O5H500
O5H500
    IFM(易福门)
    DIFFUSE REFLECTION SENSOR; RED L
O5H500 数据手册
O5H500 Diffuse reflection sensor with background suppression O5H-FPKG/US100 1 2 programming buttons When a M5 mounting screw is used, the max. tightening torque is 2 Nm. Product characteristics Type of light red light Housing Dimensions rectangular [mm] 56 x 18.2 x 46.8 Application Special feature Background suppression Function principle Diffuse reflection sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 25 II Reverse polarity protection yes Type of light Wave length 10...36 DC red light [nm] 624 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O5H500-00 — 13.04.2007 — O5H500 Diffuse reflection sensor with background suppression O5H-FPKG/US100 Outputs Electrical design PNP Output function light-on/dark-on mode; (programmable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Detection zone Range [mm] 50...1800; (white paper 200 x 200 mm 90% remission) Range on white object (90 % [mm] remission) 50...1800 Range on grey object (18 % remission) [mm] 50...900 Range on black object (6 % remission) [mm] 50...600 Range adjustable yes Max. light spot diameter [mm] 50 Light spot dimensions refer to Range Background suppression available yes Operating conditions Ambient temperature [°C] -25...60 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 360 [g] 67.5 Mechanical data Weight Housing Dimensions rectangular [mm] Materials 56 x 18.2 x 46.8 housing: PA; bezel: stainless steel; operator interface: TPU Lens material PMMA Lens alignment side lens Displays / operating elements Display switching status 1 x LED, yellow Teach function yes Electronic lock yes Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O5H500-00 — 13.04.2007 — O5H500 Diffuse reflection sensor with background suppression O5H-FPKG/US100 Electrical connection Connector: 1 x M12 Connection Diagrams and graphs a: sensor b: object c: background x: distance sensor/object [mm] y: min. distance object/background [mm] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O5H500-00 — 13.04.2007 — O5H500 Diffuse reflection sensor with background suppression O5H-FPKG/US100 accuracy graph x: distance sensor/object [mm] y: min. distance object/background [mm] 1 = object black (6 % remission) , background (white 90 % remission) 2 = object grey (18 % remission) , background (white 90 % remission) 3 = object white (90 % remission) , background (white 90 % remission) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O5H500-00 — 13.04.2007 —
O5H500 价格&库存
很抱歉,暂时无法提供与“O5H500”相匹配的价格&库存,您可以联系我们找货
