PART CODE:
CK4M000000S001
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0208-CK4M000000S001
DATE
Feb. 08, 2021
REVISION
A0
DESCRIPITION
SMD Ceramic Resonator, 7434 Type, L7.4*W3.4*H1.8mm, 3 pads
4.00MHz, Built-in Capacitance
Frequency Accuracy +/-0.3%, Operating Temp. Range -25°C ~+85°C,
Tape/Reel, Reflow Profile Condition 260 °C Max.
RoHS/RoHS III compliant, Tape/Reel
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
TGS CRTC 4.0MG TLF
PART CODE
CK4M000000S001
VENDOR APPROVE
Issued/Checked/Approved
DATE: Feb. 08, 2021
CUSTOMER APPROVE
DATE:
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
CK4M000000S001
MHZ SMD CERAMIC RESONATOR CRTC SERIES
MAIN FEATURE
• MHz SMD Ceramic Resonator, L7.4*W3.4*H1.8mm, 3 pads
• Low cost, Built-in load capacitance type.
• Reflow Profile Condition 260 °C Max.
• Cross more competitors part
• RoHS/RoHS III compliant
APPLICATION
• Measurement Instrument
• Communication Electronics
RFQ
PART CODE GUIDE
Request For Quotation
CK
4M000000
S
001
1
2
3
4
1) CK: Part family Code for SMD Ceramic Resonator, L7.4*W3.4*H1.8mm, 3 pads, CRTC series
2) 4M000000: Frequency range code for 4.00000MHz
3) S: SMD type, Package Tape/Reel, 4000pcs/Reel
4) 001 Specification code for original Part No. TGS CRTC 4.0MG TLF
MORE FREQUENCY RANGE AVAILABLE (MHz)
3.5800
4.000
4.91000
PART CODE:
CK4M000000S001
DIMENSION (Unit: mm, Tol. +/-0.15mm)
Image for reference
Marking
Line 1: Frequency Range, 4..000MHz
CRTC
Connection
① Input ② Ground ③ Output
Recommend Pad Layout
PART CODE:
CK4M000000S001
ELECTRICAL PARAMETERS
Parameter
Part No.
Symbol
Units
Value
Min.
Typical
Condition
Max.
Original
Manufacturer
TGS
TGS Crystals
Holder Type
CRTC
Frequency Range
4.0
MHz
4.000
Withstanding Voltage
V
50
@DC, 1 min
Insulation Resistance
MΩ
500
@AV, 1
min.
Operation
Temperance
°C
-25
+85
Storage Temperance
°C
-55
+85
Rating Voltage
V
6
DC
15
p-p
Frequency Accuracy
Resonant Impedance
Ω
30
Temperature
Coefficient of
Oscillation
Frequency
+/-0.3
Oscillation
Frequency
drift,25℃~
+85℃)
Oscillation Frequency
Aging Rate (10 years)
+/-0.3
From initial
value
IC application
Design Mode
1/6TC4069UBPx2
MG
Other
s
0.5
pF
30
Package
T
Tape/Reel
RoHS Status
LF
RoHS III compliant
Add Value
N/A
Internal
Control
Code *
N/A
Note: 1) Original Part Number: TGS CRTC 4.0MG TLF
2) * Internal Control Code- 2 letter or digits; Blank: N/A
PART CODE:
CK4M000000S001
RELIABILITY
Test Items
Humidity
Test Method And Conditions
Performance
Requirements
Keep the resonator at 40℃±2℃ and 90%-95% RH for 96h.
Then Release the resonator into the room Condition for 1h
prior to the Measurement.
It shall fulfill the
specifications in
Table 1.
High
Temperature
Exposure
Subject the resonator to -85℃±2℃ for 96h, then release
the resonator into the room conditions for 1h prior to
the measurement.
specifications in
Table 1.
Low
Temperature Exposure
Subject the resonator to -55℃±2℃ for 96h, then release
the measurement.
It shall fulfill
the specifications
in Table 1.
Temperature
Cycling
After temperature cycling of blow table was performed 5
times, resonator shall be measured after being placed in
natural conditions for 1h. Time: 30 min.@ -25 +/-3℃
; Time: 30 min. @85 +/-3℃
It shall fulfill
the specifications
in Table 1.
Vibration
Subject the resonator to vibration for 2h each in x, y and z
axis With the amplitude of 1.5mm, the frequency shall be
varied uniformly between the limits of 10 Hz—55Hz.
It shall fulfill
the specifications
in Table 1.
Drop the resonator randomly onto a wooden floor from the
height of 100cm 3 times.
It shall fulfill
the specifications
in Table 1.
Passed through the re-flow oven under the following
condition and left at room temperature for 1h before
measurement
It shall fulfill
the specifications
in Table 1.
Solder
Ability
Dipped in 245℃±5℃ solder bath for 3s±0.5 s with rosin flux
(25wt% ethanol solution.)
The terminals shall
be at least 95%
covered by solder.
Board Bending
Mount a glass-epoxy board
(Width=40mm,thickness=1.6mm),then bend it to 1mm
displacement and keep it for 5s. (See the following figure 1)
Mechanical damage
such as breaks shall
not occur.
Mechanical
Shock
Soldering Test
Table 1
Item
Specification after test
Oscillation Frequency Change △Fosc/Fosc (%) max
Resonant Impedance (Ω) max
±0.3
35
The limits in the above table are referenced to the initial measurements.
PART CODE:
CK4M000000S001
TEST CIRCUIT (For Reference Only)
Note:
Parts shall be tested under the condition
( Temp.: 20±15℃,Humidity 65±20% R.H.)
unless the standard condition(Temp.:
25±3 ℃, Humidity :65±10% R.H.) is
regulated to measure.
SUGGESTED REFLOW PROFILE (For Reference Only)
BOARD BENDING TEST- FIGURE 1
PART CODE:
CK4M000000S001
TAPE/REEL (Unit: mm)
All Devices are packed in accordance with EIA standard RS-481-2 and specifications. 4000pcs/Reel
Symbol
Dimension
ɸA
330±3.0
ɸB
80.0 Min.
W
16.4 Min.
T
22.4 Max.
DISCLAIMER
NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained
herein without notice. No liability is assumed as a result of their use or application. No rights under any patent
accompany the sale of any such product(s) or information
很抱歉,暂时无法提供与“CRTC4.0MG TLF”相匹配的价格&库存,您可以联系我们找货
