MIL-DTL-83723 Series III
Features and Application
Bayonet and Threaded Coupling
Shell Polarization – Alternate key/keyway positions prevent cross mating of adjacent connectors having same insert
arrangement.
MIL-DTL-83723 Series III family offers connectors with
bayonet and threaded coupling including lanyard-release
quick-disconnects. These connectors combine the best features
of MIL-DTL-26500 and NAS 1599 miniature connector
specifications. They are intermateable with both bayonet and
threaded 26500 connectors (exception: shell size 8, threaded
coupling only) and have the added advantage provided by the
rear-release contact retention system.
Closed-Entry Socket Insert – Hard dielectric socket face has
lead-in chamfers for positive alignment of pins (even partially
bent within pre-established limits) with sockets.
Interfacial Pin Insert Seal – Raised moisture barriers around
each pin, which mate into lead-in chamfers of hard face socket insert, provide individual contact sealing. Interfacial seal is
never touched by service tools.
AE833 connectors are widely used on commercial, military
and aerospace systems requiring general-purpose, miniature
cylindrical bayonet or threaded coupling connectors. In
addition, Series III threaded connectors with self-locking
plugs are well suited for engine applications.
Elastomer Wire Sealing Grommet – Sealing over a wide
range of wire diameters is assured by a triple wire seal in each
cavity at the rear of the connector.
This family of connectors (bayonet as well as threaded) is
offered in wall mount receptacles as well as jam nut mounted
receptacles which incorporate “O” ring seals, designed for
rear panel “D” hole mounting.
Superior Contact Stability – Rear release crimp contact
system features a stamped beryllium-copper retaining clip
captivated by molded-in shoulders of each contact cavity in
the insulator. A rear-inserted M81969 plastic tool expands the
tines beyond the shoulder, releasing the contact.
Series III bayonet-coupling plugs are available in two designs
- with and without RFI grounding. Threaded coupling plugs
are offered with and without RFI grounding, self-locking
and RFI/self-locking. In addition we offer quick-disconnect
(lanyard release) plugs, which mate with threaded receptacles
via an adapter.
83723 S III
Thirty-one insert arrangements per MIL-STD-1554 are tooled
and qualified to MIL-DTL-83723 Series III, utilizing
2 to 61 M39029 contacts. Contacts come in sizes 20, 16 and
12, terminating wire sizes from 24 to 12 gauge.
These connectors are available in wide range of shell materials
and finishes. Aluminum shells are offered in electroless nickel,
olive drab cadmium and black anodic. Other finishes such as
zinc cobalt are available upon request to commercial callouts
only. In addition, we offer passivated stainless steel shells
with both standard and firewall-rated inserts, and for highly
corrosive environments, nickel-aluminum-bronze shells
with standard environment-resisting inserts (commercial
callouts only).
Universal I/R Tool – A single, expendable plastic tool is used
for both insertion and removal of contacts.
www.conesys.com
– 127 –
sales@aero-electric.com
Performance Specifications
Durability
Mated connectors withstand a minimum of 500 mating
cycles for bayonet coupling straight plug (M83723/75,
76); 250 mating cycles for bayonet coupling RFI plug
(M83723/77, 78); and 250 cycles for all threaded coupling
plugs (M83723/86, 87, 91, 92, 95, 96, 97, 98).
Operating Temperature Range
Classes A and R: -65°C to +200°C (-85°F to +392°F)
Class W: -65°C to +175°C (-85°F to +347°F)
Classes G and K: -65°C to +200°C (-85°F to +392°F)
Classes N and S: -65°C to +200°C (-85°F to +392°F)
Shock and Vibration Requirements
Wired, mated connectors shall not be damaged, coupling
ring shall not loosen, and there shall be no interruption of
electrical continuity longer than one microsecond when
subjected to the following:
Material and Finish Data (Class)
A – aluminum shell, black anodized finish
G – stainless steel shell, passivated
K – stainless steel shell, passivated, firewall
R – aluminum shell, electroless nickel finish
S – stainless steel shell, passivated, firewall, and 360° teeth
W– aluminum shell, olive drab cadmium over nickel base
N – stainless steel shell, electrodeposited nickel, firewall, and
360° teeth
Shock
Mated connectors withstand a pulse of approximate half
sine wave of 300 G ± 15 percent magnitude with duration of
3 ± 1 milliseconds applied in three axes.
Vibration
Mated connectors withstand the following vibration levels:
• Random vibration per MIL-STD-1344, method 2005, test
condition VI, letter J.
Corrosion Resistance
Class W withstands 500-hour salt spray.
Class R withstands 48-hour salt spray.
Environmental Seal
Wired, mated connectors with specified accessories attached, shall meet the altitude-immersion test specified by
MIL-DTL-83723 Series III.
Shielding Effectiveness
RFI attenuation at the specified frequency meets the requirements of MIL-DTL-83723 Series III.
• RFI shielding effectiveness of mated connectors with
RFI backshells is measured in a triaxial radio frequency
leakage fixture.
Shell-to-Shell Conductivity (Except class A)
• With RFI spring fingers, the maximum potential drop
shall not exceed 5 millivolts.
• Without spring fingers, the maximum potential drop
shall not exceed 200 millivolts.
Voltage Rating
Service
Rating
Suggested Operating Voltage*
Test Voltage
Test Voltage
Test Voltage
Test Voltage
(Sea Level)
Sea Level
50,000 Ft.
70,000 Ft.
110,000 Ft.
V RMS
V RMS
V RMS
V RMS
AC (RMS)
DC
I
600
850
1500
500
375
200
II
900
1250
2300
750
500
200
* To be used by designer only as a guide.
www.conesys.com
– 128 –
83723 S III
Fluid Resistance
Connectors resist specified immersions in MIL-PRF-7808
(lubricating oil), MIL-PRF-23699 (lubricating oil),
MIL-PRF-5606 (hydraulic fluid), M2-V Chevron oil, Coolanol 25, MIL-DTL-83133 (turbine fuel JP-8),
MIL-DTL-5624 (turbine fuels JP-4 and JP-5), SAE-AMS1424
Type I (defrosting fluid), and other solvents and cleaning
agents.
