OGH580
OGH580
    IFM(易福门)
    DIFFUSE REFLECTION SENSOR; RED L
OGH580 数据手册
OGH580 Diffuse reflection sensor with background suppression OGH-FPKG/US/CUBE 1 programming buttons transmitter in lower lens receiver in upper lens Product characteristics Type of light red light Communication interface IO-Link Housing Dimensions rectangular [mm] M18 x 1 Application Special feature Background suppression Function principle Diffuse reflection sensor Electrical data Operating voltage [V] 10...30 DC; ("supply class 2" to cULus) Rated insulation voltage [V] 32 [mA] 25 Current consumption Protection class III Reverse polarity protection Max. power-on delay time yes [ms] Type of light Wave length 300 red light [nm] 645 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH580-03 — 18.12.2020 — OGH580 Diffuse reflection sensor with background suppression OGH-FPKG/US/CUBE Outputs Electrical design PNP Output function light-on/dark-on mode; (programmable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Detection zone Range [mm] 15...200; (white paper 200 x 200 mm 90% remission) Range on white object (90 % [mm] remission) 15...200 Range on grey object (18 % remission) [mm] 15...200 Range on black object (6 % remission) [mm] 15...200 Range adjustable Max. light spot diameter yes [mm] 13 Light spot dimensions refer to at maximum range Background suppression available yes Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Profiles Measuring Sensor, Identification and Diagnosis, Switching Signal Channel, Teach Channel SIO mode yes Required master port type Min. process cycle time A [ms] IO-Link process data (cyclical) IO-Link functions (acyclical) 10 function bit length process value 16 device status 4 binary switching information 1 application specific tag; operating hours counter; switching cycles counter Supported DeviceIDs Note Type of operation DeviceID Default 1132 For further information please see the IODD PDF file under "Downloads" Operating conditions Ambient temperature [°C] -25...60 Storage temperature [°C] -40...60 Protection IP 65; IP 67 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH580-03 — 18.12.2020 — OGH580 Diffuse reflection sensor with background suppression OGH-FPKG/US/CUBE Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 782 Ta -25...60 °C Enclosure type Type 1 voltage supply Class 2 File number UL E174191 Mechanical data Weight [g] 60.5 Housing Dimensions rectangular [mm] M18 x 1 Thread designation M18 x 1 Materials diecast zinc; PEI Lens material PEI Displays / operating elements Display Operating elements switching status 1 x LED, yellow operation 1 x LED, green switch point pushbutton Output function pushbutton Accessories Items supplied lock nut: 1 x Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH580-03 — 18.12.2020 — OGH580 Diffuse reflection sensor with background suppression OGH-FPKG/US/CUBE Connection Other data Repeatability / precision: 6 σ repeatability of the measured values Abstand white (90 % remission) black (6 %...90 % remission) 20 mm 0.5 mm 1.0 mm 50 mm 0.8 mm 2.0 mm 100 mm 1.5 mm 4.5 mm 150 mm 3.0 mm 9.0 mm 200 mm 6.0 mm 20.0 mm Accuracy Abstand white (90 % remission) black (6 %...90 % remission) 20 mm ± 2.0 mm ± 2.5 mm 50 mm ± 3.5 mm ± 4.5 mm 100 mm ± 6.0 mm ± 7.5 mm 150 mm ± 7.5 mm ± 11.0 mm 200 mm ± 10.0 mm ± 17.0 mm The values apply at Extraneous light on the object < 10 klx constant ambient conditions 23 °C / 960 hPa minimum power-on time in minutes 10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH580-03 — 18.12.2020 — OGH580 Diffuse reflection sensor with background suppression OGH-FPKG/US/CUBE Diagrams and graphs a: sensor b: object c: background x: distance sensor/object [mm] y: min. distance object/background [mm] x: distance sensor/object [mm] y: min. distance object/background [mm] accuracy graph 1 = object black (6 % remission) , background (white 90 % remission) 2 = object grey (18 % remission) , background (white 90 % remission) 3 = object white (90 % remission) , background (white 90 % remission) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGH580-03 — 18.12.2020 —
OGH580 价格&库存
很抱歉,暂时无法提供与“OGH580”相匹配的价格&库存,您可以联系我们找货
