FPG.0B.309.CLAD52
FPG.0B.309.CLAD52
    LEMO(雷莫)
    CONN PLUG MALE 9POS SOLDER CUP
FPG.0B.309.CLAD52 数据手册
FPG.0B.309.CLAD52 www.lemo.com SUMMARY # Wires Low voltage 9 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Cable Ø 4.30 - 5.20 mm Status active Matching parts EGG.0B.309.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FP*: Elbow (90°) plug with cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 10.77 g Performance Configuration 0B.309 : 9 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm Vtest (contact-shell): 500 V (AC), 710 V (DC) Vtest (contact-contact): 600 V (AC), 850 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A H L M S1 S2 S3 mm. 9.5 23 30 20 8 7 8 in. 0,37 0,91 1,18 0,79 0,31 0,28 0,31 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0B.005.PA070 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.09.T28.050CNQZ CMN.09.T28.051PGZE Grey CMN.09.T28.051PNZE CMN.09.T28.051QGZE TPR (medical) Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FPG.0B.309.CLAD52 价格&库存
很抱歉,暂时无法提供与“FPG.0B.309.CLAD52”相匹配的价格&库存,您可以联系我们找货
