NPRN214EFCN-RC
NPRN214EFCN-RC
    SULLINS
    CONN HDR 84POS 0.079 GOLD PCB
NPRN214EFCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY D 2515 ADD "REF." IN CONTACT POINT DIST, ADD NOTE 10 MATING PART 01/16/2012 LH E 3120 UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL 04/15/2015 LH F F E E .079 2.00 A±.004 [ .10] .079 2.00 .079 2.00 .236 6.00 D D .079 2.00 B±.012 [ 0.30] RECOMMENDED PCB LAYOUT .031 0.80 .315 8.00 .072 1.82 C C .189 4.80 .250 6.35 .094±.008 2.40±0.20 .079±.002 2.00±0.05 B A±.008 [ 0.20] .020±.002 0.50±0.05 .020±.002 0.50±0.05 B .079±.004 2.00±0.10 .236 6.00 A 05-20, 0.20mm MAX. NOTES: 21-30, 0.30mm MAX. 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 2 AMPS 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 10.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES. (.020 [0.50] SQUARE POSTS) 8 7 6 5 Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 5 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 01/10/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, FEMALE 2mm CC, 4 ROWS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 12:1 3 2 NPxNxx4EFCN-RC DWG. NO. 10665 SHEET 1 OF 1 1 REV E FILE NAME: 10665, NPxNxx4EFCN-RC A
NPRN214EFCN-RC
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一种光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有较高的输入输出隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:包括最大正向电流100mA,最大反向电压5V,最小正向电压1.0V等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于各种需要电气隔离的场合。
6. 应用信息:广泛应用于通信设备、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
NPRN214EFCN-RC 价格&库存
很抱歉,暂时无法提供与“NPRN214EFCN-RC”相匹配的价格&库存,您可以联系我们找货
