OG0039
OG0039
    IFM(易福门)
    THROUGH-BEAM SENSOR; INFRARED LI
OG0039 数据手册
OG0039 Through-beam sensor receiver OGE-DBOA/LS-100-AK 1 pushbutton Product characteristics Type of light infrared light Housing Dimensions threaded type [mm] M18 x 1 / L = 76 Application Function principle Through-beam sensor Electrical data Frequency AC Operating voltage [Hz] 47...63 [V] 20...250 AC/DC Protection class II Reverse polarity protection no Type of light Wave length infrared light [nm] 880 Outputs Output function dark-on mode Max. voltage drop switching output DC [V] 8 Max. voltage drop switching output AC [V] 8 Minimum load current [mA] 5 Max. leakage current [mA] 1.7 Permanent current rating of switching output AC [mA] 90; (180 (...40 °C)) Permanent current rating of switching output DC [mA] 90; (180 (...40 °C)) Short-time current rating of switching output [mA] 600; (20 ms / 0,5 Hz) Switching frequency AC [Hz] 25 Switching frequency DC [Hz] 25 Short-circuit proof no Overload protection no ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OG0039-00 — 06.03.2003 — OG0039 Through-beam sensor receiver OGE-DBOA/LS-100-AK Detection zone Transmitter / receiver receiver Range [m] < 15 Range adjustable yes Operating conditions Ambient temperature [°C] -25...80 Protection IP 67 Tests / approvals EN 60947-5-2 EMC EN 55011 MTTF class B [years] 334 [g] 38.8 Mechanical data Weight Housing Dimensions threaded type [mm] M18 x 1 / L = 76 Thread designation M18 x 1 Materials PBT Lens material PMMA Displays / operating elements Display switching status 1 x LED, red function 1 x LED, red flashing Electrical connection Required protection miniature fuse to IEC60127-2 sheet 1; ≤ 2 A; fast acting Accessories Items supplied lock nuts: 2 x Remarks Remarks Pack quantity Recommendation: Check the safe functioning of the unit after a short circuit. 1 pcs. Electrical connection Connector: 1 x 1/2" ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OG0039-00 — 06.03.2003 — OG0039 Through-beam sensor receiver OGE-DBOA/LS-100-AK Connection Note : miniature fuse to IEC60127-2 sheet 1 ≤ 2 A fast acting Diagrams and graphs excess gain graph ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OG0039-00 — 06.03.2003 —
OG0039 价格&库存
很抱歉,暂时无法提供与“OG0039”相匹配的价格&库存,您可以联系我们找货
