DF51A-24DP-2DSA
DF51A-24DP-2DSA
    HRS(广濑)
    插件,P=2mm
    线对板针座 2x12P 插件 间距:2mm
DF51A-24DP-2DSA 数据手册
DF51 Series Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Mar. 2021 ④ DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Features 1. Positive lock provides clear tactile click and secures reliable connection. Lock Insertion Force Curb Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. The lock delivers a clear tactile click during peak insertion force, preventing incomplete mating. Contact Insertion Force Curb Clear click sound and tactile click when the insertion force peak is matched. Secure Mating 2. Wide variation Each of the straight/ right angle/ in- line configurations is available in single- row and dual- row for flexible design. Gold and Tin plating options support various application needs. 3. Secure Side- locking design No Extra Space Required for Release The straight type with short depth and low profile right angle type are well suited for compact/ thin equipment. Height Small size Short Depth Reduces overall system size. 2 Low Profile DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) 4. Prevents incorrect mating Visually and mechanically polarized features prevent reverse mating and incorrect mating between different number of positions. Mating Mark Secure Side-locking Design Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Incorrect Mating Prevention 5. Uses the same contacts and crimping tools as DF11 Series Wide applicable cable range: 22 to 30 AWG. 6. Suitable for potting The straight header can be potted up to 3mm. Resin 3mm Max. 7. UL, C- UL Certified Applications Office automation, Industrial machinery, Industrial robots, Amusement equipment, Medical equipment. 3 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Product Specifications Ratings Rated Current (Note 1) SingleRow Dual- Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Row Pos. 22 AWG 24 AWG 2 3A 2.5A 3-6 2A 2A 4 3A 2.5A 6-30 2A 2A Rated Voltage 26 AWG 2A 28 AWG 1A 30 AWG 0.5A Operating Temperature (Note 2) -55 to +105℃ Operating Humidity Range (Note 3) 20 to 80% Storage Temperature Range (Note 4) -10 to +60℃ Storage Humidity Range (Note 4) 40 to 70% 1.5A 250V AC/DC Rated Current (Note 1) UL, C-UL Safety Standard Approved Specification 22 AWG 24 to 28 AWG 30 AWG 2A 1A 0.5A Rated Voltage 30V AC/DC UL/C-UL File No. and Recognition No.UL, C-UL: E52653 Note Note Note Note 1 2 3 4 : : : : The rated current depends on the wire size used. Includes temperature rise due to current flow. Use without condensation on parts. The storage condition refers to long-term storage of the product on the shelf before assembly. The operating temperature and humidity are applicable after assembly when the product is not energized and during transportation. Item Specification Condition Insulation Resistance 1,000M Ω Min. Measured at 500V DC Withstand Voltage No flashover or breakdown 650V AC is applied for 1 min. Contact Resistance 30m Ω Max. Measured at 1mA (DC or 1000Hz), 20mV