LF10WBP-12S(31)
LF10WBP-12S(31)
    HRS(广濑)
    CONN PLUG FMALE 12P SOLDER CUP
LF10WBP-12S(31) 数据手册
Miniature Waterproof Shielded Connectors LF Series Mated dimensions (Example : LF07) 8.9 mm max. (3 pos.) Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ø13 36.4 Receptacle Plug Fig. 1 ■Features Shielding Connection - Plug 1. Ease of shielded termination and connector assembly All components are self-aligning and do not require complex assembly tooling. The shield of the cable is connected with the metal housing of the connector using simple shielding clamp, supplied with the connector. (Fig. 2) Built-in shield connection spring Cable shielding connection clamp Cable 2. Water and dust protected The LF series is a rugged, waterproof connector series that is IP67 and IP68 rated in the mated condition. IP67 : Left in water at a depth of 1 m for 30 minutes IP68 : Left in water at a depth of 2 m for 14 days 3. Simplified assembly procedure No use of screws makes wiring and mounting easier. 4. Bayonet lock Fig. 2 Short turn bayonet lock Mating: Insert the plug, and then turn the locking collar clockwise, as indicated by the coupling direction marking. 2 Short turn bayonet lock assures secure vibration resistant mating of the connectors. (Fig. 3) 5. Acquired safety standard 4 pos. is 10A and meets safety standards (TÜV) Also 3- and 4-pos. have acquired the UL standard. 6. High current rating capacity No. of contacts Current rating 3 5A max. 4 10A max. 6, 12 and 20 2A max. 11 1 Receptacle Locking collar Coupling direction marking Plug Un-mating: Turn the locking collar counter-clockwise then pull off the plug. 1 2 Coupling direction marking Fig. 3 10A max. 2A max. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.7④ 1 LF Series●Miniature Waterproof Shielded Connectors ■Product Specifications Voltage rating 125V AC, 175V DC (3 pos.) 125V AC, 125V DC (4 pos.) 30V AC, 42V DC (6 pos. , 12pos. , 20pos.) 125V AC, 125V DC (11 pos. A to D) 30V AC, 42V DC (11 pos. 1 to 7) Current rating 5A max. (3 pos.) 10A max. (4 pos.) 2A max. (6 pos. , 12pos. , 20pos.) 10A(11 pos. A to D), 2A(11 pos. 1 to 7) Ratings Operating temperature range –25ç to +85ç Storage temperature range –10ç to +60ç Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specifications Conditions 1.Contact resistance 15mø max. (3, 6, 12, 20 pos.) 5mø max. (4 pos.) 5mø max. (A to D), 15mø max. (1 to 7)(11 pos.) 2.Insulation resistance 1000Mø min. 3.Withstanding voltage No flashover or insulation breakdown. 4.Vibration No electrical discontinuity for 10µs max. 5.Shock No electrical discontinuity for 10µs max 6.Durability6.  (Mating/un-mating) 30mø max. (3, 6, 12, 20 pos.) 10mø max. (4 pos.) 10mø max.(A to D), 30mø max.(1 to 7)(11pos.) 1000 cycles 7.Temperature cycle Insulation resistance : 100Mø min. Temperature : -55ç → Room temperature → +85ç → Room temperature Time : 30 → 2 to 3 → 30 → 2 to 3 (minutes) 5 cycles 8.Humidity Insulation resistance : 10Mø min. (at high humidity condition) Insulation resistance : 100Mø min. (at dry condition) 96 hours at temperature of 40ç and humidity of 90% to 95%. 9.Water / dust protection When mated with corresponding connector. Complete dust protection. No water penetration when submerged for 48 hours at the depth of 1.8 meter. 