OGE700
OGE700
    IFM(易福门)
    THROUGH-BEAM SENSOR; LIGHT-ON/DA
OGE700 数据手册
OGE700 Through-beam laser sensor receiver OGELFPKG/US100 1 programming buttons Product characteristics Type of light red light Housing Dimensions threaded type [mm] M18 x 1 / L = 72 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 10...36 DC 11 II Reverse polarity protection yes Type of light red light Wave length [nm] Typ. lifetime [h] 655 50000 Outputs Electrical design PNP Output function light-on/dark-on mode; (programmable) Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 1000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGE700-01 — 27.06.2008 — OGE700 Through-beam laser sensor receiver OGELFPKG/US100 Detection zone Transmitter / receiver receiver Range [m] < 60 Factory setting dark-on mode Range adjustable Diameter of the smallest detectable object yes [mm] 3; (60 m) [°C] -10...60 Operating conditions Ambient temperature Protection IP 65; IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 786 [g] 61.9 Mechanical data Weight Housing Dimensions threaded type [mm] M18 x 1 / L = 72 Thread designation Materials M18 x 1 stainless steel (1.4404 / 316L); PA; LCP; EPDM; TPU Lens material PMMA Displays / operating elements Display switching status 1 x LED, yellow Accessories Items supplied lock nuts: 2 x Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus 1 pcs. Electrical connection Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGE700-01 — 27.06.2008 — OGE700 Through-beam laser sensor receiver OGELFPKG/US100 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OGE700-01 — 27.06.2008 —
OGE700 价格&库存
很抱歉,暂时无法提供与“OGE700”相匹配的价格&库存,您可以联系我们找货
OGE700
    • 1+1407.958871+182.99220
    • 5+1343.881705+174.66410