Max. Vibration Resistance No electrical discontinuity of 1μ s or greater Frequency 10 to 55 Hz, half amplitude 0.75mm, 10 times in each of the 3 directions Shock Resistance No electrical discontinuity of 1μ s or greater Accelerated velocity : 490 m/s2 for 11ms, half-sine wave in 3 directions, 3 times for each direction Moisture-resistance Contact resistance : 30m Ω Max. Insulation resistance : 500M Ω Min. Temperature : 40 ± 2℃ ; humidity: 90 to 95%, left as it is for 96 hours Temperature cycles Contact resistance : 30m Ω Max. Insulation resistance : 1,000M Ω Min. -55℃ :30 minutes → 105℃ : 30 minutes 5 cycles Durability Contact resistance : 30m Ω Max. Tin plated : 30 mating cycles, Gold plated: 50 mating cycles Solder heat resistance The resin parts should withstand the temperature and resist melting. Flow : 260℃ , 5 sec Hand soldering : temperature of soldering iron at 270℃ for 3 seconds Materials / Finish Product Part Material Finish Specification Insulator PBT (glass-reinforced) Black UL94V-0 Contact Brass Tin Plated or Gold Plated - Crimp Socket Insulator PBT (glass-reinforced) Black UL94V-0 Socket Contact Contact Phosphor Copper Tin Plated or Gold Plated - In-line Plug Insulator PBT (glass-reinforced) Black UL94V-0 In-line Plug Contact Contact Phosphor Copper Tin Plated or Gold Plated - Header 4 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Connector DF51 # - # P - 2 DSA ❶ ❷ ❸ ❹ ❺ ❻ Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ Crimp Contact DF11 - EP 2428 PCF A ❶ ❼ ❽ ❾  ❶ Series name DF51 ❻ Housing Type DSA : Straight Header DS : Right Angle Header C : Crimp Socket ❷ Form Type Blank : Guide-boss Type A : Without Guide-boss ❼ Contact Type EP : In-line Plug ❸ Number of Positions Single-row : 2 to 6 Dual-row : 4 to 30 ❽ Applicable Conductor 22 : 22 AWG 2428 : 24 to 28 AWG 30 : 30 AWG ❹ Connector Type P : Single-row Pin Header S : Single-row Crimp Socket DP : Dual-row Pin Header DS : Dual-row Crimp Socket EP : Single-row In-line Plug DEP : Dual-row In-line Plug ❾ Packaging Style SCF : Socket Contacts/Reel SC : Socket Contacts/Bag PCF : In-line Plug Contacts/Reel PC : In-line Plug Contacts/Bag ❺ Contact Pitch 2mm  Plating Specifications Blank : Tin Plated A : Gold Plated 5 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Diagram of Connector Mating Combinations Single-row Crimp Socket (Cable Side) DF51-#S-2C Socket Contact DF11-22SC(F)(A) Straight Header DF51A-#P-2DSA DF11-2428SC(F)(A) DF11-30SC(F)(A) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right Angle Header DF51(A)-#P-2DS In-line Plug (Cable Side) In-line Plug Contact DF51-#EP-2C DF11-EP2428PC(F)(A) Dual-row Crimp Socket (Cable Side) Socket Contact DF51-#DS-2C DF11-2428SC(F)(A) DF11-22SC(F)(A) Straight Header DF51A-#DP-2DSA DF11-30SC(F)(A) Right Angle Header DF51(A)-#DP-2DS In-line Plug (Cable Side) In-line Plug Contact DF51-#DEP-2C DF11-EP2428PC(F)(A) 6 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Single-row Straight Header A B P=2.0 1.8 CAV No. A Contact No.1 HRS Mark HRS Mark Polarity Mark No. of Pos. Indicator Lot No. 5HS1 8.4 * 3.0 □0.5 +0 0 .1 Recommended PCB Layout (t=1.6mm) 8 B±0.1 P=2.0±0.05 Φ 0. Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.25 4.4 Unit : mm Part No. HRS No. No. of Pos. A B DF51A-2P-2DSA(##) CL0543-5105-0-## 2 10.8 2.0 DF51A-3P-2DSA(##) CL0543-5106-0-## 3 12.8 4.0 DF51A-4P-2DSA(##) CL0543-5107-0-## 4 14.8 6.0 DF51A-5P-2DSA(##) CL0543-5108-0-## 5 16.8 8.0 DF51A-6P-2DSA(##) CL0543-5109-0-## 6 18.8 10.0 【Specification number】 ‐##、 (##) Blank : Tin plated (01) : Gold plated 7 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Dual-row Straight Header 2.65 P=2.0 A B Contact No.2 2.0 Cavity No. A HRS Mark Contact No.1 A Polarity Mark HRS Mark 7.3 5HS1 8.4 * Lot No. 3.0 □0.5 Recommended PCB Layout (t=1.6mm) B±0.1 P=2.0±0.05 .1 +0 0 8 0. φ 2.0±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of Pos. Indicator Unit : mm Part No. HRS No. No. of Pos. A B DF51A-4DP-2DSA(##) CL0543-5015-0-## 4 11.1 2.0 DF51A-6DP-2DSA(##) CL0543-5044-0-## 6 13.1 4.0 DF51A-8DP-2DSA(##) CL0543-5045-0-## 8 15.1 6.0 DF51A-10DP-2DSA(##) CL0543-5046-0-## 10 17.1 8.0 DF51A-12DP-2DSA(##) CL0543-5047-0-## 12 19.1 10.0 DF51A-14DP-2DSA(##) CL0543-5048-0-## 14 21.1 12.0 DF51A-16DP-2DSA(##) CL0543-5049-0-## 16 23.1 14.0 DF51A-18DP-2DSA(##) CL0543-5050-0-## 18 25.1 16.0 DF51A-20DP-2DSA(##) CL0543-5051-0-## 20 27.1 18.0 DF51A-22DP-2DSA(##) CL0543-5052-0-## 22 29.1 20.0 DF51A-24DP-2DSA(##) CL0543-5053-0-## 24 31.1 22.0 DF51A-26DP-2DSA(##) CL0543-5054-0-## 26 33.1 24.0 DF51A-28DP-2DSA(##) CL0543-5055-0-## 28 35.1 26.0 DF51A-30DP-2DSA(##) CL0543-5056-0-## 30 37.1 28.0 【Specification number】 ‐##、 (##) Blank : Tin plated (01) : Gold plated 8 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) 5HS1 Lot No. No. of Pos. Indicator 12.0 Single-row Right Angle Header * Polarity Mark HRS Mark A B P=2.0 Contact No.1 Cavity No. HRS Mark 4.5 3.0 1.9 1.6 9.45 C Above drawing is guide-boss type. Recommended PCB Layout (t=1.6mm) B±0.1 P=2.0±0.05 .1 +0 0 .8 Ø0 Ø1.7 C±0.1 2.7±0.1 +0.1 0 2.7±0.1 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A □0.5 Unit : mm Part No. HRS No. Guide-boss No. of Pos. A B C Purchase Unit DF51-2P-2DS(##) CL0543-5110-0-## With boss 2 10.8 2.0 6.0 243pcs per tray DF51-3P-2DS(##) CL0543-5111-0-## With boss 3 12.8 4.0 8.0 207pcs per tray DF51A-4P-2DS(##) CL0543-5117-0-## Without boss 4 14.8 6.0 - 171pcs per tray DF51A-5P-2DS(##) CL0543-5118-0-## Without boss 5 16.8 8.0 - 153pcs per tray DF51A-6P-2DS(##) CL0543-5119-0-## Without boss 6 18.8 10.0 - 135pcs per tray 【Specification number】 ‐##、 (##) (20) : Tin plated, tray packaging (50) : Gold plated, tray packaging 9 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Dual-row Right Angle Header 5HS1 No. of Pos. Indicator 11.9 Lot No. * Polarity Mark HRS Mark Contact No.1 P=2.0 A B 3.0 1 2.65 2 □0.5 9.45 C A 2.0 Above drawing is guide-boss type. B±0.1 P=2.0±0.05 +0.1 0 2.7±0.1 Ø1.7 .1 0 +0 .8 Ø0 2.0±0.05 Recommended PCB Layout (t=1.6mm) 2.7±0.1 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Contact