1A DC 500V DC (3, 4 pos.) 100V DC (6, 12, 20 pos.) 500V DC (A to D), 100V DC (1 to 7)(11pos.) 1250V AC/1 minute (3, 4 pos.) 300V AC/1 minute (6, 12, 20 pos.) 1250V AC(A to D),300V AC(1 to 7) / 1 minute(11pos.) 10 → 55 → 10Hz /cycle, single amplitude of 0.75mm 5 minutes / cycle, three directions, 10 cycles for each direction. Acceleration of 490m/s2, duration of 11ms, three directions, three times for each direction. ■Materials / Finish Components Material Finish / Color Remarks Body / back shell Zinc alloy Nickel plated –––––––––– Insulator PPS Black UL94V-0 Contacts Copper alloy Selective Gold plated –––––––––– Packing Chloroprene rubber Black –––––––––– Tightening collar PPS Brown UL94V-0 ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. LF 07 - W B P * - 6 S (**) ❶ 1 Series name 2 Shell size 3 Waterproof 4 Lock Mechanism 5 Connector type 2 ❷ ❸ ❹ ❺ ❻ ❼ : LF 07 10 13 W : Waterproof type B : Bayonet lock P : Plug R : Receptacle J : Jack (* : Form change zoning symbols in an identical class) ❽ 6 No. of contacts 7 Contact type : 3, 4, 6, 11, 12, 20 P : Male contact S : Female contact 8 Other specifications : A two-digit character is added to indicate other specifications as needed. LF Series●Miniature Waterproof Shielded Connectors (Cable dia.) ■Plugs ØA ØC B (Representative example.) HRS No. 136-0003-7 31 136-0004-0 31 136-0001-1 31 136-0002-4 31 136-0005-2 31 136-0006-5 31 136-0007-8 31 136-0008-0 31 136-0009-3 136-0010-2 136-0011-5 136-0012-8 No. of contacts ØA B ØC Weight 12.3 35.8 5 11g 14.8 41.8 7.3 3 6 4 12 17g 16g 20 17.9 51.9 8.7 29g 11 B ØC(Cable dia.) ●Lock ease type ØA Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. LF07WBP-3S(31) LF07WBP-3P(31) LF07WBP-6S(31) LF07WBP-6P(31) LF10WBP-4S(31) LF10WBP-4P(31) LF10WBP-12S(31) LF10WBP-12P(31) LF13WBP-20S LF13WBP-20P LF13WBP-11S LF13WBP-11P (Representative example.) Unit : mm Part No. LF07WBPD-6S(31) LF10WBPD-4S(31) LF10WBPD-4P(31) LF10WBPD-12S(31) LF10WBPD-12P(31) HRS No. 136-0020-6 31 136-0014-3 31 136-0017-1 31 136-0015-6 31 136-0018-4 31 No. of contacts ØA B ØC Weight 6 14.3 35.8 5 12g 16.8 41.8 7.3 19g 4 12 3 LF Series●Miniature Waterproof Shielded Connectors ■Receptacles ●Front panel mount type・Solder Type C ØB ØA D F(HEX) E (Representative example.) Unit : mm Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. LF07WBR-3P LF07WBR-3S LF07WBR-6P LF07WBR-6S LF10WBR-4P LF10WBR-4S LF10WBR-12P LF10WBR-12S LF13WBR-20P LF13WBR-20S LF13WBR-11P LF13WBR-11S HRS No. 136-1003-2 136-1004-5 136-1001-7 136-1002-0 136-1005-8 136-1006-0 136-1007-3 136-1008-6 136-1009-9 136-1010-8 136-1011-0 136-1012-3 No. of contacts ØA ØB 10.3 13 12.8 15.3 3 C D ØC E F Weight 7.65 1M9∞0.75 11 4g 7.75 M11∞0.75 13 7.75 M14∞0.75 17 16.55 6 4 15.05 15.25 19.05 12 6g 5g 6g 9g 10g 9g 10g 17.25 20 17.25 15.9 18.3 11 19.05 ●Front panel mount type・Through hole Type C ØB ØA D E F(HEX) (Representative example.) Unit : mm Part No. LF13WBR-20SD 4 HRS No. 136-1017-7 No. of contacts 20 ØA 15.9 ØB 18.3 C 17.5 D 7.75 E M14∞0.75 F 17 Weight 9g LF Series●Miniature Waterproof Shielded Connectors ■Receptacles ●Rear panel mount type・Solder Type C ØA ØB D(HEX) E Part No. LF10WBRB-4P LF10WBRB-12P LF10WBRB-12S LF13WBRB-20S LF13WBRB-11S HRS No. 136-1118-4 136-1013-6 136-1014-9 136-1018-0 136-1019-2 No. of contacts 4 12 20 11 ØA ØB 12.8 18.3 15.9 21.5 C 19.05 17.25 19.25 D E 17 M14∞0.75 10g 20 M17∞0.75 16g ●Rear panel mount type・ Through hole Type C ØA ØB D(HEX) E (Representative