General Accessories
Connector Plug Terminals
Type CONB14NF-A/S
• Straight or 90° connectors
• M12 version
• 4 wire
• IP 67
• UL approved
CONB14NF-A
CONB14NF-S
Product Description
Ordering Key
M12 connector plug terminals for 4 wires. High quality
CONB
1 = M12 DC
4 = 4 wire (BN, BU, BK, WH)
N= Not shielded
F= Female
A = Angled
S = Straight
and approved by UL. Come
instraight or angled versions.
Type Selection
CONB14NF-A/S
Plug type
Ordering number
4-Wire Angled
4-Wire Straight
CONB14NF-A
CONB14NF-S
Specifications
Rated operating voltage
Rated current
Contact resistance
Rated impulse voltage
Insulation resistance
Cable outlet diameter
Connection wires
Contact Material
Contact plating
Contact bearer material
250VAC/DC
≤4A
≤5mΩ
2.0KV
>109Ω
3.6 to 5mm
max 0.75mm2
CuZn
CuSnZn, pre-coppered
PBT, black
Specifications are subject to change without notice (12.04.2016)
Moulded body material
O-ring sealing
Coupling nut
Cup nut
Knurled but
Degree of protection
Pollution Degree
Temperature
Weight
PBT, black
FKM
PBT, black
PBT, black
CuZn, nickel plated
IP67
3
-25° to 90°C
approx 25g
1
CONB1...
Dimensions
Straight version
Angled version
35
Ø 20
52.5
Ø 20
27.5
Contact layout
(4-wire)
Female
3
4
2
1
Derating curve (DIN EN 60512-5-2)
6
Current [A]
5
4
3
2
1
10
40
50
Temperature [ºC]
60
70
80
90
100
很抱歉,暂时无法提供与“CONB14NF-A”相匹配的价格&库存,您可以联系我们找货