No.2 7.3 HRS Mark Cavity No. C±0.1 Unit : mm Part No. HRS No. Guide-boss No. of Pos. A B C Purchase Unit DF51-4DP-2DS(##) CL0543-5016-7-## With boss 4 11.1 2.0 7.4 234pcs per tray DF51-6DP-2DS(##) CL0543-5017-0-## With boss 6 13.1 4.0 9.4 198pcs per tray DF51A-8DP-2DS(##) CL0543-5059-0-## Without boss 8 15.1 6.0 - 171pcs per tray DF51A-10DP-2DS(##) CL0543-5060-0-## Without boss 10 17.1 8.0 - 153pcs per tray DF51A-12DP-2DS(##) CL0543-5061-0-## Without boss 12 19.1 10.0 - 135pcs per tray DF51A-14DP-2DS(##) CL0543-5062-0-## Without boss 14 21.1 12.0 - 126pcs per tray DF51A-16DP-2DS(##) CL0543-5063-0-## Without boss 16 23.1 14.0 - 108pcs per tray DF51A-18DP-2DS(##) CL0543-5064-0-## Without boss 18 25.1 16.0 - 99pcs per tray DF51A-20DP-2DS(##) CL0543-5065-0-## Without boss 20 27.1 18.0 - 90pcs per tray DF51A-22DP-2DS(##) CL0543-5066-0-## Without boss 22 29.1 20.0 - 90pcs per tray DF51A-24DP-2DS(##) CL0543-5067-0-## Without boss 24 31.1 22.0 - 81pcs per tray DF51A-26DP-2DS(##) CL0543-5068-0-## Without boss 26 33.1 24.0 - 72pcs per tray DF51A-28DP-2DS(##) CL0543-5069-0-## Without boss 28 35.1 26.0 - 72pcs per tray DF51A-30DP-2DS(##) CL0543-5070-0-## Without boss 30 37.1 28.0 - 72pcs per tray 【Specification number】 ‐##、 (##) (20) : Tin plated, tray packaging (50) : Gold plated, tray packaging 10 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Single-row Crimp Socket P=2.0 A B C A HRS Mark Cavity No. 10.15 * 4.4 1 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.1 Contact No. Unit : mm Part No. HRS No. No. of Pos. A B C DF51-2S-2C CL0543-5120-0-00 2 16.2 12.6 2.0 DF51-3S-2C CL0543-5121-0-00 3 18.2 14.6 4.0 DF51-4S-2C CL0543-5122-0-00 4 20.2 16.6 6.0 DF51-5S-2C CL0543-5123-0-00 5 22.2 18.6 8.0 DF51-6S-2C CL0543-5124-0-00 6 24.2 20.6 10.0 11 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Dual-row Crimp Socket A B C P=2.0 2.0 A HRS Mark Cavity No. Contact No.1 * 10.7 1 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.2 Contact No. Unit : mm Part No. HRS No. No. of Pos. A B C DF51-4DS-2C CL0543-5030-8-00 4 15.0 11.1 2.0 DF51-6DS-2C CL0543-5031-0-00 6 17.0 13.1 4.0 DF51-8DS-2C CL0543-5032-3-00 8 19.0 15.1 6.0 DF51-10DS-2C CL0543-5033-6-00 10 21.0 17.1 8.0 DF51-12DS-2C CL0543-5034-9-00 12 23.0 19.1 10.0 DF51-14DS-2C CL0543-5035-1-00 14 25.0 21.1 12.0 DF51-16DS-2C CL0543-5036-4-00 16 27.0 23.1 14.0 DF51-18DS-2C CL0543-5037-7-00 18 29.0 25.1 16.0 DF51-20DS-2C CL0543-5038-0-00 20 31.0 27.1 18.0 DF51-22DS-2C CL0543-5039-2-00 22 33.0 29.1 20.0 DF51-24DS-2C CL0543-5040-1-00 24 35.0 31.1 22.0 DF51-26DS-2C CL0543-5041-4-00 26 37.0 33.1 24.0 DF51-28DS-2C CL0543-5042-7-00 28 39.0 35.1 26.0 DF51-30DS-2C CL0543-5043-0-00 30 41.0 37.1 28.0 12 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Single-Row In-line Plug A B C P=2.0 5.4 4.5 Cavity No. A B A D 15.15 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS Mark 1 * Contact No.1 Contact No. Unit : mm Part No. HRS No. No. of Pos. A B C D DF51-2EP-2C CL0543-5125-0-00 2 15.5 10.8 2.0 17.5 DF51-3EP-2C