OGD592
OGD592
    IFM(易福门)
    PHOTOELECTRIC DISTANCE SENSOR; 2
OGD592 数据手册
OGD592 Photoelectric distance sensor OGDLFPKG/IO-LINK/US 1 2 alphanumeric display , 3-digit programming buttons Product characteristics Type of light Measuring range red light [m] Communication interface IO-Link Laser protection class Dimensions 0.025...0.3 1 [mm] 61.7 x 22.5 x 45.2 Application Application [m] 0.03...0.3 [V] 10...30 DC; ("supply class 2" to cULus) Electrical data Operating voltage Current consumption [mA] Current consumption reference voltage [V] Protection class < 75 24 III Reverse polarity protection yes Type of light red light Wave length [nm] Typ. lifetime [h] 650 50000 Outputs Electrical design PNP Output function 2 x normally open / normally closed; (parameterisable) Permanent current rating of switching output DC [mA] 100; (per output) Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGD592-00 — 16.12.2020 — OGD592 Photoelectric distance sensor OGDLFPKG/IO-LINK/US Detection zone Max. light spot width [mm] 3 Max. light spot height [mm] 3 Light spot dimensions refer to Background suppression at maximum range [m] 0.03...19.2 [m] 0.025...0.3 [Hz] 33 Measuring/setting range Measuring range Sampling rate Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SDCI standard IEC 61131-9 Smart Sensor: Sensor Identification; Binary Data Channel; Process Value; Sensor Diagnosis Profiles SIO mode yes Required master port type A Process data analogue 2 Process data binary 2 Min. process cycle time [ms] Supported DeviceIDs 6 Type of operation DeviceID Default 1012 Operating conditions Ambient temperature [°C] In ambient temperatures < -10 °C a warm-up time is necessary. Note on ambient temperature Storage temperature -25...50 Laser is off. [°C] -30...80 Protection IP 65; IP 67 Tests / approvals EMC EN 60947-5-2 Laser protection class 1 Caution: laser light laser class: 1 EN / IEC60825-1:2007 Notes on laser protection EN / IEC60825-1:2014 Complies with 21 CFR 1040 except for deviations pursuant to Laser Notice No. 50, dated June 2007. MTTF [years] 181 [g] 205 Mechanical data Weight Dimensions Materials [mm] 61.7 x 22.5 x 45.2 Housing: stainless steel (1.4404 / 316L); PPSU; ABS; PMMA; PBT / PC; EPDM; front lens: glass ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGD592-00 — 16.12.2020 — OGD592 Photoelectric distance sensor OGDLFPKG/IO-LINK/US Displays / operating elements switching status Display 2 x LED, yellow 1 x alphanumeric display, 3-digit Accessories Items supplied lock nuts: 2 Remarks Remarks operating voltage "supply class 2" according to cULus Pack quantity 1 pcs. Electrical connection Connector: 1 x M12 Connection 2: OUT2: switching output 4: OUT1: switching output or IO-Link 5: IN1: Laser On/ Off ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGD592-00 — 16.12.2020 — OGD592 Photoelectric distance sensor OGDLFPKG/IO-LINK/US Other data Parameter Setting range Factory setting Uni mm, inch mm OU1 Hno, Hnc, Fno, Fnc, OFF Hno SP1 [mm] 30...300 300 nP1 [mm] 30...300 90 FP1 [mm] 30...300 110 OU2 Hno, Hnc, Fno, Fnc, OFF Hno SP2 [mm] 30...300 30 nP2 [mm] 30...300 190 FP2 [mm] 30...300 210 dS1 [s] 0...0.1...5 0 dr1 [s] 0...0.1...5 0 dS2 [s] 0...0.1...5 0 dr2 [s] 0...0.1...5 0 dFo [s] 0...0.1...5 0.1 dIS ON / OFF ON Repeatability: 6 σ repeatability of the measured values distance white (90 % remission) black (6 %...90 % remission) 25...300 mm 2.0 mm 5.0 mm The values apply at Extraneous light on the object < 10 klx constant ambient conditions 23 °C / 960 hPa minimum power-on time in minutes 10 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGD592-00 — 16.12.2020 — OGD592 Photoelectric distance sensor OGDLFPKG/IO-LINK/US Diagrams and graphs hysteresis graph x: distance sensor/object [mm] y: min. distance object/background [mm] 1 = background (black 6 % remission) 2 = background (white 90 % remission) a: sensor b: object c: background x: distance sensor/object [mm] y: min. distance object/background [mm] ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGD592-00 — 16.12.2020 —
OGD592 价格&库存
很抱歉,暂时无法提供与“OGD592”相匹配的价格&库存,您可以联系我们找货