Part Number Development
Bayonet Coupling
Military and Aero-Electric Part Number Development
Mil. Prefix
Aero Prefix
M83723/
AE833
71
71
R
R
12
12
12
12
N
N
-340
Shell type
71 = Wall mount receptacle with socket contacts
72 = Wall mount receptacle with pin contacts
73 = Jam nut receptacle with socket contacts
74 = Jam nut receptacle with pin contacts
75 = Straight plug with socket contacts
76 = Straight plug with pin contacts
77 = RFI grounding plug with socket contacts
78 = RFI grounding plug with pin contacts
Class (Material and Finish)
A = Aluminum shell, black anodized finish (not available in 77 and 78 RFI plugs)
G = Stainless stell shell, passivated
R = Aluminum shell, electroless nickel finish
W = Aluminum shell, olive drab cadmium over electroless nickel finish
Shell Size (SS)
8, 10, 12, 14, 16, 18, 20, 22 or 24
Insert Arrangement
See pages 148 and 149
Polarization (Keying)
N = Normal
6, 7, 8, 9 or Y (Alternate keyed positions, Y is not availabe in SS 8)
1, 2, 3, 4 or 5 (Clocked insert polarizations within normally keyed shell, not approved for new design, n/a in SS 8)
Modification (applies to Aero part numbers only)
01 = Less contacts (Part is bagged and tagged, but not marked with 01)
340 = Connector kitted with M85049/31-XXX E-nut
83723 S III
341 = Connector kitted with M85049/52-1-XXX straight clamp
342 = Connector kitted with M85049/51-1-XXX right angle clamp
Consult factory for other modifications
Note 1: Each connector is furnished with contacts unless
ordered less contacts (L/C) as follows: One spare contact for
inserts requiring 2 to 26 of each contact and two spares for
inserts with 27 or more of each size, and a minimum of one
sealing plug up to 15% of the number of contacts of each
size. In addition, one insertion/removal tool of each size is
included.
www.conesys.com
Note 2: Proper part number marking has no “0” in front of
single digit shell size (8), but it does include the “0” in front
of single digit layout. Examples: M83723/72W803N and
M83723/77G10056. Please note that in this series “N” for
normal is included in part number marking.
– 129 –
M83723/71, 72
Wall Mounting Receptacle
AE83371, 72
Bayonet Coupling, Crimp Removable, Rear Release
1.300(33.02)
MAX
A
.728(18.49)
.708(17.98)
B
.072(1.83)
.052(1.32)
.290(7.37) MIN FULL THREAD
3x BAYONET PINS
EQUALLY SPACED
MASTER
KEYWAY
.190(4.83) GROMMET
.130(3.30) EXTENSION
3 ACCESSORY TEETH
EQUALLY SPACED
D
F
MAX
GROMMET
E
4x MINOR KEYS
4x C
ACCESSORY THREAD
BLUE COLOR BANDS
MOUNTING
HOLES
Page 129
Completed Part Number
Page 145
Contacts, Sealing Plugs and Tools
Pages 148,149 Insert Arrangements
Page 128
Page 147
Insert Availability and Contact Information
Page 143 Polarization
A
±.005
±.13
inch
mm
ØC
(TP)
inch
mm
ØD
E
±.005
±.13
+.000
-.005
+.00
-.13
inch
mm
inch
mm
Accessory Thread
Class 2A
ØF
Maximum
inch
mm
8
.812
20.62
.594
15.09
.120
3.05
.536
13.61
1/2-20UNF
.305
7.75
10
.937
23.80
.719
18.26
.120
3.05
.659
16.74
5/8-24UNEF
.405
10.29
12
1.031
26.19
.812
20.62
.120
3.05
.829
21.06
3/4-20UNEF
.531
13.49
14
1.125
28.58
.906
23.01
.120
3.05
.898
22.81
7/8-20UNEF
.665
16.89
16
1.250
31.75
.969
24.61
.120
3.05
1.025
26.04
1-20UNEF
.790
20.07
18
1.343
34.11
1.062
26.97
.120
3.05
1.131
28.73
1-1/16-18UNEF
.869
22.07
36.50
1.156
29.36
.120
3.05
1.256
31.90
1-3/16-18UNEF
.994
25.25
22
1.562
39.67
1.250
31.75
.120
3.05
1.381
35.08
1-5/16-18UNEF
1.119
28.42
24
1.703
43.26
1.375
34.93
.149
3.78
1.506
38.25
1-7/16-18UNEF
1.244
31.60
www.conesys.com
– 130 –
83723 S III
Shell
Size
B
M83723/73, 74
Jam Nut Receptacle
AE83373, 74
A
MAX
1.300(33.02)
MAX
.190(4.83) GROMMET
E
MOUNTING FLAT
.781(19.84)
.761(19.33)
MASTER
KEYWAY
"O" RING
3 ACCESSORY TEETH
EQUALLY SPACED
C
D
MAX
GROMMET
F JAM NUT
G ACCESSORY THREAD
B
THREAD
MAX
4x MINOR KEYWAYS
HEX NUT
PER MS3186
BLUE COLOR BAND
BLUE COLOR BAND
PANEL THICKNESS:
.125(3.18)
.062(1.58)
Page 129
Page 145
Page 128
Page 147
83723 S III
Shell
Size
A
ØB
ØC
Maximum
Maximum
Maximum
inch
mm
inch
mm
inch
ØD
E
+.000
-.005
+.00
-.13
±.003
±.08
mm
inch
mm
inch
mm
F
G
Jam Nut Thread
Class 2A
Accessory Thread
Class 2A
8
.979
24.87
1.068
27.13
.305
7.75
.536
13.61
.593
15.06
5/8-20UN
1/2-20UNF
10
1.104
28.04
1.192
30.28
.405
10.29
.659
16.74
.718
18.24
3/4-20UNEF
5/8-24UNEF
12
1.291
32.79
1.380