example.) Part No. LF10WBRB-12PD LF10WBRB-12SD HRS No. 136-1015-1 136-1016-4 Unit : mm Weight No. of contacts ØA ØB C D E 12 12.8 18.3 17.5 17 M14∞0.75 9g C ØD (Cable dia.) ■Jacks ØB ØA Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example.) Unit : mm Weight (Representative example.) Part No. LF07WBJ-3P LF07WBJ-3S LF07WBJ-6P LF07WBJ-6S LF10WBJ-4P LF10WBJ-4S LF10WBJ-12P LF10WBJ-12S LF13WBJ-20P LF13WBJ-20S LF13WBJ-11P LF13WBJ-11S HRS No. 136-2003-8 136-2004-0 136-2001-2 136-2002-5 136-2005-3 136-2006-6 136-2007-9 136-2008-1 136-2009-4 136-2010-3 136-2011-6 136-2012-9 No. of contacts Unit : mm ØD Weight ØA ØB C 10.3 11.5 36.3 5 11g 12.8 13.8 42.4 7.3 16g 8.7 29g 30g 29g 30g 3 6 4 12 20 15.9 11 16.9 52.4 5 LF Series●Miniature Waterproof Shielded Connectors ■CAP ●For Receptacles ØA B Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example.) Unit : mm Part No. HRS No. Applicable connector ØA B Weight LF07WBR-6P LF07WBR-C 136-3008-7 LF07WBR-6S LF07WBR-3P 12.3 4g 14.8 5g LF07WBR-3S LF10WBR-4P LF10WBR-4S LF10WBR-12P LF10WBR-12S LF10WBR-C 136-3001-8 LF10WBRB-4P LF10WBRB-12P 8.8 LF10WBRB-12S LF10WBRB-12PD LF10WBRB-12SD LF13WBR-20P LF13WBR-20S LF13WBR-11P LF13WBR-C 136-3003-3 LF13WBR-11S LF13WBR-20SD LF13WBRB-20S LF13WBRB-11S 6 17.9 7g LF Series●Miniature Waterproof Shielded Connectors BApplicable tools Unit : mm Description Part No. HRS No. LF series Applicable cable dia. Manual cable HR10A-TC-02 150-0041-2 clamp crimp LF-TC-01 150-0234-6 (Representative example.) 5 (Note) 7.3 · 8.7 Note : Applicable cable dia. is only 5mm for LF series. (Representative example.) Part No. LF07BP-T01 LF07BJ-T01 LF10BP-T01 LF10BJ-T01 LF13BP-T01 LF13BJ-T01 HRS No. 150-0232-0 150-0233-3 150-0235-9 150-0236-1 150-0237-4 150-0238-7 Applicable connectors LF07WBP-** LF07WBJ-** LF10WBP-** LF10WBJ-** LF13WBP-** LF13WBJ-** Note : It is applicable regard less of given alphabets or Numbers shown at *. Alignment guide Unit : mm 5 .0 +0 0 BPanel Cutout (Representative example.) A Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BSolder termination fixture Shell size LF07WBR-** Ø9.05 8.1 LF10WBR-** Ø11.05 10.2 Ø14.05 13.1 LF13WBRB-** Ø17.05 16.1 LF13WBR-** B +0.05 0 B A LF10WBRB-** Weight 0.7 to 2 0.7 to 4.8 BContact position arrangement and specifications Shell size LF10 LF07 LF13 Contact arrangement 3 1 5 2 1 8 3 3 2 7 12 11 3 6 5 4 10 No. of contacts 3 6 4 12 Withstanding voltage 1250V AC 300V AC 1250V AC 300V AC Current rating 5A 2A 10A 2A Insulation resistance C A 2 D 2 1 5 3 6 4 7 11 4 7 AC1250V AC300V 4 7 10A 2A 6 3 7 4 8 5 9 10 11 12 13 14 15 16 17 18 19 20 20 AC300V 2A 1000Mø Contact resistance Solder pot inner diameter B 2 4 2 4 1 1 9 1 6 15mø 1.15mm 0.8mm 5mø 15mø 1.7mm 0.8mm 4 5mø 4 Ø1.7 7 15mø 7 Ø0.8 15mø 0.8mm Note 1 : The contact configuration as viewed from the female contact connector mating side. Note 2 : The ▼ symbol indicates polarizing key position. Note 3 : Withstanding voltages are test voltage values. 7 LF Series●Miniature Waterproof Shielded Connectors Termination and Assembly Instructions The connectors are delivered with pre-assembed condition and the disassembly as shown No.1. 