RO3118A
RO3118A
    RFMI
    SMD-4
    陶瓷谐振器 ±75kHz 318MHz ±32ppb SMD-4
RO3118A 数据手册
• • • • • • Designed for 318.0 MHz Transmitters Very Low Series Resistance Quartz Stability Surface-mount Ceramic Case Complies with Directive 2002/95/EC (RoHS) Tape and Reel Standard per ANSI/EIA481 RO3118A RoHS Compliant 318.0 MHz SAW Resonator The RO3118A is a one-port surface-acoustic-wave (SAW) resonator packaged in a surface-mount ceramic case. It provides reliable, fundamental-mode quartz frequency stabilization of fixed-frequency transmitters operating at 318.0 MHz. Absolute Maximum Ratings Rating Value Units CW RF Power Dissipation (See: Typical Test Circuit) +0 dBm DC Voltage Between Terminals (Observe ESD Precautions) ±30 VDC Case Temperature -40 to +85 °C 260 °C Soldering Temperature (10 seconds / 5 cycles maximum) Electrical Characteristics Characteristic Center Frequency, +25 °C Sym fC Absolute Frequency Tolerance from 318.0 MHz Temperature Stability Frequency Aging Typical 317.925 IL 1.5 QU 12000 50 Loaded Q QL 2000 Turnover Temperature TO Turnover Frequency fO fC Frequency Temperature Coefficient FTC 0.032 Absolute Value during the First Year |fA| 10 Unloaded Q DC Insulation Resistance between Any Two Terminals RF Equivalent RLC Model Minimum fC Insertion Loss Quality Factor Notes SM5035-4 10 25 1.0 Maximum Units 318.075 MHz ±75 kHz 2.0 dB 40 °C ppm/°C2 ppm/yr M Motional Resistance RM 19.8  Motional Inductance LM 118 µH Motional Capacitance CM 2.1 fF Shunt Static Capacitance CO 2.9 pF 79 nH Test Fixture Shunt Inductance LTEST Lid Symbolization (YY - Year, WW = Week, S = Shift)) 661, YYWWS CAUTION: Electrostatic Sensitive Device. Observe precautions for handling. NOTES: 1. The design, manufacturing process, and specifications of this device are subject to change. 2. US or International patents may apply. 3. RoHS compliant from the first date of manufacture. ©2010-2014 by RFM Integrated Device, Inc. RO3118A (R) 09/21/2021 Page 1 of 3 www.rfmi.com Electrical Connections Equivalent RLC Model The SAW resonator is bidirectional and may be installed with either orientation. The two terminals are interchangeable and unnumbered. The callout NC indicates no internal connection. The NC pads assist with mechanical positioning and stability. External grounding of the NC pads is recommended to help reduce parasitic capacitance in the circuit. C Terminal Case Ground Case Ground P L Terminal C C C C S C M R M = 0 .0 5 p F (C a s P a r a s t c s ) = S A W S ta t c C a p a c ta n c = C S + C P P S M Temperature Characteristics The test circuit inductor, LTEST, is tuned to resonate with the static capacitance, CO, at FC. ELECTRICAL TEST fC = f O , T C = T O -50 -50 -100 -100 -150 -150 -200 -80 -60 -40 -20 Case -200 0 +20 +40 +60 +80 T = TC - T O ( °C ) To 50  Network Analyzer From 50  Network Analyzer 0 0 (f-fo ) / fo (ppm) Typical Test Circuit The curve shown on the right accounts for resonator contribution only and does not include LC component temperature contributions. T o p V ie w S id e V ie w B C B o tto m V ie w E ) ) 1 A POWER TEST P INCIDENT 50  Source P at F C REFLECTED CW RF Power Dissipation = Low-Loss Matching Network to 50  2 Terminal G 1 ) NC NC D Terminal P INCIDENT - P REFLECTED I Typical Application Circuits I Typical Low-Power Transmitter Application H H +9VDC Modulation Input J H 200k  C1 47 K L1 (Antenna) L PCB Footprint C2 RF Bypass RO3XXXA Bottom View Dimensions 470 A Typical Local Oscillator Applications Output +VDC C1 +VDC L1 Millimeters Inches Min Nom Max Min Nom Max 4.87 5.00 5.13 0.191 0.196 0.201 B 3.37 3.50 3.63 0.132 0.137 0.142 C 1.45 1.53 1.60 0.057 0.060 0.062 D 1.35 1.43 1.50 0.040 0.057 0.059 E 0.67 0.80 0.93 0.026 0.031 0.036 F 0.37 0.50 0.63 0.014 0.019 0.024 G 1.07 1.20 1.33 0.042 0.047 0.052 C2 RO3XXXA Bottom View ©2010-2014 by RFM Integrated Device, Inc. RO3118A (R) 09/21/2021 RF Bypass Page 2 of 3 www.rfmi.com Recommended Reflow Profile 1. 2. 3. 4. Preheating shall be fixed at 150~180° for 60~90 seconds. Ascending time to preheating temperature 150° shall be 30 seconds min. Heating shall be fixed at 220°C for 50~80 seconds and at 260°C peak (10 seconds.) Time: 5 times maximum ©2010-2014 by RFM Integrated Device, Inc. RO3118A (R) 09/21/2021 Page 3 of 3 www.rfmi.com
RO3118A
物料型号:RO3118A
器件简介: - 设计用于318.0 MHz发射器 - 非常低的串联电阻 - 石英稳定性 - 表面安装陶瓷外壳 - 符合2002/95/EC指令(RoHS) - 符合ANSI/EIA481标准的带和卷标准
引脚分配: - SAW谐振器是双向的,可以以任何方向安装 - 两个端子是可互换的,未编号 - 标记NC表示内部无连接
参数特性: - 中心频率:317.925 MHz 至 318.075 MHz - 插入损耗:1.5 dB 至 2.0 dB - 品质因数:未加载Q值 12000,50欧姆加载Q值 2000 - 温度稳定性:转换温度 10°C 至 40°C - 频率温度系数:0.032 ppm/°C² - 频率老化:第一年内绝对值 ≤10 ppm/yr - DC绝缘电阻:1.0 MΩ - RF等效RLC模型:运动电阻19.8 Ω,运动电感118 μH,运动电容2.1 fF,并联静态电容2.9 pF,测试夹具并联电感79 nH
功能详解: - 提供固定频率发射器在318.0 MHz的可靠、基频石英频率稳定 - 测试电路电感LTEST与静态电容CO在FC处谐振 - 典型应用电路包括低功耗发射器应用和本地振荡器应用
应用信息: - 典型低功耗发射器应用电路和典型本地振荡器应用电路
封装信息: - 封装类型:SM5035-4 - PCB足迹尺寸:最小值、标称值、最大值(毫米和英寸)
注意事项: - 静电敏感设备,处理时需注意预防措施 - 设计、制造过程和规格可能会变化 - 自制造之日起符合RoHS标准
推荐回流焊曲线: - 预热温度固定在150~180°C,持续60~90秒 - 达到预热温度150°C的上升时间至少30秒 - 加热温度固定在220°C,持续50~80秒,峰值260°C(10秒)
RO3118A 价格&库存
很抱歉,暂时无法提供与“RO3118A”相匹配的价格&库存,您可以联系我们找货
