FGG.2B.308.CLAD62Z
FGG.2B.308.CLAD62Z
    LEMO(雷莫)
    FGG.2B.308.CLAD62Z
FGG.2B.308.CLAD62Z 数据手册
FGG.2B.308.CLAD62Z www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Catalog Cable Ø 5.30 - 6.20 mm See video assembly instructions Status active Matching parts EGG.2B.308.CLL Download Request a quote Eplan PHG.2B.308.CLLD62Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 29.27 g Performance Configuration 2B.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 1500 V (AC), 2120 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 49 37 13 12 in. 0,59 1,93 1,46 0,51 0,47 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG Cables CMN.08.T22.059QGC TPR Grey CMN.08.T22.059QGZE TPR (medical) Grey 16080 PVC Grey 180240 PVC Black 180260 PVC Black 335991 PVC Black 42265 PVC Yellow 80140 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.308.CLAD62Z
物料型号:FGG.2B.308.CLAD62Z
器件简介: - 系列:2B - 端接类型:焊接式公头 - IP等级:50 - 线规:30.00 - 22.00 AWG - 电缆直径:5.30 - 6.20 mm - 状态:活跃 - 匹配零件:EGG.2B.308.CLL 和 PHG.2B.308.CLLD62Z
引脚分配: - 配置:2B.308:8个低压引脚
参数特性: - 绝缘材料:PEEK (UL 94 / V-0/1.5) - 额定电流:10安培 - 接触类型:焊接 - 接触直径:0.9毫米 (0.035英寸) - 桶直径:0.8毫米 (0.031英寸) - 最大实心导体:0.34 mm² (AWG 22) - 最大绞合导体:0.34 mm² (AWG 22) - 最大电阻:4.8毫欧姆 - 接触-外壳电压测试:1250伏交流,1770伏直流 - 接触-接触电压测试:1500伏交流,2120伏直流
功能详解: - 寿命:5000次 - 温度范围:-55°C 至 +250°C - 湿度:最高95%(在60°C/140°F时) - 振动:15g [10 Hz - 2000 Hz] - 冲击抵抗力:100g [6 ms] - 气候类别:50/175/21 - 屏蔽最小值:75分贝 (10 MHz) 和 40分贝 (1 GHz) - 盐雾腐蚀:超过1000小时
应用信息: - 推荐工具:DCD.2B.025.PA120 扳手 - 推荐盖:BFG.2B.100.PCSG - 推荐电缆: - CMN.08.T22.059QGC:TPR,灰色 - CMN.08.T22.059QGZE:医用TPR,灰色 - 16080:PVC,灰色 - 180240:PVC,黑色 - 180260:PVC,黑色 - 335991:PVC,黑色 - 42265:PVC,黄色 - 80140:PVC,灰色
封装信息: - 壳体风格/型号:FG:直插头,线缆套环和螺母用于安装弯曲释放 - 键位:1个键(alpha=0,插头:公接触,插座:母接触) - 外壳材料:黄铜(镀硬铬 [SAE AMS 2460])外壳和套环螺母,镀镍 [SAE AMS QQ N 290] 黄铜锁套和中间件 - 变体:Z:用于安装弯曲释放的螺母 - 重量:29.27克
FGG.2B.308.CLAD62Z 价格&库存
很抱歉,暂时无法提供与“FGG.2B.308.CLAD62Z”相匹配的价格&库存,您可以联系我们找货
FGG.2B.308.CLAD62Z
  • 1+678.018411+87.76242
  • 10+576.3076310+74.59702
  • 30+533.3521130+69.03687
  • 50+514.4898650+66.59535
  • 100+489.96582100+63.42097
库存:44