1 Operation Illustration No. Plug disassembly Solder termination fixture 1 1 Insert the plug into securely held solder Plug termination fixture as shown. Fixture Part No. Applicable connector LF07BP-T01 LF07WBP-6S,6P,3S,3P LF10BP-T01 LF10WBP-4S,4P,12S,12P LF13BP-T01 LF13WBP-20S,20P,11S,11P Locking collar Insertion direction Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 Loosen the backshell turning it counter Body / insulator assembly 2 clockwise and remove it from the body/ insulator assembly. Backshell Note Vice fixed ban Vice A Detail view Retaining ring Vice Note When removing, assembling and wiring, be sure to use a solder termination fixture. Directly fixing the locking collar in place with a vice etc.. could lead to damage, deformation or lacuna of retaining ring. Jack Disassembly Solder termination fixture 1 A Jack 1 Insert the jack into the securely held solder termination fixture as shown. Fixture Part No. Applicable connector LF07BJ-T01 LF07WBJ-6S,6P,3S,3P LF10BJ-T01 LF10WBJ-4S,4P,12S,12P LF13BJ-T01 LF13WBJ-20S,20P,11S,11P Insertion direction 2 2 Loosen the backshell turning it Body / insulator assembly counterclockwise. Backshell Note Vice fixed ban Vice Note When removing, assembling and wiring, be sure to use a solder termination fixture. Directly fixing the body in place with a vice etc.. could lead to damage or deformation. Vice Backshell 2 Connector Assembly 1 1 Apply a coating of Loctite 7649 (Manufactured by Henkel Japan, Ltd,) primer to the threaded sections of the backshell and the tightening collar. Completely dry the coated surfaces. Threaded section Threaded section Notes (1) Drying time at room temperature is approximately 30 to 70 seconds. (2) Ensure sufficient ventilation of the area at time of drying. (3) Take necessary steps to protect the coated surfaces from contamination. Tightening collar 2 Backshell Strain relief collar Tightening collar Cable preparation end Gasket 8 Cable 2 Thread the tightening collar, strain relief collar, seal bushing and the backshell over the cable as illustrated. Note Threading the components may not be possible after the cable-end finishing process. LF Series●Miniature Waterproof Shielded Connectors 3 Operation Illustration No. 1 Cable preparation Stripping dimensions A Cable outer jacket 1 Strip the cable’s outer jacket to the dimensions No. of Conductors 3 6 4 12 Shielding mesh 11 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20 Shielding mesh 2 illustrated in the table 1. Notes Table 1. Stripping Dimensions A mm 8 to 9 13 to 14 14 to 15 22 to 23 (No.A to D) 23 to 24 (No.1 to 7) 23 to 24 Cable outer jacket Wires (1) Exercise caution not to damage the shielding mesh. (2) Any damage to the cable’s outer jacket may affect the waterproof performance of the assembled connector. 2 Fold back the shielding mesh over the cable’s outer jacket assuring that it is uniform on its diameter. Shielding mesh (Folded back) 4 to 5mm Cable outer jacket Wires Stripping dimensions 3 Wires B 3 Strip the wires to the dimensions illustrated in Cable outer jacket Table 2. Stripping Dimensions No. of Conductors 3 6 4 12 11 Conductors 20 B mm 2.5±0.5 2±0.5 3±0.5 2±0.5 3±0.5 (No.A to D) 2±0.5 (No.1 to 7) 2±0.5 the Table 2. Note When stripping the wires exercise caution not to damage it’s insulation, folded over shielding mesh or cable’s outer jacket. It may cause deffects in insulation, conduction, and waterproof performance. Soldering 4 1 Soldering conditions Soldering iron tip temperature: 350±10ç Soldering time: within 5 sec. Notes (1) Assure that the solder compound is sufficiently