RO3164E-3
RO3164E-3
    RFMI
    SMD-6
    陶瓷谐振器 ±75kHz 868.35MHz ±32ppb SMD-6
RO3164E-3 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. RO3164E-3 • • • • • Designed for European 868.35 MHz Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 868.35 MHz SAW Resonator The RO3164E-3 is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 868.35 MHz. This SAW is designed specifically for remote-control and wireless security transmitters operating under ETSI EN 300 220-2. Absolute Maximum Ratings Rating Value Units Input Power Level 0 dBm DC Voltage 12 VDC Storage Temperature -40 to +125 °C Operating Temperature Range -40 to +125 °C +260 °C Soldering Temperature SM3030-6 Case 3.0 X 3.0 Electrical Characteristics Characteristic Sym Nominal Frequency, +25 °C fC Tolerance from 868.35 MHz ΔfC Insertion Loss Quality Factor Temperature Stability Frequency Aging Minimum Typical 868.275 Maximum Units 868.425 MHz ±75 kHz 2.0 dB IL 1.3 Unloaded Q QU 27000 50 Ω Loaded Q QL 4000 Turnover Temperature TO Turnover Frequency fO fC kHz Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| ppm/°C2 ppm/yr DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Notes 10 25 40
RO3164E-3 价格&库存
很抱歉,暂时无法提供与“RO3164E-3”相匹配的价格&库存,您可以联系我们找货
