O6E202
O6E202
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O6E202 数据手册
O6E202 Through-beam sensor receiver O6E-FPKG/AS/3P 1: 2: 3: output function switch potentiometer sensitivity Light incidence Product characteristics Type of light red light Housing Dimensions rectangular [mm] 46 x 13 x 21 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] 10...30 DC [mA] 7; ((24 V)) Protection class III Reverse polarity protection yes Type of light Wave length red light [nm] 633 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E202-01 — 02.06.2014 — O6E202 Through-beam sensor receiver O6E-FPKG/AS/3P Outputs Electrical design PNP Output function light-on/dark-on mode; (selectable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Detection zone Transmitter / receiver receiver Range [m] < 10 Range adjustable yes Operating conditions Ambient temperature [°C] -25...60 Protection IP 65; IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] UL approval 956 UL Approval no. E001 Mechanical data Weight [g] 18.1 Housing Dimensions rectangular [mm] 46 x 13 x 21 Materials housing: ABS; PPSU Lens material PMMA Lens alignment side lens Sealing material EPDM Tightening torque [Nm] 0.5 Displays / operating elements Display switching status 1 x LED, yellow operation 1 x LED, green Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M8; Locking: brass, coated; Sealing: EPDM ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E202-01 — 02.06.2014 — O6E202 Through-beam sensor receiver O6E-FPKG/AS/3P Connection Diagrams and graphs excess gain graph x: distance [mm] y: excess gain factor ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O6E202-01 — 02.06.2014 —
O6E202 价格&库存
很抱歉,暂时无法提供与“O6E202”相匹配的价格&库存,您可以联系我们找货