CL0543-5126-0-00 3 17.5 12.8 4.0 19.5 DF51-4EP-2C CL0543-5127-0-00 4 19.5 14.8 6.0 21.5 DF51-5EP-2C CL0543-5128-0-00 5 21.5 16.8 8.0 23.5 DF51-6EP-2C CL0543-5129-0-00 6 23.5 18.8 10.0 25.5 13 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Dual-row In-line Plug A B C P=2.0 Cavity No. 2.0 8.4 7.3 A B A HRS Mark 15.15 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D * 1 Contact No.1 Contact No. Unit : mm Part No. HRS No. No. of Pos. A B C D DF51-4DEP-2C CL0543-5071-0-00 4 14.4 11.1 2.0 16.4 DF51-6DEP-2C CL0543-5072-0-00 6 16.4 13.1 4.0 18.4 DF51-8DEP-2C CL0543-5073-0-00 8 18.4 15.1 6.0 20.4 DF51-10DEP-2C CL0543-5074-0-00 10 20.4 17.1 8.0 22.4 DF51-12DEP-2C CL0543-5075-0-00 12 22.4 19.1 10.0 24.4 DF51-14DEP-2C CL0543-5076-0-00 14 24.4 21.1 12.0 26.4 DF51-16DEP-2C CL0543-5077-0-00 16 26.4 23.1 14.0 28.4 DF51-18DEP-2C CL0543-5078-0-00 18 28.4 25.1 16.0 30.4 DF51-20DEP-2C CL0543-5079-0-00 20 30.4 27.1 18.0 32.4 DF51-22DEP-2C CL0543-5080-0-00 22 32.4 29.1 20.0 34.4 DF51-24DEP-2C CL0543-5081-0-00 24 34.4 31.1 22.0 36.4 DF51-26DEP-2C CL0543-5082-0-00 26 36.4 33.1 24.0 38.4 DF51-28DEP-2C CL0543-5083-0-00 28 38.4 35.1 26.0 40.4 DF51-30DEP-2C CL0543-5084-0-00 30 40.4 37.1 28.0 42.4 14 Purchase Unit 100pcs per bag DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) In-line Plug Panel Cutouts ● Single-row 4.65±0.05 1.05±0.05 5.7±0.05 4.8±0.05 A±0.05 B±0.05 C±0.05 B±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm A Part No. HRS No. No. of Pos. Panel Board Thickness (Note 1) B C 0.5 to 0.8 0.9 to 1.3 1.4 to 1.8 1.9 to 2.3 DF51-2EP-2C CL0543-5125-0-00 2 14.9 15.2 15.6 16.0 11.0 7.2 DF51-3EP-2C CL0543-5126-0-00 3 16.9 17.2 17.6 18.0 13.0 9.2 DF51-4EP-2C CL0543-5127-0-00 4 18.9 19.2 19.6 20.0 15.0 11.2 DF51-5EP-2C CL0543-5128-0-00 5 20.9 21.2 21.6 22.0 17.0 13.2 DF51-6EP-2C CL0543-5129-0-00 6 22.9 23.2 23.6 24.0 19.0 15.2 Note 1 : The A dimension of the mounting hole varies based on panel board thickness. Note 2 : Do not use a rounded surface at the panel tab portion. 15 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) ● Dual-row A±0.05 B±0.05 2.3±0.05 8.6±0.05 7.5±0.05 6.7±0.05 C±0.05 B±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm A Part No. HRS No. No. of Pos. Panel Board Thickness (Note 1) B C 0.5 to 0.8 0.9 to 1.3 1.4 to 1.8 1.9 to 2.3 DF51-4DEP-2C CL0543-5071-0-00 4 13.6 14.1 14.5 14.9 11.3 7.5 DF51-6DEP-2C CL0543-5072-0-00 6 15.6 16.1 16.5 16.9 13.3 9.5 DF51-8DEP-2C CL0543-5073-0-00 8 17.6 18.1 18.5 18.9 15.3 11.5 DF51-10DEP-2C CL0543-5074-0-00 10 19.6 20.1 20.5 20.9 17.3 13.5 DF51-12DEP-2C CL0543-5075-0-00 12 21.6 22.1 22.5 22.9 19.3 15.5 DF51-14DEP-2C CL0543-5076-0-00 14 23.6 24.1 24.5 24.9 21.3 17.5 DF51-16DEP-2C CL0543-5077-0-00 16 25.6 26.1 26.5 26.9 23.3 19.5 DF51-18DEP-2C CL0543-5078-0-00 18 27.6 28.1 28.5 28.9 25.3 21.5 DF51-20DEP-2C CL0543-5079-0-00 20 29.6 30.1 30.5 30.9 27.3 23.5 DF51-22DEP-2C CL0543-5080-0-00 22 31.6 32.1 32.5 32.9 29.3 25.5 DF51-24DEP-2C CL0543-5081-0-00 24 33.6 34.1 34.5 34.9 31.3 27.5 DF51-26DEP-2C CL0543-5082-0-00 26 35.6 36.1 36.5 36.9 33.3 29.5 DF51-28DEP-2C CL0543-5083-0-00 28 37.6 38.1 38.5 38.9 35.3 31.5 DF51-30DEP-2C CL0543-5084-0-00 30 39.6 40.1 40.5 40.9 37.3 33.5 Note 1 : The A dimension of the mounting hole varies based on panel board thickness. Note 2 : Do not use a rounded surface at the panel tab portion. 