O6S400
O6S400
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O6S400 数据手册
O6S400 Through-beam sensor transmitter O6S-OOKG/AS/4P 1: light emission Product characteristics Type of light red light Housing rectangular Dimensions [mm] 34.8 x 13 x 21 Application Function principle Through-beam sensor Application suited for use in the machine tool industry Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 11; ((24 V)) Protection class III Type of light red light Wave length [nm] 633 Detection zone Transmitter / receiver transmitter Range Max. light spot diameter [m] < 10 [mm] 300 Light spot dimensions refer to at maximum range Operating conditions Ambient temperature [°C] -25...60 Protection IP 65; IP 67; IP 68 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 2942 UL Approval no. E002 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S400-00 — 23.10.2015 — O6S400 Through-beam sensor transmitter O6S-OOKG/AS/4P Mechanical data Weight [g] 33.7 Housing Dimensions rectangular [mm] Materials 34.8 x 13 x 21 housing: stainless steel (1.4404 / 316L); plastics: PPSU; Sealing: FKM Lens material PMMA Lens alignment side lens Displays / operating elements Display operation 1 x LED, green Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M8 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S400-00 — 23.10.2015 — O6S400 Through-beam sensor transmitter O6S-OOKG/AS/4P Diagrams and graphs excess gain graph x: distance [mm] y: excess gain factor ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6S400-00 — 23.10.2015 —
O6S400 价格&库存
很抱歉,暂时无法提供与“O6S400”相匹配的价格&库存,您可以联系我们找货
