8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
E
2515
F
2829
DESCRIPTION
DATE
UPDATE CONTACT POINT DIST TO REF, ADD NOTE 01/16/2012
11 MATING PARTS
ADD INSULATOR MATERIAL 'LCP' AND 'C' PLATING 12/10/2014
OPTIONS, UPDATE OPERATING TEMPERATURE
BY
LH
LH/JHSU
F
F
A±.004 [ .10]
.035±.002 0.90±0.05
.079±.002 2.00±0.05
PIN 1
.205±.004 5.20±0.10
E
E
.079±.002 2.00±0.05
RECOMMENDED PCB LAYOUT - FOR PN: xPxNxx1BFLD-RC
A±.004 [ .10]
.094 2.40
.035±.002 0.90±0.05
PIN 1
D
.079±.002 2.00±0.05
xPxNxx1BFLD-RC
PIN 1
D
PIN 1
.205±.004 5.20±0.10
.079±.002 2.00±0.05
.094 2.40
RECOMMENDED PCB LAYOUT - FOR PN: xPxNxx1BFLC-RC
xPxNxx1BFLC-RC
B±.014[ 0.35]
C
C
.098 2.50
.173 4.40
.181±.010 4.60±0.25
.006[0.15]
.020 0.50
.008 0.20
.079±.002 2.00±0.05
.157±.012 4.00±0.30
A±.008 [ 0.20]
B
B
02-20, 0.20mm MAX.
21-40, 0.30mm MAX.
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: PHOSPHOR BRONZE
3. CONTACT PLATING: SEE PART NUMBER CODING
4. CURRENT RATING: 2 AMPS
5. VOLTAGE RAATING: 150 V AC/DC
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX
8. DIELECTRIC WITHSTANDING: 500 VAC
9. OPERATING TEMPERATURE: SEE PART NUMBER CODING
10. PROCESSING TEMP. : SEE PART NUMBER CODING
11. FOR ODD NUMBER POSITIONS, MOUNTING STYLES CAN BE EITHER 'C' OR 'D'
12. MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES
(.020 [0.50] SQUARE POSTS)
8
7
6
5
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
5
DECIMALS
.X= .012 [.3]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
01/10/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, FEMALE, 2mm CC, 1 ROW, SMT
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 12:1
3
2
xPxNxx1BFLx-RC
DWG. NO.
10489
SHEET 1 OF 1
1
REV
F
FILE NAME: 10489, xPxNxx1BFLx-RC
A
很抱歉,暂时无法提供与“NPPN091BFLC-RC”相匹配的价格&库存,您可以联系我们找货
