O6S203
O6S203
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O6S203 数据手册
O6S203 Through-beam sensor transmitter O6S-OOKG/AS/4P 1: light emission Product characteristics Type of light red light Housing Dimensions rectangular [mm] 35.4 x 13 x 21 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 11; ((24 V)) Protection class III Type of light Wave length red light [nm] 633 Detection zone Transmitter / receiver Range Max. light spot diameter transmitter [m] < 10 [mm] 300 Light spot dimensions refer to at maximum range Operating conditions Ambient temperature Protection [°C] -25...60 IP 65; IP 67 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S203-00 — 28.02.2014 — O6S203 Through-beam sensor transmitter O6S-OOKG/AS/4P Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 2600 UL Approval no. E002 Mechanical data Weight [g] 17.6 Housing Dimensions rectangular [mm] 35.4 x 13 x 21 Materials housing: ABS; PPSU Lens material PMMA Lens alignment side lens Sealing material EPDM Tightening torque [Nm] 0.5 Displays / operating elements Display operation 1 x LED, green Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M8; Locking: brass, coated; Sealing: EPDM Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S203-00 — 28.02.2014 — O6S203 Through-beam sensor transmitter O6S-OOKG/AS/4P Diagrams and graphs excess gain graph x: distance [mm] y: excess gain factor ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S203-00 — 28.02.2014 —
O6S203 价格&库存
很抱歉,暂时无法提供与“O6S203”相匹配的价格&库存,您可以联系我们找货
