RO3164C
RO3164C
    RFMI
    SMD-8
    陶瓷谐振器 868.35MHz ±200kHz ±32ppb SMD-8
RO3164C 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • Ideal for European 868.35 MHz Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RO3164C RoHS Compliant 868.35 MHz SAW Resonator The RO3164C is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 868.35 MHz. Absolute Maximum Ratings Rating Value Units Input Power Level 10 dBm DC Voltage 12 VDC Storage Temperature -40 to +85 °C Operating Temperature -40 to +85 °C SM5050-8 Case 5X5 Electrical Characteristics Characteristic Frequency (+25 °C) Nominal Frequency RO3164C Tolerance from 868.35 MHz RO3164C Insertion Loss Quality Factor Unloaded Q 50 Loaded Q Temperature Stability Turnover Temperature Turnover Frequency Frequency Temperature Coefficient Frequency Aging Absolute Value during the First Year DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Motional Resistance Motional Inductance Motional Capacitance Shunt Static Capacitance Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Sym fC fC Notes Minimum 868.150 IL QU QL TO fO Typical 1.1 7000 671 25 fC 10 FTC |fA| 0.032
RO3164C 价格&库存
很抱歉,暂时无法提供与“RO3164C”相匹配的价格&库存,您可以联系我们找货
