8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
E
2515
F
3120
H
3563
DESCRIPTION
DATE
REMOVE CONTACT DEPTH TOLERANCE & ADD "REF.", ADD 01/16/2012
NOTE 10 MATING PARTS.
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL AND CURRENT RATING TO 2 AMPS (WAS 1 AMP), 04/15/2015
ADD VIEW FOR POSITIONS 27 TO 40
ADD LCP MATERIAL OPTION, UPDATE WARPING, TAIL LENGTH
AND ROW SPACING OF TOLERANCES AND UPDATE VIEW FOR 11/22/2016
25 TO 40 POSITIONS AND UPDATE DIM 'B' ON DIMENSION
TABLE(ADD 0.1mm TO OVERALL BODY LENGTH)
F
BY
LH
LH
F
LH
E
E
B±.014 [ 0.35]
FOR POSITIONS 25 TO 40
.079±.002 2.00±0.05
.157 4.00
D
D
.057 1.45
.169 4.30
.094±.010 2.40±0.25
.020±.002 0.50±0.05
.079±.002 2.00±0.05
C
C
.008±.002 0.20±0.05
.079±.008 2.00±0.20
A±.008 [ 0.20]
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
A±.004 [ .10]
.079±.002 2.00±0.05
.031±.002 0.80±0.05
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, COLOR: BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS.
5. VOLTAGE RATING: 150 V AC/DC.
6. INSULATOR RESISTANCE: 5,000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500 VAC.
9. OPERATING TEMPERATURE: SEE PART NUMBER CODING
10.PROCESSING TEMP.: SEE PART NUMBER CODING
11.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES.
(.020 [0.50] SQUARE POSTS)
.079±.002 2.00±0.05
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
8
7
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
01/10/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, FEMALE 2mm CC, 2 ROWS, ST
_PPN_ _2AFCN-RC
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
2
DWG. NO.
10497
SHEET 1 OF 1
1
REV
H
FILE NAME: 10497, _PPN_ _2AFCN-RC
A
很抱歉,暂时无法提供与“NPPN172AFCN-RC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.753491+2.27828
- 17+14.5137017+1.86252
- 102+12.78939102+1.64124
- 510+11.41546510+1.46493
- 1003+10.883711003+1.39669
- 5015+10.439165015+1.33964
