OGH500
OGH500
    IFM(易福门)
    DIFFUSE REFLECTION SENSOR; RED L
OGH500 数据手册
OGH500 Diffuse reflection sensor with background suppression OGH-FPKG/US100 1 programming buttons Product characteristics Type of light red light Housing Dimensions threaded type [mm] M18 x 1 / L = 72 Application Special feature Background suppression Function principle Diffuse reflection sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 25 II Reverse polarity protection yes Type of light Wave length 10...36 DC red light [nm] 624 Outputs Electrical design PNP Output function light-on/dark-on mode; (programmable) Max. voltage drop switching output DC [V] Permanent current rating of switching output DC [mA] 150; (200 (...60 °C)) Switching frequency DC [Hz] 1000 Factory setting Short-circuit protection 2.5 light-on mode yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH500-00 — 23.05.2011 — OGH500 Diffuse reflection sensor with background suppression OGH-FPKG/US100 Detection zone Range [mm] 15...300; (white paper 200 x 200 mm 90% remission) Range on white object (90 % [mm] remission) 15...300 Range on grey object (18 % remission) [mm] 15...290 Range on black object (6 % remission) [mm] 15...190 Range adjustable yes Max. light spot diameter [mm] 25 Light spot dimensions refer to at maximum range Background suppression available yes Operating conditions Ambient temperature [°C] -25...80 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 362 [g] 61.1 Mechanical data Weight Housing Dimensions threaded type [mm] M18 x 1 / L = 72 Thread designation Materials M18 x 1 stainless steel (1.4404 / 316L); PA; LCP; EPDM; TPU Lens material PMMA Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 x Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH500-00 — 23.05.2011 — OGH500 Diffuse reflection sensor with background suppression OGH-FPKG/US100 Connection Diagrams and graphs a: sensor b: object c: background x: distance sensor/object [mm] y: min. distance object/background [mm] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH500-00 — 23.05.2011 — OGH500 Diffuse reflection sensor with background suppression OGH-FPKG/US100 accuracy graph x: distance sensor/object [mm] y: min. distance object/background [mm] 1 = object black (6 % remission) , background (white 90 % remission) 2 = object grey (18 % remission) , background (white 90 % remission) 3 = object white (90 % remission) , background (white 90 % remission) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH500-00 — 23.05.2011 —
OGH500 价格&库存
很抱歉,暂时无法提供与“OGH500”相匹配的价格&库存,您可以联系我们找货