16 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Socket Contact 1.35 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.8 3.0 0.7 (9.9) 0.7 1.2 6.2 1 3.1 1.35 Part No. HRS No. Category Purchase Unit DF11-22SCF CL0543-0601-0-00 Reel Contact 10,000pcs per reel DF11-22SC CL0543-0602-2-00 Loose Contact 100pcs per bag DF11-2428SCF CL0543-0500-2-00 Reel Contact 10,000pcs per reel DF11-2428SC CL0543-0501-5-00 Loose Contact 100pcs per bag DF11A-2428SCF CL0543-0634-9-00 Reel Contact 10,000pcs per reel DF11A-2428SC CL0543-0635-1-00 Loose Contact 100pcs per bag DF11-30SCF CL0543-0605-0-00 Reel Contact 10,000pcs per reel DF11-30SC CL0543-0606-3-00 Loose Contact 100pcs per bag DF11-22SCFA(04) CL0543-0603-5-04 Reel Contact 10,000pcs per reel DF11-22SCA CL0543-0604-8-00 Loose Contact 100pcs per bag DF11-2428SCFA(04) CL0543-0550-0-04 Reel Contact 10,000pcs per reel DF11-2428SCA CL0543-0551-3-00 Loose Contact 100pcs per bag DF11-30SCFA(04) CL0543-0607-6-04 Reel Contact 10,000pcs per reel DF11-30SCA CL0543-0608-9-00 Loose Contact 100pcs per bag Note : DF11A-2428SCF/SC is the tin plated low insertion/extraction force type. ◆Applicable Wire (Tinned, Annealed Copper Wire) ● Recommended Wire   UL1061, UL1007 ( Note 2) ● Strip Length   1. 7 to 2. 3mm Wire Size (Stranded Wire Conductor) 22 AWG(17/0.16) Jacket Diameter φ 1.2-1.45mm 24 AWG(11/0.16) 26 AWG(7/0.16) φ 0.9-1.45mm 28 AWG(7/0.127) 30 AWG(7/0.1) φ 0.75-1.2mm Note 1 : Contact your Hirose representative when using a cable other than those specified. Note 2 : DF11-22SCF/SC/SCFA/SCA is for UL1061. 17 Finish Tin Plated Gold Plated DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) In-line Plug Contact 0.9 1.3 14.1 0.9 0.7 3.0 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.7 0.5 10.4 1.58 Part No. HRS No. Category Purchase Unit DF11-EP2428PCF CL0543-0615-4-00 Reel Contact 10,000pcs per reel DF11-EP2428PC CL0543-0616-7-00 Loose Contact 100pcs per bag DF11-EP2428PCFA CL0543-0617-0-00 Reel Contact 10,000pcs per reel DF11-EP2428PCA CL0543-0618-2-00 Loose Contact 100pcs per bag ◆Applicable Wire (Tinned, Annealed Copper Wire) ● Recommended Wire   UL1061, UL1007 ● Strip Length   1. 9 to 2. 3mm Wire Size (Stranded Wire Conductor) Jacket Diameter 24 AWG(11/0.16) 26 AWG(7/0.16) φ 0.9-1.45mm 28 AWG(7/0.127) Note : Contact your Hirose representative when using a cable other than those specified. 