melted on the soldering iron tip. (2) When applying, make sure that the solder will flow correctly at all the contact surfaces between the conductor and the contact. C 2 –1 Wire Insulator 2 – 1 6, 12, 11(No.1 to 7), 20 Conductors Table 3 Heat shrink tubing Dimensions No. of No. of contacts C mm Conductors Contact 6 1 to 6 1 to 9 10 to 12 1 to 4 5 to 7 4 4 6 6 4 1 to 5,16 to 20 6 to 15 4 6 12 Heat-shrink tubing 11 20 Insulator Insulator wall 2 –2 Insulator Contact Contact Insulator wall Solder Wire insulation 0.5 mm min. Wire insulation (1) Place a heat-shrink tubing (inside diameter of 1.1 mm min.) over every other wire. Perform the soldering of the contact and the (2) conductor, with the wire’s insulation touching the contact as shown. After soldering, slide the heat shrink tubing (3) over the soldered joint and shrink it. The tubing should touch the insulator as shown. 2 – 2 3, 4, 11(No.A to D) Conductors (1) Perform the soldering of the contact and the conductor, with the wire’s insulation touching the contact as illustrated. (2) When soldering, to maintain the insulation between adjacent contacts. Make sure that the wire’s insulation remains below the edge of the insulator’s wall 0.5 mm min., as illustrated. 9 LF Series●Miniature Waterproof Shielded Connectors 4 Operation Illustration No. 3 D 3 After the soldering, keep a distance of D Cable outer jacket Table 4. Wire Dimensions No. of Conductors D mm 3 6 to 7 6 4 10 to 11 12 13 to 14 11 18 to 19 20 Shielding mesh (Folded back) Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5 Crimping of the Shielding Clamp Solder termination fixture 1 Body / insulator assembly Soldered joints Cable outer jacket Copper tape 2 mm max. Wires 1 After completion of the soldering operations carefully remove (holding on the locking collar) the body/insulator assembly from the solder termination fixture. Note Exercise caution not to damage or deform the solder joints. 2 Wrap the folded over shielding mesh with 5 to Cable outer jacket 2 between the contact end and the cable’s outer jacket as illustrated. Note The distance of D is required in order to assure correct assembly of the backshell. 6mm wide copper tape to assure that it will not become loose. Apply the copper tape so that the shielding mesh does not protrude from under it. Note Shielding mesh Copper tape After wrapping the copper tape, the tape should overlap itself by 2mm max. 5 to 6mm 3 Insert the “U” shaped shielding clamp over the 3 Cable outer jacket Ground clamp 1±0.5mm Copper tape Cable outer jacket Copper tape copper tape as shown on the illustration. It is critical that the overlap of the copper tape is located inside the shielding clamp as shown on the illustration. Note Wires Shielding clamp Shielding mesh Overlap of the copper tape When the end of the copper tape wrapping is positioned at the open side of the ground fitting, the end portion of the copper tape wrapping will no longer be covered by the ground fitting when the ground fitting is crimped. 