35.05
.531
13.49
.829
21.06
.905
22.99
15/16-20UNEF
3/4-20UNEF
14
1.391
35.33
1.505
38.23
.665
16.89
.898
22.81
.968
24.59
1-20UNEF
7/8-20UNEF
16
1.516
38.51
1.630
41.40
.790
20.07
1.025
26.04
1.093
27.76
1-1/8-20UN
1-20UNEF
18
1.641
41.68
1.756
44.60
.869
22.07
1.131
28.73
1.217
30.91
1-1/4-18UNEF
1-1/16-18UNEF
44.86
1.860
47.24
.994
25.25
1.256
31.90
1.342
34.09
1-3/8-18UNEF
1-3/16-18UNEF
22
1.954
49.63
2.086
52.98
1.119
28.42
1.381
35.08
1.467
37.26
1-1/2-18UNEF
1-5/16-18UNEF
24
2.079
52.81
2.160
54.86
1.244
31.60
1.506
38.25
1.592
40.44
1-5/8-18UNEF
1-7/16-18UNEF
www.conesys.com
– 131 –
M83723/75, 76
Straight Plug
AE83375, 76
1.230(31.24)
MAX
F
3x BAYONET HOLES
EQUALLY SPACED
MAX
COUPLING
NUT
.190(4.83) GROMMET
MASTER KEY
3 ACCESSORY TEETH
EQUALLY SPACED
E
G
MAX
GROMMET
4 MINOR KEYS
H ACCESSORY THREAD
BLUE COLOR BAND
Page 129
Page 145
Page 128
Page 147
inch
ØF
ØG
Maximum
Maximum
H
+.005
-.004
+.13
-.10
mm
inch
mm
inch
mm
Accessory Thread
Class 2A
8
.305
7.75
.776
19.71
.419
10.64
1/2-20UNF
10
.405
10.29
.906
23.01
.521
13.23
5/8-24UNEF
12
.531
13.49
1.078
27.38
.691
17.55
3/4-20UNEF
14
.665
16.89
1.141
28.98
.760
19.30
7/8-20UNEF
16
.790
20.07
1.266
32.16
.887
22.53
1-20UNEF
18
.869
22.07
1.375
34.93
.993
25.22
1-1/16-18UNEF
25.25
1.510
38.35
1.118
28.40
1-3/16-18UNEF
22
1.119
28.42
1.625
41.28
1.243
31.57
1-5/16-18UNEF
24
1.244
31.60
1.760
44.70
1.368
34.75
1-7/16-18UNEF
www.conesys.com
– 132 –
83723 S III
Shell
Size
ØE
M83723/77, 78
RFI Grounding Plug
AE83377, 78
1.230(31.24)
MAX
F
3x BAYONET HOLES
EQUALLY SPACED
MAX
COUPLING
NUT
MASTER KEY
.190(4.83) GROMMET
R.F.I SPRING
3 ACCESSORY TEETH
EQUALLY SPACED
E
G
MAX
GROMMET
4 MINOR KEYS
H ACCESSORY THREAD
BLUE COLOR BAND
Page 129
Page 145
Page 128
Page 147
83723 S III
Shell
Size
inch
ØE
ØF
Maximum
Maximum
mm
inch
ØG
mm
H
+.005
-.004
+.13
-.10
inch
mm
Accessory Thread
Class 2A
8
.305
7.75
.776
19.71
.419
10.64
1/2-20UNF
10
.405
10.29
.906
23.01
.521
13.23
5/8-24UNEF
12
.531
13.49
1.078
27.38
.691
17.55
3/4-20UNEF
14
.665
16.89
1.141
28.98
.760
19.30
7/8-20UNEF
16
.790
20.07
1.266
32.16
.887
22.53
1-20UNEF
18
.869
22.07
1.375
34.93
.993
25.22
1-1/16-18UNEF
25.25
1.510
38.35
1.118
28.40
1-3/16-18UNEF
22
1.119
28.42
1.625
41.28
1.243
31.57
1-5/16-18UNEF
24
1.244
31.60
1.760
44.70
1.368
34.75
1-7/16-18UNEF
www.conesys.com
– 133 –
Threaded Coupling
Mil. Prefix
Aero Prefix
M83723/
AE833
95
95
R
R
12
12
12
12
N
N
-340
Shell type
82 = Wall mount receptacle with socket contacts
83 = Wall mount receptacle with pin contacts
84 = Jam nut receptacle with socket contacts
85 = Jam nut receptacle with pin contacts
86 = Straight plug with socket contacts
87 = Straight plug with pin contacts
91 = RFI grounding plug with socket contacts
92 = RFI grounding plug with pin contacts
95 = Self-locking plug with socket contacts
96 = Self-locking plug with pin contacts
97 = Self-locking, RFI grounding plug with socket contacts
98 = Self-locking, RFI grounding plug with pin contacts
68 = Lanyard release, quick-disconnect plug, pin (not available in K & S classes)
69 = Lanyard release, quick-disconnect plug, socket (not available in K & S classes)
A = Aluminum shell, black anodized finish (Not available in 91, 92, 97 & 98 RFI plugs)
G = Stainless steel shell, passivated (n/a in 97 & 98)
K = Stainless steel shell, passivated, with firewall rated insert (n/a in 91, 92, 97 & 98)
R = Aluminum shell, electroless nickel finish (n/a in 97 & 98 to mil number)
W = Aluminum shell, olive drab cadmium over nickel base (n/a in 97 & 98 to mil number)
S = Stainless steel shell, passivated, full teeth, firewall insert (n/a in 86, 87, 91, 92, 95 & 96)
Shell Size (SS)
8, 10, 12, 14, 16, 18, 20, 22 or 24 (and shell size 28 available in Aero p/n only)
Insert Arrangement
N = Normal
for inserts requiring 2 to 26 of each contact and two spares
for inserts with 27 or more of each size, and a minimum
of one sealing plug up to 15% of the number of contacts
of each size. In addition, one insertion/removal tool of
each size is included.
www.conesys.com
83723 S III
of single digit shell size (8), but it does include the “0” in
front of single digit layout. Examples: M83723/95G803N
and M83723/98S10056. Please note that in this series “N”
for normal is included in part number marking.
