FGG.1K.308.CLAC65Z
FGG.1K.308.CLAC65Z
    LEMO(雷莫)
    FGG.1K.308.CLAC65Z
FGG.1K.308.CLAC65Z 数据手册
FGG.1K.308.CLAC65Z www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1K Termination type Male solder IP rating 68 AWG wire size 30.00 - 22.00 Cable Ø 6.10 - 6.50 mm Status active Matching parts EGG.1K.308.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 22.58 g Performance Configuration 1K.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1E.008.PA090 Caps: BFG.1K.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 180240 PVC Black 280250 PVC Grey 335990 PVC Black 335991 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1K.308.CLAC65Z 价格&库存
很抱歉,暂时无法提供与“FGG.1K.308.CLAC65Z”相匹配的价格&库存,您可以联系我们找货
