RO3101D
RO3101D
    RFMI
    SMD-6
    陶瓷谐振器 433.92MHz ±75kHz ±32ppb SMD-6
RO3101D 数据手册
RO3101D • • • • • • • Ideal for European 433.92 MHz Remote Control and Security Transmitters Very Low Series Resistance Quartz Stability Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA-481 Moisture Sensitivity Level: 1 AEC-Q200 Qualified RoHS 433.92 MHz SAW Resonator Compliant The RO3101D is a true one-port, surface-acoustic-wave (SAW) resonator in a surface-mount ceramic case. It provides reliable, fundamental-mode, quartz frequency stabilization of fixed-frequency transmitters operating at 433.92 MHz. This SAW is designed specifically for remote control and wireless security transmitters operating in Europe under ETSI I-ETS 300 220. Absolute Maximum Ratings Rating Value Units 0 dBm 12 VDC Input Power Level DC Voltage Storage Temperature Soldering Temperature (10 seconds / 5 cycles maximum) -40 to +85 °C 260 °C SM3838-6 Case 3.8 X 3.8 Electrical Characteristics Characteristic Center Frequency, +25 °C Sym fC Absolute Frequency Temperature Stability Frequency Aging Minimum fC IL 1.3 Unloaded Q QU 8900 Maximum Units 433.995 MHz ±75 kHz 2.5 dB 40 °C 50 Loaded Q QL Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 ppm/ Absolute Value during the First Year |fA| 10 ppm/yr DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Typical 433.845 Tolerance from 433.920 MHz Insertion Loss Quality Factor Notes 1250 10 25 1.0 M Motional Resistance RM 16.4  Motional Inductance LM 53.1 µH Motional Capacitance CM 2.5 fF Shunt Static Capacitance CO 2.4 pF LTEST 56.7 nH Test Fixture Shunt Inductance Lid Symbolization (in addition to Lot and/or Date Codes) Standard Reel Quantity 702, YWWS Reel Size 7 Inch 500 Pieces/Reel Reel Size 13 Inch 3000 Pieces/Reel CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3101D (R) 12/07/2021 Page 1 of 3 www.rfmi.co Electrical Connections Pin The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. B NC 2 Terminal 3 NC 4 NC 5 NC 6 Terminal 7 NC 8 NC 6 1 From 50  Network Analyzer G C Parameter Test Circuit Connection 1 5 2 4 3 To 50  Network Analyzer Power Test Circuit H 6 1 702 YWWS A 2 6 5 E 1 5 2 4 3 50  Source at F C I P INCIDENT Low-Loss Matching Network to 50  P REFLECTED 1 6 2 3 5 4 4 3 D J Example Application Circuits Typical Low-Power Transmitter Application Modulation Input 200k  +9VDC C1 47 L1 (Antenna) 1 6 2 3 5 4 C2 ROXXXXC Bottom View RF Bypass 470 Typical Local Oscillator Application Output 200k  +VDC C1 +VDC L1 Case Dimensions A B C D E G H I J mm Nom 3.80 3.80 1.30 1.10 2.54 1.00 2.00 0.60 1.80 Min 3.60 3.60 1.10 0.95 2.39 0.90 1.90 0.50 1.70 Max 4.00 4.00 1.50 1.25 2.69 1.10 2.10 0.70 1.90 Min 0.142 0.142 0.043 0.037 0.094 0.035 0.748 0.020 0.067 Inches Nom 0.150 0.150 0.050 0.043 0.100 0.040 0.079 0.024 0.071 6 Max 0.157 0.157 0.060 0.049 0.106 0.043 0.083 0.028 0.075 Lm 4 RF Bypass The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. Co = Cp + 0.05 pF fC = f O , T C = T O 0 0 -50 -50 -100 -100 -150 -150 -200 -80 -60 -40 -20 *Case Parasitics -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) Cm ©2010-2014 by RFM Integrated Device, Inc. RO3101D (R) 12/07/2021 5 Temperature Characteristics 0.05 pF* Rm 3 C2 Equivalent RLC Model Cp 2 ROXXXXC Bottom View (f-fo ) / fo (ppm) Dimension 1 Page 2 of 3 www.rfmi.co Recommended Reflow Profile 1. Preheating shall be fixed at 150~180ºC for 60~90 seconds. 2. Ascending time to preheating temperature 150ºC shall be 30 seconds min. 3. Heating shall be fixed at 220ºC for 50~80 seconds and at 260ºC +0/-5ºC peak (10 seconds). 4. Time: 5 times maximum. ©2010-2014 by RFM Integrated Device, Inc. RO3101D (R) 12/07/2021 Page 3 of 3 www.rfmi.co
RO3101D
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入输出隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出晶体管的集电极,4脚输出晶体管的发射极,5脚输出晶体管的基极,6脚为连接到地的引脚。
4. 参数特性:EL817的主要参数包括输入电流为10mA,输出晶体管的集电极-发射极电压为20V,集电极-基极电压为-5V,输出晶体管的低电平输出电流为5mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端为发光二极管,输出端为晶体管,具有隔离电压高、响应速度快等特点。
6. 应用信息:EL817广泛应用于数字电路、通信设备、仪器仪表等领域,用于实现信号隔离、电平转换等功能。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
RO3101D 价格&库存
很抱歉,暂时无法提供与“RO3101D”相匹配的价格&库存,您可以联系我们找货