18 Finish Tin Plated Gold Plated DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Applicable Crimping Tool Type Applicator Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Press Unit Hand Tool Contact Extraction Tool Note Note Note Note Note 1 2 3 4 5 : : : : : Part No. HRS No. Wire Type AP105-DF11-22S CL0901-4529-7-00 UL1061 (Note 3, 5) DF11-22SCF/SCFA(04) AP105-DF11-2428S CL0901-4511-1-00 UL1007 (Note 3) UL1061 (Note 3) DF11-2428SCF/SCFA(04) DF11A-2428SCF AP105-DF11-30S CL0901-4532-1-00 UL1007 (Note 3) UL1061 (Note 3) DF11-30SCF/SCFA(04) AP105-DF11-EP2428P CL0901-4528-4-00 UL1007 (Note 3) UL1061 (Note 3) DF11-EP2428PCF/PCFA CM-105C CL0901-0001-0-00 HT801/DF11-22S(A) CL0550-0407-5-00 UL1061 (Note 4, 5) DF11-22SC/SCA HT801/DF11-2428S(A) CL0550-0403-4-00 UL1007 (Note 4) UL1061 (Note 4) DF11-2428SC/SCA DF11A-2428SC HT801/DF11-30S(A) CL0550-0408-8-00 UL1007 (Note 4) UL1061 (Note 4) DF11-30SC/SCA HT801/DF11-EP2428P(A) CL0550-0409-0-00 UL1007 (Note 4) UL1061 (Note 4) DF11-EP2428PC/PCA DF-C-PO(B) CL0550-0179-2-00 - - Please conduct crimping based on the "Crimp Quality Standard" and "Crimp Condition" table. Any problems that occur from using tools other than those specified by Hirose are not covered by warranty. Applicator dies can be switched to crimp other wire sizes and types. The additional dies are sold separately. Hand tool dies cannot be switched. The compatible wire is limited to UL1061, 22 AWG 19 Applicable Contacts DF11-####SCF DF11-EP####PCF DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Mated Dimensions ●Wire-to-Board Connection (Straight Header) 【Dual-row】 【Single-row】 ( 7.3 ) (5.25) DF51-#S-2C DF51A-#DP-2DSA ●Wire-to-Board Connection (Right Angle Header) 【Single-row】 【Dual-row】 (14.75) (14.8) DF51A-#DP-2DS (7.3) (4.5) DF51-#S-2C DF51-#DS-2C DF51A-#P-2DS ●Wire-to-Wire Connection 【Single-row】 【Dual-row】 (18.05) (17.9) (3.4) (8.4) (3.4) (5.4) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF51A-#P-2DSA (11.3) (11.15) DF51-#DS-2C DF51-#DS-2C DF51-#S-2C DF51-#DEP-2C DF51-#EP-2C 20 DF51 Series/2mm Pitch, Positive Lock, Wire-to-Board Connector (UL, C-UL Standard Certified Product) Precautions for Use 1. The connector could be damaged if it is pulled out forcibly. When it is hard to pull out, push it in slightly first and then depress the lock and un- mate. Please refer to the " DF51 Series Mating/ Unmating Operation Instruction Manual" ( ETAD- H0847- 00) for handling precautions during mating. 2. When inserting a crimped contact into a socket, please refrain from inserting at a diagonal as doing so may affect performance reliability. Refer to the " DF51 Series Cable Assembly Procedure" ( ETAD- H0923- 00) for precautions during cable assembly. Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Environment Please contact us if you are designing this connector into environmental conditions where high and low temperatures are repeated. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com https://www.hirose-connectors.com ※ The contents of this catalog are current as of date of 3/ 2021. Contents are subject to change without notice for the purpose of improvements. 21
DF51A-24DP-2DSA 价格&库存
很抱歉,暂时无法提供与“DF51A-24DP-2DSA”相匹配的价格&库存,您可以联系我们找货
DF51A-24DP-2DSA
    DF51A-24DP-2DSA
      • 1+7.44120
      • 10+6.21000
      • 30+5.54040
      • 100+4.78440
      • 500+4.43880
      • 1000+4.28760