Note 3: Shell type M83723/70 (AE83370 Receptacle Adapter)
is not listed above,
– 134 –
M83723/82, 83
AE83382, 83
Threaded Coupling, Crimp Removable, Rear Release
1.340(34.04) MAX
CLASSES: “N” & “S” ONLY
1.248(31.70)
MAX
.072(1.83)
.728(18.49)
.052(1.32)
.708(17.98)
A
B
.290(7.37) MIN
FULL THREAD
MASTER
KEYWAY
.190(4.83) GROMMET
.160(4.06) GROMMET
.010(0.25) EXTENSION
3 ACCESORY TEETH
EQUALLY SPACED
F
F
MAX
GROMMET
H No. OF TEETH
E ACCESSORY THREAD
D MATING THREAD
4 MINOR KEYWAYS
MAX
GROMMET
E ACCESSORY THREAD
BLUE COLOR BANDS
4x C
MOUNTING HOLES
FULL MATE
INDICATOR
COLOR: RED
PANEL THICKNESS:
.125(3.18) MAX
Page 129
Page 145
Page 128
Page 147
A
B
83723 S III
±.13
ØC
+.005
-.004
(TP)
+.13
-.10
D
E
Mating Thread
Class 2A
Accessory Thread
Class 2A
ØF
H
Maximum
No. of
Teeth
Shell
Size
±.005
inch
mm
inch
mm
inch
mm
inch
mm
8
.812
20.62
.594
15.09
.120
3.05
9/16-24UNEF
1/2-20UNF
.305
7.75
12
10
.937
23.80
.719
18.26
.120
3.05
11/16-24UNEF
5/8-24UNEF
.405
10.29
15
12
1.031
26.19
.812
20.62
.120
3.05
7/8-20UNEF
3/4-20UNEF
.531
13.49
21
14
1.125
28.58
.906
23.01
.120
3.05
15/16-20UNEF
7/8-20UNEF
.665
16.89
24
16
1.250
31.75
.969
24.61
.120
3.05
1-1/16-18UNEF
1-20UNEF
.790
20.07
30
18
1.343
34.11
1.062
26.97
.120
3.05
1-3/16-18UNEF
1-1/16-18UNEF
.869
22.07
33
36.50
1.156
29.36
.120
3.05
1-5/16-18UNEF
1-3/16-18UNEF
.994
25.25
36
22
1.562
39.67
1.250
31.75
.120
3.05
1-7/16-18UNEF
1-5/16-18UNEF
1.119
28.42
39
24
1.703
43.26
1.375
34.93
.149
3.78
1-9/16-18UNEF
1-7/16-18UNEF
1.244
31.60
42
28
2.000
50.80
1.562
39.67
.149
3.78
1-13/16-16UN
1-3/4-18UNS
1.475
37.47
54
www.conesys.com
– 135 –
M83723/84, 85
Jam Nut Receptacle
AE83384, 85
1.340(34.04) MAX
A
1.240(31.50)
MAX
G
HEX NUT
PER MS3186
MOUNTING FLAT
MASTER
KEYWAY
"O" RING
.290(7.37)
MIN FULL THREAD
FULL MATE
INDICATOR
COLOR: RED
.190(4.83)
.130(3.30)
GROMMET
EXTENSION
.160(4.06) GROMMET
CLASSES: “N” & “S”
C
MAX
GROMMET
C
MAX
GROMMET
3 ACCESSORY
TEETH 120°
APART
F No. OF TEETH
H ACCESSORY THREAD
B
H ACCESSORY THREAD
E JAM NUT
BLUE COLOR BAND
THREAD
D
4 MINOR KEYWAYS
MATING THREAD
.781(19.84)
.761(19.33)
BLUE COLOR BAND
PANEL THICKNESS:
.125(3.18)
.062(1.57)
Page 129
Page 145
Page 128
Page 147
A
8
+.016
-.015
+.41
-.38
+.016
-.015
+.41
-.38
ØC
D
E
F
Maximum
Mating Thread
Class 2A
Jam Nut Thread
Class 2A
No. of
Teeth
inch
mm
Class 2A
5/8-20UN
12
.593
15.06
1/2-20UNF
inch
mm
inch
mm
inch
mm
.964
24.49
1.062
26.97
.305
7.75
9/16-24UNEF
G
±.003
H
±.08
Accessory
Thread
10
1.088
27.64
1.176
29.87
.405
10.29
11/16-24UNEF
3/4-20UNEF
15
.718
18.24
5/8-24UNEF
12
1.275
32.39
1.364
34.65
.531
13.49
7/8-20UNEF
15/16-20UNEF
21
.905
22.99
3/4-20UNEF
14
1.375
34.93
1.545
39.24
.665
16.89
15/16-20UNEF
1-20UNEF
24
.968
24.59
7/8-20UNEF
16
1.500
38.10
1.625
41.28
.790
20.07
1-1/16-18UNEF
1-1/8-18UNEF
30
1.093
27.76
1-20UNEF
18
1.625
41.28
1.750
44.45
.869
22.07
1-3/16-18UNEF
1-1/4-18UNEF
33
1.217
30.91
1-1/16-18UNEF
44.45
1.938
49.23
.994
25.25
1-5/16-18UNEF
1-3/8-18UNEF
36
1.342
34.09
1-3/16-18UNEF
22
1.938
49.23
2.062
52.37
1.119
28.42
1-7/16-18UNEF
1-1/2-18UNEF
39
1.467
37.26
1-5/16-18UNEF
24
2.063
52.40
2.166
55.02
1.244
31.60
1-9/16-18UNEF
1-5/8-18UNEF
42
1.592
40.44
1-7/16-18UNEF
28
2.314
58.78
2.428
61.67
1.475
37.47
1-13/16-16UN
1-7/8-20UN
54
1.840
46.74
1-3/4-18UNS
www.conesys.com
– 136 –
83723 S III
Shell
Size
ØB
M83723/86, 87
Straight Plug
AE83386, 87
1.180(29.97)
MAX
3x .035(.89)
SAFETY WIRE HOLES
B MAX
COUPLING NUT
MASTER KEY
.290(7.37)
MIN
FULL
THREAD
.190(4.83)
.130(3.30)
GROMMET
EXTENSION
A
C
MAX GROMMET
3 ACCESSORY TEETH
EQUALLY SPACED
D MATING THREAD
4 MINOR KEYS
BLUE COLOR BAND
E ACCESSORY THREAD
Page 129
Page 145
Page 128
Page 147
ØA
83723 S III
Shell
Size
+.005
-.004
Ø
+.13
-.10
B
Ø
Maximum
C
Maximum
D
E
Mating Thread
Class 2B
Accessory Thread
Class 2A
inch
mm
inch
mm
inch
mm
8
.400
10.16
.776
19.71
.305
7.75
9/16-24UNEF
1/2-20UNF
10
.521
13.23
.906
23.01
.405
10.29
11/16-24UNEF
5/8-24UNEF
12
.691
17.55
1.078
27.38
.531
13.49
7/8-20UNEF
3/4-20UNEF
14
.760
19.30
1.141
28.98
.665
16.89
15/16-20UNEF
7/8-20UNEF
16
.887
22.53
1.266
32.16
.790
20.07
1-1/16-18UNEF
1-20UNEF
18
.993
25.22
1.375
34.93
.869
22.07
1-3/16-18UNEF
1-1/16-18UNEF
28.40
1.510
38.35
