SA315M0000S001
SA315M0000S001
    NEXTGEN
    SMD-8
    陶瓷谐振器 ±75kHz 315MHz SMD-8
SA315M0000S001 数据手册
PART CODE: SA315M0000S001 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0521-SA315M0000S001 DATE May 21, 2021 REVISION A0 DESCRIPITION SMD SAW Resonator 5050 Type L5.0*W5.0*H1.35mm 8 Pads S3 Series 315.000KHz, Insertion Loss: 2.2 dB Max. Tolerance: +/-75KHz Operating Temp. Range -40°C ~+85°C Reflow Profile Condition 260 °C Max. Tape/Reel, RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS SR 315.0MA S3 TLF PART CODE SA315M0000S001 VENDOR APPROVE Issued/Checked/Approved DATE: May 21, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR SMD CRYSTAL 5050 2520 TYPE TYPE S3 4SERIES PADS MAIN FEATURE • SMD SAW Resonator 5050 Type 8 Pads • Dimension L5.0*W5.0*H1.35mm • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation SA 315M0000 S 001 1 2 3 4 1) SA: Part family Code for SMD SAW Resonator 5050 Type L5.0*W5.0*H1.35mm 8 Pads S3 Series 2) 315M0000: Frequency range code for 315.000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 001: Specification code for original part No.: TGS SR 315.0MA S3 TLF MORE FREQUENCY RANGE AVAILABLE (MHz) 315.00 340.000 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR 5050 TYPE S3 SERIES DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Frequency Range S3 Connection Pin 2: Input Pin 6: Output Other pins: Ground Measuring Circuit Note: Test Temperature: 25 ℃±2 ℃ Terminating Source Impedance: 50Ω Termination Load Impedance: 50Ω 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR 5050 TYPE S3 SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Original Manufacturer TGS TGS Crystals Holder Type SR SAW Resonator Max. Frequency Range (f0) 315.0M MHz Frequency Tolerance A KHz -75 +75 Operation Temperance °C -40 +85 Storage Temperance °C -40 +85 DC Voltage (between any Terminals) V 5.0 dBm 0 ESD Voltage (HB) V 400 Insertion Loss dB 1.4 RF Power (in BW) Unload 315.0000 8000 12800 1000 2000 Quality Factor (Q) 50 Ω Loaded Temperature Stability Turnover Temperature °C Frequency Temperature Coefficient ppm/°C 0.032 ppm/Year ≤±10 Aging DC Insulation Resistance MΩ Transduce Static Capacitance pF Hold Type Other S3 2.2 10 25 40 1.0 2.13 5050 Type 8 Pads L5.0*W5.0*H1.35mm Package T Tape/Reel, 1000pcs/Reel RoHS Status LF RoHS III compliant Add Value Blank: N/A Internal Control Code Blank: N/A Note: Original Part Number: TGS SR 315.0MA S3 TLF 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR 5050 TYPE S3 SERIES FREQUENCY RESPONSE EQUIVALENT LC MODEL PLICTYPCIAL APATION CIRCUITS Typical Low-power Transmitter Application Typical Local Oscillator Application 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR 5050 TYPE S3 SERIES RELIABILITY Test Items Test Method And Conditions Requirement Temperature (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h It shall remain Storage (2) Temperature: –55℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h electrical Humidity Test Conditions: 60℃±2℃ , 90~95% RH Thermal Shock Heat cycle conditions: TA=-55℃±3℃, TB=85℃±2℃, t1=t2=30min, performance Duration: 250h after tests Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. Vibration Fatigue Frequency of vibration: 10~55Hz Directions: X,Y and Z Drop Test Solderability Amplitude:1.5mm Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Duration: 3.0s--5.0s Depth: DIP--2/3 , SMD--1/5 Resistance to Soldering Heat (1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s (2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s , Recovery time : 2 ± 0.5h SUGGESTED REFLOW PROFILE (For Reference Only) 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SA315M0000S001 SMD SAW RESONATOR 5050 TYPE S3 SERIES REEL DIMENSION (Unit: mm, 1000pcs/Reel) TAPE WIDE 8MM DIMENSION (Unit: mm) Code Dimension W 12.0+/-0.30 F 5.50+/-0.05 E 1.75+/-0.10 P0 4.00+/-0.10 P1 8.00+/-0.10 P2 2.00+/-0.05 D0 Ø1.5+/-0.10 D1 Ø1.0+/-0.25 t1 0.30+/-0.05 t2 2.10+/-0.10 A 6.40+/-0.10 B 5.20+/-0.10 Code Dimension A Ø330+/-1.0 B Ø100+/-0.5 C Ø13.0+/-0.5 D Ø21+/-0.8 E 2.00+/-0.5 W 13.0+/-0.30 t 3.00 Max. r 1.00 Max. DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com 7 www.NextGenComponent.com
SA315M0000S001 价格&库存
很抱歉,暂时无法提供与“SA315M0000S001”相匹配的价格&库存,您可以联系我们找货
