OGH282
OGH282
    IFM(易福门)
    DIFFUSE REFLECTION SENSOR; RED L
OGH282 数据手册
OGH282 Diffuse reflection sensor with background suppression OGH-HNKG/US/CUBE/100MM transmitter in lower lens receiver in upper lens Product characteristics Type of light red light Communication interface IO-Link Housing Dimensions rectangular [mm] 52.6 x 19.1 x 35.9 Application Special feature Background suppression Function principle Diffuse reflection sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 25 III Reverse polarity protection yes Type of light Wave length 10...30 DC red light [nm] 645 Outputs Electrical design NPN Output function light-on mode Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH282-04 — 18.12.2020 — OGH282 Diffuse reflection sensor with background suppression OGH-HNKG/US/CUBE/100MM Detection zone Range [mm] < 100; (white paper 200 x 200 mm 90% remission) Range on white object (90 % [mm] remission) < 100 Range on grey object (18 % remission) [mm] < 100 Range on black object (6 % remission) [mm] < 100 Range adjustable no Max. light spot diameter [mm] 7 Light spot dimensions refer to at maximum range Background suppression available yes Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Smart Sensor: Device Identification; Device Diagnosis; Teach Channel; Switching Channel SIO mode yes Required master port type Min. process cycle time A [ms] IO-Link process data (cyclical) IO-Link functions (acyclical) 10 function bit length process value 16 device status 4 binary switching information 1 application specific tag; operating hours counter; switching cycles counter Supported DeviceIDs Note Type of operation DeviceID Default 1138 For further information please see the IODD PDF file under "Downloads" Operating conditions Ambient temperature [°C] -25...60 Storage temperature [°C] -40...60 Protection IP 65; IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 782 Ta -25...60 °C Enclosure type Type 1 voltage supply Class 2 File number UL E174191 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH282-04 — 18.12.2020 — OGH282 Diffuse reflection sensor with background suppression OGH-HNKG/US/CUBE/100MM Mechanical data Weight [g] 60 Housing rectangular Dimensions [mm] 52.6 x 19.1 x 35.9 Materials diecast zinc; PEI Lens material PEI Lens alignment side lens Displays / operating elements Display switching status 1 x LED, yellow operation 1 x LED, green Accessories Items supplied lock nut: 1 x Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12 Connection 4 OUT / IO-Link ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH282-04 — 18.12.2020 — OGH282 Diffuse reflection sensor with background suppression OGH-HNKG/US/CUBE/100MM Other data Repeatability / precision: 6 σ repeatability of the measured values Abstand white (90 % remission) black (6 %...90 % remission) 20 mm 0.5 mm 1.0 mm 50 mm 0.8 mm 2.0 mm 100 mm 1.5 mm 4.5 mm Accuracy Abstand white (90 % remission) black (6 %...90 % remission) 20 mm ± 1.5 mm ± 1.8 mm 50 mm ± 3.0 mm ± 3.5 mm 100 mm ± 5.0 mm ± 6.5 mm The values apply at Extraneous light on the object < 10 klx constant ambient conditions 23 °C / 960 hPa minimum power-on time in minutes 10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH282-04 — 18.12.2020 —
OGH282
- 物料型号:OGH-HNKG/US/CUBE/100MM - 器件简介:该传感器具备背景抑制功能,使用红光,具有10-Link通信接口。 - 引脚分配:文档中提到了 M12x1 的连接器,但没有提供具体的引脚分配图。 - 参数特性: - 工作电压:10...30V DC - 电流消耗:25 mA - 保护等级:具有防反接保护 - 光源类型:红光,波长 645 nm - 输出类型:NPN,光启模式 - 最大电压降:2.5 V DC - 永久电流额定值:200 mA - 切换频率:1000 Hz - 短路保护:有,脉冲式 - 过载保护:有 - 功能详解:传感器采用漫反射原理,具有背景抑制功能,不可调节检测范围,最大光斑直径为7毫米。 - 应用信息:适用于白色(90%反射率)和灰色(18%反射率)物体,黑色物体(6%反射率)的检测,检测范围小于100毫米。 - 封装信息:外形尺寸为 52.6x19.1x35.9 毫米,材料为压铸锌和 PEI,重量为60克。
OGH282 价格&库存
很抱歉,暂时无法提供与“OGH282”相匹配的价格&库存,您可以联系我们找货