.994
25.25
1-5/16-18UNEF
1-3/16-18UNEF
22
1.243
31.57
1.625
41.28
1.119
28.42
1-7/16-18UNEF
1-5/16-18UNEF
24
1.368
34.75
1.760
44.70
1.244
31.60
1-9/16-18UNEF
1-7/16-18UNEF
28
1.618
41.10
2.050
52.07
1.475
37.47
1-13/16-16UN
1-3/4-18UNS
www.conesys.com
– 137 –
M83723/91, 92
RFI Grounding Plug
AE83391, 92
1.180(29.97)
MAX
3X .035(.89)
SAFETY WIRE HOLES
B MAX
COUPLING NUT
MASTER KEY
.290(7.37)
MIN
FULL
THREAD
.190(4.83)
.130(3.30)
GROMMET
EXTENSION
RFI STRIP
C
A
MAX
GROMMET
3 ACCESSORY TEETH
EQUALLY SPACED
D MATING THREAD
4 MINOR KEYS
BLUE COLOR BAND
E
ACCESSORY THREAD
Page 129
Page 145
Page 128
Page 147
ØA
ØB
+.13
-.10
Maximum
ØC
D
E
Maximum
Mating Thread
Class 2B
Accessory Thread
Class 2A
inch
mm
inch
mm
inch
mm
8
.400
10.16
.776
19.71
.305
7.75
9/16-24UNEF
1/2-20UNF
10
.521
13.23
.906
23.01
.405
10.29
11/16-24UNEF
5/8-24UNEF
12
.691
17.55
1.078
27.38
.531
13.49
7/8-20UNEF
3/4-20UNEF
14
.760
19.30
1.141
28.98
.665
16.89
15/16-20UNEF
7/8-20UNEF
16
.887
22.53
1.266
32.16
.790
20.07
1-1/16-18UNEF
1-20UNEF
18
.993
25.22
1.375
34.93
.869
22.07
1-3/16-18UNEF
1-1/16-18UNEF
28.40
1.510
38.35
.994
25.25
1-5/16-18UNEF
1-3/16-18UNEF
22
1.243
31.57
1.625
41.28
1.119
28.42
1-7/16-18UNEF
1-5/16-18UNEF
24
1.368
34.75
1.760
44.70
1.244
31.60
1-9/16-18UNEF
1-7/16-18UNEF
28
1.618
41.10
2.050
52.07
1.475
37.47
1-13/16-16UN
1-3/4-18UNS
www.conesys.com
– 138 –
83723 S III
Shell
Size
+.005
-.004
M83723/95, 96
Self-Locking Plug
AE83395, 96
1.180(29.97)
MAX
C MAX
.290(7.37)
MIN
FULL
THREAD
COUPLING NUT
MASTER KEY
.190(4.83)
.130(3.30)
GROMMET
EXTENSION
B
A
MAX
GROMMET
3 ACCESSORY TEETH
EQUALLY SPACED
D MATING THREAD
E ACCESSORY THREAD
4 MINOR KEYS
BLUE COLOR BAND
Page 129
Page 145
Page 128
Page 147
Ø
83723 S III
Shell
Size
+.005
-.004
A
Ø
+.13
-.10
B
Ø
Maximum
C
Maximum
D
E
Mating Thread
Class 2B
Accessory Thread
Class 2A
1/2-20UNF
inch
mm
inch
mm
inch
mm
8
.400
10.16
.305
7.75
.832
21.13
9/16-24UNEF
10
.521
13.23
.405
10.29
.959
24.36
11/16-24UNEF
5/8-24UNEF
12
.691
17.55
.531
13.49
1.097
27.86
7/8-20UNEF
3/4-20UNEF
14
.760
19.30
.665
16.89
1.236
31.39
15/16-20UNEF
7/8-20UNEF
16
.887
22.53
.790
20.07
1.360
34.54
1-1/16-18UNEF
1-20UNEF
18
.993
25.22
.869
22.07
1.473
37.41
1-3/16-18UNEF
1-1/16-18UNEF
28.40
.994
25.25
1.586
40.28
1-5/16-18UNEF
1-3/16-18UNEF
22
1.243
31.57
1.119
28.42
1.703
43.26
1-7/16-18UNEF
1-5/16-18UNEF
24
1.368
34.75
1.244
31.60
1.846
46.89
1-9/16-18UNEF
1-7/16-18UNEF
28
1.618
41.10
1.475
37.47
2.278
57.86
1-13/16-16UN
1-3/4-18UNS
www.conesys.com
– 139 –
M83723/97, 98
Self-Locking, RFI Grounding Plug
AE83397, 98
1.280(32.51)
MAX
[ D MAX
.290(7.37)
MIN
FULL
THREAD
COUPLING NUT
MASTER KEY
.160(4.06)
.010(0.25)
GROMMET
EXTENSION
[C
[A
MAX
GROMMET
RFI STRIP
B
NUMBER OF TEETH
E MATING THREAD
4 MINOR KEYS
F ACCESSORY THREAD
BLUE COLOR BAND
Page 129
Page 145
Page 128
Page 147
Ø
A
B
+.13
-.10
No. of
Teeth
Ø
C
Ø
Maximum
D
Maximum
E
F
Mating Thread
Class 2B
Accessory Thread
Class 2A
inch
mm
inch
mm
inch
mm
8
.400
10.16
12
.305
7.75
.967
24.56
9/16-24UNEF
1/2-20UNF
10
.521
13.23
15
.405
10.29
1.093
27.76
11/16-24UNEF
5/8-24UNEF
12
.691
17.55
21
.531
13.49
1.170
29.72
7/8-20UNEF
3/4-20UNEF
14
.760
19.30
24
.665
16.89
1.310
33.27
15/16-20UNEF
7/8-20UNEF
16
.887
22.53
30
.790
20.07
1.500
38.10
1-1/16-18UNEF
1-20UNEF
18
.993
25.22
33
.869
22.07
1.562
39.67
1-3/16-18UNEF
1-1/16-18UNEF
28.40
36
.994
25.25
1.710
43.43
1-5/16-18UNEF
1-3/16-18UNEF
22
1.243
31.57
39
1.119
28.42
1.812
46.02
1-7/16-18UNEF
1-5/16-18UNEF
24
1.368
34.75
42
1.244
31.60
1.948
49.48
1-9/16-18UNEF
1-7/16-18UNEF
28
1.618
41.10
54
1.475
37. 47
2.278
57.86
1-13/16-16UN
1-3/4-18UNS
www.conesys.com
– 140 –
83723 S III
Shell
Size
+.005
-.004
M83723/68, 69
Lanyard Release, Quick-Disconnect Plug
AE83368, 69
Quick-Disconnect, Threaded Coupling, Crimp Removable, Rear Release
A
7.500(190.50)
MAX
MAX
C ACCESSORY THREAD
BLUE COLOR BAND
MASTER
KEY
B
D
MAX GROMMET
4 MINOR KEYS
LENGTH TO BE MEASURED WITH A
.750(19.05)±.060(1.52) BAR TO PULL
LANYARD TAUT
3 ACCESSORY TEETH
EQUALLY SPACED
1.180(29.97)
MAX
.190(4.83)
.130(3.30) GROMMET EXTENSION
Note 1: M83723/70 receptacle adapter (page 142) is required
to mate the Quick-Disconnect Plug with a receptacle.
