RO3156E-3
RO3156E-3
    RFMI
    SMD-6
    陶瓷谐振器 868.95MHz ±32ppb SMD-6 ±70KHz
RO3156E-3 数据手册
AEC-Q200 This component was always RoHS compliant from the first date of manufacture. • • • • • RO3156E-3 Designed for European 868.95 MHz Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 RoHS Compliant 868.95 MHz SAW Resonator The RO3156E-3 is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 868.95 MHz.This SAW is designed specifically for remote-control and wireless security transmitters operating under ETSI EN 300 220. Absolute Maximum Ratings Rating Value Units Input Power Level 0 dBm DC Voltage 12 VDC -40 to +85 °C +260 °C Operating Temperature Range Soldering Temperature, 10 seconds / 5 cycles maximum SM3030-6 Case Electrical Characteristics Characteristic Frequency, +25 °C Tolerance from 868.95 MHz Insertion Loss Quality Factor Unloaded Q 50 Loaded Q Temperature Stability Turnover Temperature Turnover Frequency Frequency Temperature Coefficient Frequency Aging Absolute Value during the First Year DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Motional Resistance Motional Inductance Motional Capacitance Shunt Static Capacitance Test Fixture Shunt Inductance Lid Symbolization Standard Reel Quantity Reel Size 7 Inch Reel Size 13 Inch Sym fC fC IL QU QL TO fO Notes Minimum 868.880 10 FTC |fA| RM LM CM CO Typical 1.2 6700 800 25 fC Maximum 869.020 ±70 2.0 Units MHz kHz dB 40 °C kHz 0.032
RO3156E-3 价格&库存
很抱歉,暂时无法提供与“RO3156E-3”相匹配的价格&库存,您可以联系我们找货
