RO3164E-2
RO3164E-2
    RFMI
    SMD-6
    陶瓷谐振器 ±100kHz 868.35MHz ±32ppb SMD-6
RO3164E-2 数据手册
RO3164E-1 • • • • • • • Ideal for European 868.35 MHz Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified RoHS Compliant 868.35 MHz SAW Resonator The RO3164E-1 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 868.35 MHz. This SAW is designed specifically for remote-control and wireless security transmitters operating under ETSI-ETS 300 220 in Europe and under FTZ 17 TR 2100 in Germany. Absolute Maximum Ratings Rating Value Units 0 dBm 12 VDC Input Power Level DC Voltage Storage Temperature -40 to +125 °C Operating Temperature Range -40 to +125 °C +260 °C Soldering Temperature SM3030-6 Case 3.0 X 3.0 Electrical Characteristics Characteristic Frequency (+25 °C) Sym Nominal Frequency Notes Minimum Typical 868.200 Maximum 868.500 fC MHz Tolerance from 868.35 MHz ±150 ΔfC Insertion Loss Quality Factor Unloaded Q 50 Ω Loaded Q Temperature Stability Turnover Temperature Turnover Frequency Frequency Temperature Coefficient Frequency Aging Absolute Value during the First Year DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Motional Resistance Motional Inductance Motional Capacitance Shunt Static Capacitance Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity Reel Size 7 Inch Reel Size 13 Inch ©2010-2015 by RFM Integrated Device, Inc. RO3164E-1 (R) 12/07/2021 Units IL QU QL TO fO kHz 10 FTC |fA| 1.3 7200 975 25 fC 2.0 dB 40 °C kHz 0.032
RO3164E-2 价格&库存
很抱歉,暂时无法提供与“RO3164E-2”相匹配的价格&库存,您可以联系我们找货