Page 129
Page 145
Page 128
Page 147
83723 S III
Ø
A
Ø
Maximum
Note 2: Not available in shell size 8.
B
C
Ø
D
Accessory Thread
Class 2A
Maximum
Shell
Size
inch
mm
inch
mm
inch
mm
10
1.240
31.50
.405
10.29
5/8-24UNEF
.526/.517
13.36/13.13
12
1.432
36.37
.531
13.49
3/4-20UNEF
.696/.687
17.68/17.45
14
1.490
37.85
.665
16.89
7/8-20UNEF
.765/.756
19.43/19.20
16
1.711
43.46
.790
20.07
1-20UNEF
.892/.883
22.66/22.43
18
1.815
46.10
.869
22.07
1-1/16-18UNEF
.998/.989
25.35/25.12
49.83
.994
25.25
1-3/16-18UNEF
1.123/1.114
28.52/28.30
22
2.070
52.58
1.119
28.42
1-5/16-18UNEF
1.248/1.239
31.70/31.47
24
2.195
55.75
1.244
31.60
1-7/16-18UNEF
1.373/1.364
34.87/34.65
www.conesys.com
– 141 –
M83723/70
Receptacle Adapter, Quick-Disconnect
AE83370
Quick-Disconnect (Push-Pull) Receptacle Adapter
.442(11.23)
±.005(.13)
C
D THREAD
A
B
E
COLOR BAND
Mil Prefix
Aero Prefix
M83723/
AE833
70
70
W
W
10
10
Specification Sheet (Shell type)
70 = Receptacle adapter, quick-disconnect
A = Aluminum shell, black anodized finsih
Note: The adapter is required to mate the Lanyard Release
and Push-Pull Quick-Disconnect plugs (M83723/66 thru 69)
with M83723/82, 83, 84, 85, 88, 89 and 90 threaded coupling
receptacles. Use compatible thread seizing compound to
permanently secure to the receptacle.
R = Aluminum shell, elctroless nickel finish
W = Aluminum shell, cadmium olive drab over nickel base
Shell Size
D
Coupling Thread
Class 2B
A
Ø
B
Ø
C
Ø
E
±.002
±.05
±.002
±.05
±.002
±.05
±.005
±.13
inch
mm
inch
mm
inch
mm
inch
mm
8
9/16-24UNEF
.605
15.37
.577
14.66
.687
17.45
.525
13.34
10
11/16-24UNEF
.730
18.54
.712
18.08
.812
20.62
.650
16.51
12
7/8-20UNEF
.917
23.29
.892
22.66
.999
25.37
.840
21.34
14
15/16-20UNEF
.980
24.89
.952
24.18
1.062
26.97
.900
22.86
16
1-1/16-18UNEF
1.105
28.07
1.077
27.36
1.187
30.15
1.025
26.04
18
1-3/16-18UNEF
1.230
31.24
1.202
30.53
1.328
33.73
1.150
29.21
1-5/16-18UNEF
1.355
34.42
1.327
33.71
1.453
36.91
1.275
32.39
22
1-7/16-18UNEF
1.480
37.59
1.452
36.88
1.578
40.08
1.400
35.56
24
1-9/16-18UNEF
1.605
40.77
1.577
40.06
1.703
43.26
1.525
38.74
www.conesys.com
– 142 –
83723 S III
Shell
Size
Ø
Polarization (Shell Keying, Insert Clocking)
Shell Keying
D°
B°
Insert Clocking
E°
MASTER
KEYWAY(KEY)
OF SHELL
MASTER
KEYWAY
A°
ENGAGING FACE VIEW FOR
RECEPTACLE SHELL KEYWAYS
(PLUG SHELL KEYS, OPPOSITE)
C°
INSERT
VERTICAL
CENTERLINE
SOCKET INSERT
MATING FACE
(PIN INSERT IS OPPOSITE)
Notes:
1. In the normal position (N), the insert centerline coincides
with the centerline of the master keyway (key) of the
shell. E = 0°.
2. In the alternate keying positions (6, 7, 8, 9 and Y), the
minor keyways (keys) are positioned with reference to
master keyway (key) as indicated in the keying position
table below.
Polarizing
Shell
Size
8*, 10
10 only
83723 S III
12 thru 24, 28**
10 thru 24
Position
N
6
7
8
9
Y
N
6
7
8
9
Y
1†
2†
3†
4†
5†
3. In the alternate insert clocking positions (1, 2, 3, 4 and
5), the socket insert (viewing from the mating side) is
rotated counter-clockwise relative to the centerline of the
master keyway (key) of the shell. The pin insert is rotated
clockwise.
