O6H303
Diffuse reflection sensor with background suppression
O6H-FPKG/AS/4P
1:
2:
output function switch
potentiometer sensitivity
Product characteristics
Type of light
red light
Housing
Dimensions
rectangular
[mm]
41.3 x 13 x 21
Application
Special feature
Background suppression
Function principle
Electrical data
Operating voltage
Current consumption
[V]
10...30 DC
[mA]
22; ((24 V))
Protection class
III
Reverse polarity protection
yes
Type of light
Wave length
red light
[nm]
633
Outputs
Electrical design
PNP
Output function
light-on/dark-on mode; (selectable)
Max. voltage drop switching
output DC
[V]
2.5
Permanent current rating of
switching output DC
[mA]
100
Switching frequency DC
[Hz]
1000
Short-circuit protection
Type of short-circuit
protection
yes
pulsed
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6H303-01 — 03.06.2014 —
O6H303
O6H-FPKG/AS/4P
Detection zone
Range
[mm]
2...200; (white paper 200 x 200 mm)
Range on white object (90 %
[mm]
remission)
2...200
Range on grey object (18 %
remission)
[mm]
4...200
Range on black object (6 %
remission)
[mm]
8...200
Range adjustable
yes
Max. light spot diameter
[mm]
8
Light spot dimensions refer to
at maximum range
available
yes
Operating conditions
Ambient temperature
[°C]
-25...80
Protection
IP 65; IP 67; IP 68; IP 69K
Tests / approvals
EMC
EN 60947-5-2
MTTF
[years]
UL approval
708
UL Approval no.
E001
Mechanical data
Weight
[g]
34.3
Housing
Dimensions
rectangular
[mm]
Materials
41.3 x 13 x 21
housing: stainless steel (1.4404 / 316L); plastics: PPSU; Sealing: EPDM
Lens material
PMMA
Lens alignment
side lens
Displays / operating elements
Display
switching status
1 x LED, yellow
operation
1 x LED, green
Remarks
Remarks
Pack quantity
operating voltage "supply class 2" according to cULus
1 pcs.
Electrical connection
Connector: 1 x M8
O6H303
O6H-FPKG/AS/4P
Connection
Diagrams and graphs
a:
sensor
b:
object
c:
background
x:
distance sensor/object [mm]
y:
min. distance object/background [mm]
O6H303
O6H-FPKG/AS/4P
accuracy graph
x:
y:
1 = object black (6 % remission) , background (white 90 % remission)
2 = object grey (18 % remission) , background (white 90 % remission)
3 = object white (90 % remission) , background (white 90 % remission)
很抱歉,暂时无法提供与“O6H303”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1492.632591+193.88540
