PART CODE:
CD4M000000S001
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0429-CD4M000000S001
DATE
April 29, 2021
REVISION
A1
DESCRIPITION
Thru-Hole Ceramic Resonator, L9.5*T4.0*H6.0mm, 3 Pins, Lead: 13.5mm
4.00000MHz, Built-in Capacitance, CRTWS Series
Frequency Accuracy ±0.5%, Operating Temp. Range -40°C ~+85°C
RoHS/RoHS III compliant
Packed in AMNO-Pack, 2000pcs/Tape, 1 Tape/Box
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
TGS CRTWS 4.0MG TLF
PART CODE
CD4M000000S001
VENDOR APPROVE
Issued/Checked/Approved
DATE: April 29, 2021
CUSTOMER APPROVE
DATE:
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
CD4M000000S001
MHZ THRU-HOLE CERAMIC RESONATOR CRTWS SERIES
MAIN FEATURE
• MHz Thru-Hole Ceramic Resonator, L9.5*T4.0*H6.0mm, Lead: 13.5mm, 3 pins
• Low cost, Built-in load capacitance type.
• Cross more competitors part CSTLS G and more
• RoHS/RoHS III compliant
APPLICATION
• Remote control
• Office equipment and more
RFQ
PART CODE GUIDE
Request For Quotation
CD
4M000000
S
001
1
2
3
4
1) CD: Part family Code for MHz Thru-Hole Ceramic Resonator, L9.5*T4.0*H6.0mm, 3 Pins, Lead: 13.5mm CRTWS
2) 4M000000: Frequency range code for 4.00000MHz
3) S: Packed in AMNO-Pack, 2000pcs/Tape, 1 Tape/Box
4) 001 Specification code for original Part No. TGS CRTWS 4.0MG TLF
MORE FREQUENCY RANGE AVAILABLE (MHz)
2.000
4.000
PART CODE:
CD4M000000S001
DIMENSION (Unit: mm)
Image for reference
Marking
Frequency Range + QC Code/stamp
CRTWS
Connection
① Input ② Ground ③ Output
Structure
PART CODE:
CD4M000000S001
ELECTRICAL PARAMETERS
Parameter
Part No.
Symbol
Units
Value
Min.
Original Manufacturer
Holder Type
Frequency Range
Condition
Typical
Max.
TGS
TGS Crystals
CRTWS
4.0
MHz
4.0
Withstanding Voltage
V
50
@DC, 1 min
Insulation Resistance
MΩ
100
@100V, 1
min.
Operation
Temperance
°C
-40
+85
Storage Temperance
°C
-55
+85
Rating Voltage
V
10
DC
p-p
Frequency Accuracy
Resonant Impedance
Ω
Temperature
Coefficient of
Oscillation
Frequency
±0.3
Oscillation
Frequency
drift,-40℃
~+85℃)
Oscillation Frequency
Aging Rate (10 years)
±0.3
From initial
value
IC Application
Design Mode
1/6TC4069UBPx2
MG
(C1,C2)
Other
±0.5
pF
30pF±20%
Package
T
RoHS Status
LF
RoHS III compliant
Add Value
N/A
Internal
Control
Code
N/A
Note: Original Part Number: TGS CRTWS 4.0MG TLF
PART CODE:
CD4M000000S001
RELIABILITY
Test Items
Test Method And Conditions
Humidity
Subject the resonator at +60℃±2℃ and 90%-95% R.H.
for 1000h, resonator shall be measured after being
placed in natural conditions for 1h.
It shall fulfill the
specifications in Table 1.
Subject the resonator to +85℃±2℃ for 1000h,
resonator shall be measured after being placed in
High
Temperature
Exposure
Low
Temperature Exposure
Temperature
Cycling
Performance
Requirements
Subject the resonator to –40℃±3℃ for 1000h,
resonator shall be measured after being placed in natural
conditions for 1h.
Submit to 100 cycles of the above sequence at
condition in air.
Time: 30±3 min. @ -40 +/-3℃
Time: 30±3 min. @+85 +/-3℃
Vibration
Subject the resonator to vibration for 2h each in x y and
z axis with the amplitude of 1.5mm, the frequency shall
be varied uniformly between the limits of 10Hz-55Hz
and then resonator shall be measured.
Mechanical
Shock
Apply the half-sine shock pulses:981m/s2,6ms for 3
times in each direction of three mutually perpendicular
planes.
Lead terminals are immersed up to 2 mm from
resonator’s body in soldering bath of 260℃±5℃ for
10s±1s and then resonator shall be measured after
being placed in natural conditions for 1h.
Solderability
With Rosin-methanol 25% by weight, dip in 230℃±5℃
solder(H63A) bath for 3s±0.5s.
More than 95% of the
terminal surface of the
filter shall be covered
with fresh solder.
Lead restraint
Apply the force of 5N to the lead in direction of axis and
with the load of 2.5N bend the lead through 0°→90°→90°→0°..
Resistance to Soldering
Heat
Table 1
Item
Specification after test
Oscillation Frequency Change △Fosc/Fosc (%) max
±0.25(Refer to the initial value)
Resonant Impedance (Ω) max
30
The limits in the above table are referenced to the initial measurements.
PART CODE:
CD4M000000S001
TEST CIRCUIT (For Reference Only)
Note:
Parts shall be tested under the condition
( Temp.: 20±15℃,Humidity 65±20% R.H.)
unless the standard condition(Temp.: 25±3 ℃,
Humidity :65±10% R.H.) is regulated to
measure.
PART CODE:
CD4M000000S001
TAPE AND AMNO-Pack (Unit: mm)
All Devices are packed in accordance with EIA standard RS-481-2 and Packed in AMNO-Pack
MARK
SIZE(mm)
P
12.7±0.5
Po
12.7±0.2
P1
3.85±0.5
P2
6.35±1.30
(include the slant of product)
F1
F2
Wo
W1
2.5±0.3
2.5±0.3
5.5±0.5
9.0±0.5
W2 max.
1.0
W
18.0±0.5
H
18.0
H1
27.0 max.
(Varies with P/N)
H2
36.0 max.
(Varies with P/N)
L min.
3.0
ΦDo
4.0±0.2
t1
0.6±0.2
t2 max
1.5.
1.0
△h max.
DISCLAIMER
NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained
herein without notice. No liability is assumed as a result of their use or application. No rights under any patent
accompany the sale of any such product(s) or information.
很抱歉,暂时无法提供与“CD4M000000S001”相匹配的价格&库存,您可以联系我们找货