Key/Keyway Positions
A°
105
102
80
35
64
25
105
18
92
84
24
98
105
105
105
105
105
B°
140
132
118
140
155
115
140
149
152
152
135
152
140
140
140
140
140
* Per MIL-STD-1554, keyed position Y and clocked positions 1, 2, 3, 4 and
5 are not available in shell size 8.
D°
265
320
312
275
304
270
265
259
342
334
240
338
265
265
265
265
265
E°
40
50
† Per MIL-STD-1554, insert positions 1 thru 5 are inactive for new design.
Note: Alternate positions “Z” and “10” are cancelled and
superseded by Position “Y”.
** Shell size 28 is not from military standard. It is only availabe in threaded family to Aero-Electric part number.
www.conesys.com
C°
215
248
230
205
234
220
215
192
222
204
199
268
215
215
215
215
215
Insert Position
– 143 –
MIL-DTL-83723 Series III, Bayonet and Threaded
Flange and Jam Nut Receptacles
Panel Cutouts
Panel Cutouts
S
LL
J
Z
L
Panel Thickness
Receptacle Type
Rear Mounting
Wall Mount Receptacle, Bayonet
Front Mounting
inch
mm
inch
mm
.250 max*
6.36 max*
.125 max
3.18 max
Wall Mount Receptacle, Threaded
.125 max
3.18 max
.125 max
3.18 max
Jam Nut Mount (Bayonet & Threaded)
.062/.125
1.57/3.18
* Includes screw-head
Flange and Jam Nut Mounting Dimensions
L
Ø
J
Ø
Ø
inch
mm
inch
mm
inch
S
Ø
Z
+.000
-.009
+.00
-.23
±.005
±.13
±.005
±.13
mm
inch
mm
inch
mm
inch
mm
For Front Mounting
Minimum
Shell
Size
LL
8
.594
15.09
.620
15.75
.510
12.95
.125
3.18
.605
15.37
.635
16.13
10
.719
18.26
.748
19.00
.635
16.13
.125
3.18
.730
18.54
.760
19.30
12
.812
20.62
.918
23.32
.760
19.30
.125
3.18
.917
23.29
.947
24.05
14
.906
23.01
.988
25.10
.885
22.48
.125
3.18
.980
24.89
1.010
25.65
16
.969
24.61
1.114
28.30
1.010
25.65
.125
3.18
1.105
28.07
1.135
28.83
18
1.062
26.97
1.220
30.99
1.072
27.23
.125
3.18
1.229
31.22
1.260
32.00
29.36
1.346
34.19
1.197
30.40
.125
3.18
1.354
34.39
1.385
35.18
22
1.250
31.75
1.470
37.34
1.322
33.58
.125
3.18
1.479
37.57
1.510
38.35
24
1.375
34.93
1.596
40.54
1.442
36.63
.154
3.91
1.604
40.74
1.635
41.53
www.conesys.com
– 144 –
83723 S III
For Back Mounting
Minimum
(TP)
J
MIL-DTL-83723
Contacts, Tools and Seal Plugs
Series III
Contacts, Plastic Insertion/Removal Tools and Seal Plugs
Application
Pin Contacts
Socket Contacts
Seal Plugs
Plastic
Contact
Size
Type
Military No.
Military No.
Military No.
Military No.
Power/Signal
M39029/4-110
M39029/5-115
MS27488-20-1
M81969/14-11
16
Power/Signal
M39029/4-111
M39029/5-116
MS27488-16-1
M81969/14-03
12
Power/Signal
M39029/4-113
M39029/5-118
MS27488-12-1
M81969/14-04
Positioner
Positioner
Insertion Tool
Extraction Tool
For Pin Contacts
For Socket Contacts
Metal
Metal
Military No.
Military No.
Military No.
Military No.
M81969/8-205
M81969/8-206
Crimping and Metal Insertion/Extraction Tools
Crimp Tool
Contact
Size
Military No.
M22520/1-01
M22520/1-02
M22520/1-02
M22520/2-01
M22520/2-02
M22520/2-02
16
M22520/1-01
M22520/1-02
M22520/1-02
M81969/8-207
M81969/8-208
12
M22520/1-01
M22520/1-02
M22520/1-02
M81969/8-209
M81969/8-210
Contact and Wire Data
83723 S III
Test Current
Voltage
DC Test
Max. Drop
Well Dia.
Amps
Millivolts
inch
inch
mm
AWG
mm2
inch
mm
inch
mm
55
.049 ±.001
.155
3.94
24-20
.20-.52
.040
1.02
.083
2.11
16
13.0
49
.067 ±.001
.250
6.35
20-16
.52-1.31
.053
1.35
.103
2.62
12
23.0
42
.100 ±.002
.250
6.35
14-12
2.08-3.31
.097
2.46
.158
4.01
Contact
Size
Crimp Well Data
Wire Range
Minimum Well Dept
Finished Wire Ø Range
Minimum
Maximum
Note: Test Current and Maximum Voltage Drop when
tested with silver-plated wire at 25°C.
www.conesys.com
– 145 –
Contact Installation Instructions
Instructions
3. Place the correct insertion tool on the contact so that the
wire runs along the groove in the tool. (Tool tip will butt
against the shoulder.) Hold the plug or receptacle body
firmly.
Crimping Contacts
1. Select the appropriate crimp tool and ensure that the
proper crimp head positioner is used.
4. Beginning with a center cavity, insert the contact into
the insulator with a slow, even pressure until the contact
snaps into position. Make sure the contact and tool are
held perpendicular to the face of the insert during the
contact installation or the grommet could be damaged.
2. Cycle the tool to be sure the indentors are open.
3. Determine the correct selector setting for the wire size
from the data plate on the positioner (turret head
assembly) and set the selector knob on the crimp tool
to match.
4.1 If contacts are not inserted all the way prior to
removing insertion tool, do not try to reinsert the
insertion tool. Instead, remove the contact and try
again; otherwise reinserting the insertion tool may
damage the inside of the contact cavity.
4. Place the contact, mating end first, into the tool.
5. Remove tool and check the face of the connector for
proper contact installation. Proper installation may also
be checked by pulling back lightly on the wire to make
sure the contact is properly seated.
5. Insert the stripped wire into the hollow end of the contact.
Be sure the wire is inserted as far as it will go.
6. Close the tool completely to crimp. Unless the tool is
closed completely, the tool will not release the contact.
