RO3144E-2
RO3144E-2
    RFMI
    SMD-6
    陶瓷谐振器 916.5MHz ±100kHz ±32ppb SMD-6
RO3144E-2 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • Ideal for 916.5 MHz Remote Control and Data Telemetry Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RO3144E-2 RoHS 916.5 MHz SAW Resonator Compliant The RO3144E-2 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode stabilization of fixed-frequency transmitters operating at 916.5 MHz. This SAW is designed specifically for remote control and data telemetry transmitters operating in the USA under FCC Part 15 regulations and in Canada under DoC RSS-210. Absolute Maximum Ratings Rating Value Units 0 dBm Input Power Level DC Voltage 12 VDC Storage Temperature -40 to +125 °C Operating Temperature Range -40 to +125 °C 260 °C Soldering Temperature Electrical Characteristics Characteristic Sym Notes Minimum SM3030-6 Case 3.0 X 3.0 Typical Maximum 916.400 Frequency, +25 °C Units 916.600 fC MHz Tolerance from 916.5 MHz ±100 fC Insertion Loss Quality Factor Temperature Stability Frequency Aging kHz IL 1.2 QU 6400 50 Loaded Q QL 780 Turnover Temperature TO Turnover Frequency fO fc MHz Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| ppm/°C2 ppm Unloaded Q 15 dB 40 °C 1.0 M Motional Resistance RM 14  Motional Inductance LM 15.4 µH Motional Capacitance CM 1.9 fF Transducer Static Capacitance CO 1.9 pF 16 nH LTEST Test Fixture Shunt Inductance 770, YWWS Lid Symbolization Standard Reel Quantity 25 10 DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model 1.6 Reel Size 7 Inch 500 Pieces / Reel Reel Size 13 Inch 3000 Pieces / Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2015 by RFM Integrated Device, Inc. RO3144E-2 (R) 06/11/2021 Page 1 of 3 www.rfmi.co Temperature Characteristics Electrical Connections B Pin 1 NC 2 Terminal 3 NC 4 NC 5 Terminal 6 NC 6 770 YWWS A 2 fC = f O , T C = T O 0 G C 1 5 E F The curve shown accounts for resonator contribution only and does not include external LC component temperature effects. Connection 0 -50 -50 -100 -100 -150 -150 (f-fo ) / fo (ppm) The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. -200 -80 -60 -40 -20 H 6 1 5 2 4 3 -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) I Characterization Test Circuit Inductor LTEST is tuned to resonate with the static capacitance, CO, at FC. 3 4 D J 6 1 From 50  Network Analyzer 5 2 4 3 To 50  Network Analyzer K L N K N Power Dissipation Test O N M M 50  Source at F C Case and Typical PCB Land Dimensions Ref A B C D E F G H I J K L M N O Min 2.87 2.87 1.12 0.77 2.67 1.47 0.72 1.37 0.47 1.17 mm Nom 3.00 3.00 1.25 0.90 2.80 1.60 0.85 1.50 0.60 1.30 3.20 1.70 1.05 0.81 0.38 Max 3.13 3.13 1.38 1.03 2.93 1.73 0.98 1.63 0.73 1.43 Min 0.113 0.113 0.044 0.030 0.105 0.058 0.028 0.054 0.019 0.046 P INCIDENT Low-Loss Matching Network to 50  P REFLECTED Inches Nom 0.118 0.118 0.049 0.035 0.110 0.063 0.033 0.059 0.024 0.051 0.126 0.067 0.041 0.032 0.015 Max 0.123 0.123 0.054 0.040 0.115 0.068 0.038 0.064 0.029 0.056 1 6 5 4 Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  C1 Equivalent RLC Model +VDC L1 0.05 pF* Cp Lm 3 Example Application Circuits +VDC Rm 2 1 Co = Cp + 0.05 pF 6 2 3 5 4 C2 *Case Parasitics ROXXXXC Bottom View RF Bypass Cm ©2010-2015 by RFM Integrated Device, Inc. RO3144E-2 (R) 06/11/2021 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2015 by RFM Integrated Device, Inc. RO3144E-2 (R) 06/11/2021 Page 3 of 3 www.rfmi.co
RO3144E-2 价格&库存
很抱歉,暂时无法提供与“RO3144E-2”相匹配的价格&库存,您可以联系我们找货
