O4S500
O4S500
    IFM(易福门)
    THROUGH-BEAM SENSOR; RED LIGHT;
O4S500 数据手册
O4S500 Through-beam sensor transmitter O4S-OOKG/US100 1 2 When a M5 mounting screw is used, the max. tightening torque is 2 Nm. light emission Product characteristics Type of light red light Housing Dimensions rectangular [mm] 74.4 x 27 x 63.8 Application Function principle Through-beam sensor Electrical data Operating voltage Current consumption [V] [mA] Protection class 20 II Reverse polarity protection yes Type of light Wave length 10...36 DC; ("supply class 2" to cULus) red light [nm] 624 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O4S500-00 — 30.01.2009 — O4S500 Through-beam sensor transmitter O4S-OOKG/US100 Outputs Overload protection yes Detection zone Transmitter / receiver transmitter Range [m] 0...80 Range adjustable no Max. light spot diameter [mm] 2400 Light spot dimensions refer to at maximum range Operating conditions Ambient temperature [°C] -25...60 Protection IP 67 Tests / approvals EMC EN 60947-5-2 MTTF [years] 616 Mechanical data Weight [g] 122 Housing Dimensions rectangular [mm] Materials 74.4 x 27 x 63.8 housing: PA; bezel: stainless steel; operator interface: TPE Lens material PMMA Lens alignment side lens Displays / operating elements Display operation 1 x LED, green Remarks Pack quantity 1 pcs. Electrical connection Connector: 1 x M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O4S500-00 — 30.01.2009 — O4S500 Through-beam sensor transmitter O4S-OOKG/US100 Connection Diagrams and graphs excess gain graph x: Abstand [mm] y: Funktionsreservefaktor ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — O4S500-00 — 30.01.2009 —
O4S500 价格&库存
很抱歉,暂时无法提供与“O4S500”相匹配的价格&库存,您可以联系我们找货
