Voltage Between Terminals (Observe ESD Precautions) ±30 VDC -40 to +85 °C 260 °C Case Temperature Soldering Temperature (10 seconds / 5 cycles maximum) SM5035-4 Units Electrical Characteristics Characteristic Center Frequency, +25 °C Sym Absolute Frequency Tolerance from 315.050 MHz Insertion Loss Quality Factor Temperature Stability Frequency Aging Maximum Units fC Notes 314.950 315.130 MHz fC -100 +80 Typical kHz 2.2 dB 40 °C IL 1.5 Unloaded Q QU 8000 50 Loaded Q QL 1300 Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum 10 25 10 1.0 ppm/°C2 ppm/yr M Motional Resistance RM 19.4  Motional Inductance LM 78.4 µH Motional Capacitance CM 3.3 fF Shunt Static Capacitance CO 4.1 pF LTEST 64.2 nH Test Fixture Shunt Inductance Lid Symbolization (YY = year, WW = week, S = shift) 783, YYWWS CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3073A-16 (R) 06/10/2021 Page 1 of 3 www.rfmi.co Electrical Connections Equivalent RLC Model The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. Case Ground Case Ground C M The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. R M M fC = f O , T C = T O 0 -50 -50 -100 -100 -150 -150 -200 -80 -60 -40 -20 -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) To 50  Network Analyzer T o p V ie w S id e V ie w B C B o tto m V ie w E ) ) 1 A POWER TEST Low-Loss Matching Network to 50  2 Terminal G 1 ) NC NC D Terminal P INCIDENT - P REFLECTED I Typical Application Circuits I H Typical Low-Power Transmitter Application H J H +9VDC Modulation Input = 0 .0 5 p F (C a s P a r a s t c s ) = S A W S ta t c C a p a c ta n c = C S + C P P S 0 Case From 50  Network Analyzer CW RF Power Dissipation = S (f-fo ) / fo (ppm) ELECTRICAL TEST 50  Source P at F C REFLECTED L C C C Temperature Characteristics The test circuit inductor, LTEST, is tuned to resonate with the static capacitance, CO, at FC. INCIDENT P C Terminal Typical Test Circuit P C Terminal 200k  K C1 47 L1 (Antenna) L C2 RF Bypass RO3XXXA Bottom View 470 Typical Local Oscillator Applications Output +VDC Dimensions C1 +VDC A L1 ©2010-2014 by RFM Integrated Device, Inc. RO3073A-16 (R) 06/10/2021 Inches Nom Max Min Nom Max 4.87 5.00 5.13 0.191 0.196 0.201 B 3.37 3.50 3.63 0.132 0.137 0.142 C 1.45 1.53 1.60 0.057 0.060 0.062 D 1.35 1.43 1.50 0.040 0.057 0.059 E 0.67 0.80 0.93 0.026 0.031 0.036 F 0.37 0.50 0.63 0.014 0.019 0.024 G 1.07 1.20 1.33 0.042 0.047 0.052 C2 RO3XXXA Bottom View Millimeters Min RF Bypass Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3073A-16 (R) 06/10/2021 Page 3 of 3 www.rfmi.co
RO3073A-16 价格&库存
很抱歉,暂时无法提供与“RO3073A-16”相匹配的价格&库存,您可以联系我们找货
