RO3164A-1
RO3164A-1
    RFMI
    SMD-4
    陶瓷谐振器 868.35MHz ±150kHz ±32ppb SMD-4
RO3164A-1 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. RO3164A-1 • • • • • • Designed for European 868.35 MHz SRD Transmitters Very Low Series Resistance Quartz Stability Surface-mount Ceramic Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 868.35 MHz SAW Resonator The RO3164A -1 is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 868.35 MHz. The RO3164A is designed specifically for remote control and wireless security SRD transmitters operating under ETSI EN 300 220-2. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation +5 dBm DC Voltage Between Terminals ±30 VDC -40 to +85 °C 260 °C Case Temperature Soldering Temperature, 10 seconds / 5 cycles maximum SM5035-4 Electrical Characteristics Characteristic Sym Frequency, +25 °C fC Tolerance from 868.35 MHz Typical 868.200 IL QU Unloaded Q QL 50 Loaded Q Temperature Stability Minimum fC Insertion Loss Quality Factor Notes TO Turnover Temperature Frequency Temperature Coefficient FTC Frequency Aging Absolute Value during the First Year DC Insulation Resistance between Any Two Terminals |fA| RF Equivalent RLC Model RM Motional Resistance Motional Capacitance Shunt Static Capacitance Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Units MHz ±150 kHz 2.0 dB 40 °C 6600 800 10 fO Turnover Frequency Motional Inductance 1.3 868.500 25 fC kHz
RO3164A-1
PDF文档中包含了以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有两个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V至1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817主要功能是发射红外光,用于无线通信。
6. 应用信息:广泛应用于遥控器、红外通信等领域。
7. 封装信息:EL817采用黑色塑料封装,尺寸为3.4mm x 1.6mm。
RO3164A-1 价格&库存
很抱歉,暂时无法提供与“RO3164A-1”相匹配的价格&库存,您可以联系我们找货
