8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
647
INITIAL RELEASE
6/14/2005
TT
B
707
UPDATE DIMENSIONS
8/18/2005
TT
C
767
10/13/2005
TT
D
1869
ADD .20mm TO B DIMS
ADD PCB LAYOUT D STYLE, UPDATE POSITION
CHART FORMAT
12/04/2008
JH
A
0.100 2.54
F
0.039 1.00
E
E
PIN 1
0.209 5.30
0.079 2.00
D MOUNTING STYLE
RECOMMENDED PCB LAYOUT
D MOUNTING STYLE
B±0.016 [ 0.40]
D
D
A
A±0.008 [ 0.20]
0.039 1.00
0.100 2.54
0.079 2.00
C MOUNTING STYLE
0.209 5.30
PIN 1
0.098±0.004 2.50±0.10
0.280±0.006 7.10±0.15
C
C
C MOUNTING STYLE
0.295±0.010 7.50±0.25
0.024(w) X 0.010(t) [0.60 X 0.25]
B
B
0.169±0.012 4.30±0.30
0.100±0.004 2.54±0.10
A
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0.
02-20, 0.20mm MAX.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
21-40, 0.30mm MAX.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +125° C.
9. *MAX PROCESSING TEMP.: 230° C FOR 30 - 60 SECONDS
(260° C FOR 10 SECONDS).
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
7
6
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN INCHES[MM]
TOLERANCES:
ANGULAR: 5
.XX= .014 [.35]
.XXX= .008 [.20]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DRAWN
NAME
12/4/2008
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
HEADER FEMALE,
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
2.54mm CC, 1 ROW, SMT
NPxCxx1KFXx-RC
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
10487
SCALE: 4:1
2
D
SHEET 1 OF 1
1
FILE NAME: Z:\COMPONENTS\Taiwan\10487, NPxCxx1KFXx-RC PRINT: 2/2/2009
A
很抱歉,暂时无法提供与“NPPC021KFXC-RC”相匹配的价格&库存,您可以联系我们找货