Completion
After all the cavities have been filled, slide the hardware back
into position on the connector and tighten.
7. Remove the crimped contact from the tool. Check the
inspection hole to verify that the wire is fully inserted.
Insertion of Contacts
1. Before inserting the contacts, unscrew the accessories
(clamps, backshells or adapters) from rear of plug or
receptacle. Slide the hardware over the wire bundle in
the proper order for reassembly after all the contacts
are inserted.
Extraction of Contacts (Rework)
1. Slide the hardware back over the wire bundle.
2. Select the appropriate tool. Place the wire into the
extraction tool of the pin or socket.
Size
Pin Contact
Socket Contact
M39029/4-110
M39029/5-115
16
M39029/4-111
12
M39029/4-113
www.conesys.com
Basic Crimp Tool
Pin Positioner
Socket Positioner
M22520/1-01
M22520/1-02 Red
M22520/1-02 Red
M22520/2-01
M22520/2-02
M22520/2-02
M39029/5-116
M22520/1-01
M22520/1-02 Blue
M22520/1-02 Blue
M39029/5-118
M22520/1-01
M22520/1-02 Yellow M22520/1-02 Yellow
– 146 –
M81969/14-11
M81969/14-03
M81969/14-04
83723 S III
3. Slowly slide the extraction tool down wire into the
contact cavities until the tool tip bottoms against the
contact shoulder, expanding the clip retaining tines. Hold
the wire firmly in the tool and pull the wired contact and
tool straight out of the rear of the insulator.
2. To assist insertion of contacts, lubricate insulator
(grommet) cavities with isopropyl alcohol. Alcohol will
evaporate and will not leave a conductive film. Caution:
Never use any lubricant other than isopropyl alcohol.
per MIL-STD-1554
Aero-Electric
Total
Quantity of Contacts
Status
No. of
(by Size)
Service
Alternate Positions**
(Insert Rotation in Degrees)
Insert
Arrangement
QPL’d
Tooled
Contacts
Rating
1
2
3
4
5
8-2∆
Yes
Yes
2
2
I
N/A
N/A
N/A
N/A
N/A
8-3
Yes
Yes
3
3
I
N/A
N/A
N/A
N/A
N/A
16
12
# 8 coax
8-98
Yes
Yes
3
3
I
N/A
N/A
N/A
N/A
N/A
10-2
Yes
Yes
2
2
I
10
40
50
10-5
Yes
Yes
5
5
I
10
40
50
10-6
Yes
Yes
6
6
I
10
40
50
10-20
Yes
Yes
2
I
10
40
50
12-3
Yes
Yes
3
12-12
Yes
Yes
12
2
3
12
14-4
Yes
Yes
4
14-7
Yes
Yes
7
14-12
Yes
Yes
12
9
15
14-15
Yes
Yes
15
16-10
Yes
Yes
10
16-24
Yes
Yes
24
18-8
Yes
Yes
8
18-14
Yes
Yes
14
18-31
Yes
Yes
31
20-16
Yes
Yes
16
4
I
10
40
50
I
10
40
50
I
10
40
50
7
I
10
40
50
3
I
10
40
50
I
10
40
50
10
I
10
40
50
24
I
10
40
50
I
10
40
50
14
I
10
40
50
I
10
40
50
16
I
10
40
50
8
31
20-25
Yes
Yes
25
19
6
I
10
40
50
20-28
Yes
Yes
28
24
4
I
10
40
50
20-39
Yes
Yes
39
37
I
10
40
50
41
20-41
Yes
Yes
41
22-12
Yes
Yes
12
83723 S III
22-19
Yes
Yes
19
22-32
Yes
Yes
32
26
22-55
Yes
Yes
55
55
24-19
Yes
Yes
19
24-29*
N/A
Yes
29
Yes
30
Yes
Yes
43
23
24-57
Yes
Yes
57
55
61
Yes
Yes
61
Yes
42
40
50
10
40
50
I
10
40
50
6
I
10
40
50
I
10
40
50
19
N/A
N/A
10
I
29
24-30*
24-61
I
12
19
24-43
28-42*
2
10
40
50
10
40
50
30
I
10
40
50
I
10
40
50
I
10
40
50
I
10
40
50
I
10
40
50
2
42
* Non MIL-STD-1554 layout, available to Aero-Electric part number only.
∆ Consult factory for pin insert availablility.
www.conesys.com
I
I
** Alternate clocking positions (1, 2, 3, 4, and 5) are for interchangeability
use only. Inactive for new design per MIL-STD-1554.
– 147 –
MIL-STD-1554
Insert Arrangements (Socket Front View)
for MIL-DTL-83723 Series III Connectors
Insert Arrangement Views
1
2
3
2
803
3 # 20
I
802*
2 # 20
I
1
4
3
1002
2 # 20
I
1005
5 # 20
I
4
1
5
2
1
2
898
3 # 20
I
1006
6 # 20
I
7
1
2
1
6
5
1
3
1
1
1
1
1
12
12
2
1020
2 # 16
I
3
1203
3 # 16
I
1212
12 # 20
I
1404
4 # 12
I
1407
7 # 16
I
1412
9 # 20, 3 # 16
I
8
10
15
1
1
1
1
24
1415
15 # 20
I
1610
10 # 16
I
1624
24 # 20
I
1808
8 # 12
I
16
14
31
25
1
1
1
1831
31 # 20
I
2016
16 # 16
I
2025
19 # 20, 6 # 12
I
41
12
28
39
1
1
2028
24 # 20, 4 # 12
I
1
1
2039
37 # 20, 2 # 16
I
2041
41 # 20
I
2212
12 # 12
I
* Consult factory for pin insert availability.
www.conesys.com
– 148 –
83723 S III
1814
14 # 16
I
1
MIL-STD-1554
19
32
55
1
1
1
2219
19 # 16
I
2255
55 # 20
I
2232
26 # 20, 6 # 12
I
19
1
1
1
30
29
2419
19 # 12
I
2429
29 # 16
I
2430
30 # 16
I
43
61
42
57
1
83723 S III
2443
23 # 20, 20 # 16
I
1
1
2461
61 # 20
I
2457
55 # 20, 2 # 12
I
1
2842
42 # 16
I
∆ Non MIL-STD-1554 layout, available to Aero-Electric part number
only.
www.conesys.com
– 149 –