4 Using commercially available pliers bend the 4 Commercially available pliers E open ends of the shielding clamp as illustrated, assuring that it stays in place. The dimension of E. between opposing edges of the shielding clamp is necessary to assure correct final crimp. Table 5 Shell size Shielding clamp Overlap of the copper tape 10 LF07 LF10 LF13 E 5mm max. 7mm max. LF Series●Miniature Waterproof Shielded Connectors 5 Operation Illustration No. 5 Crimping tool Forming cavity 5 Both sides of the shielding clamp must be placed in the forming cavity of the tool (as shown on the illustration) and crimped over the cable by closing the tool completely. Crimping tool Forming cavity HR10A-TC-02 5.3 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 , 2 6 7.0 5.3 7.0 LF-TC-01 Applicable Shielding clamp diameter cable diameter after crimping 5.3mm to 5mm 5.5mm ––– ––– 7.9 7.3mm 9.1 8.7mm 7.9mm to 8.1mm 9.1mm to 9.3mm Connector Assembly Locktite area Wiring side 1 to 2 threaded portion 1 Place the body/insulator assembly in the applicable solder termination fixture. For plug assembly Fixture Part No. LF07BP-T01 LF10BP-T01 LF13BP-T01 For jack assembly Body/insulator assembly Threaded section Applicable connector LF07WBP-6S,6P,3S,3P LF10WBP-4S,4P,12S,12P LF13WBP-20S,20P,11S,11P Fixture Part No. LF07BJ-T01 LF10BJ-T01 LF13BJ-T01 Backshell Applicable connector LF07WBJ-6S,6P,3S,3P LF10WBJ-4S,4P,12S,12P LF13WBJ-20S,20P,11S,11P 2 Coat the thread section of the body/insulator assembly with Loctite 263 compound (manufactured by Henkel Japan, Ltd.) or equivalent, tightening it with a torque specified in the table 6. Notes Wrench width : D Table 6 (Recommend tightening torgue) Shell size Tightening torque Wrench width LF07 LF10 LF13 1N·m to 1.5N·m 1N·m to 1.5N·m 1.5N·m to 2N·m 10mm 13mm 16mm (1) The applied loctite should not protrude out further than the wiring side 1 to 2 threaded section. If it does, it may affect waterproof performance and locking. Please remove any protruding loctite with a cloth or cotton swab. etc. (2) It is critical that the cable itself will not turn or twist during this operation. It may cause breakage at the soldered area. 3 Slide forward the gasket and insert it in 3 , 4 Gasket Strain relief collar the backshell until fully seated. 4 Slide forward the strain relief collar and insert it in the backshell, making sure that the opposing protrusions fit inside the corresponding grooves, as shown on the illustration. Groove Protrusion Tightening collar 5 Threaded section Tightening collar Note It is critical that the protrusions are inside the corresponding grooves. It may cause breakage, when a tightening collar is assembled. 5 Verify that the Locktite 7649 primer (or equivalent) on the threaded sections of the backshell and tightening collar are dry. Apply the Locktite 263 compound to the tightening collar’s threaded section and attach it to the backshell. 11 LF Series●Miniature Waterproof Shielded Connectors Operation Illustration No. 6 6 6 Remove the connector from the solder Tightening collar termination fixture, holding it by the locking collar. Do not pull on the cable. It may cause breakage. Recommended tightening torgue Wrench width Shell size Tightening torque Wrench width Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LF07 LF10 LF13 0.8N·m to 1N·m 0.7N·m to 1N·m 1 N·m to 1.5 N·m 10mm 14mm 16mm Confirmation of Waterproof Performance 7 After connector assembly procedure is completed, compress air in to the connector from the mating side under 17.6 kPa for 30 seconds check that no air leaks out of the connector. Cable Specifications (Reference) Material Size (mm) Construction 4 pos. 3 pos. Ø0.18 Ø0.26 6 pos. 12 pos. Tin plated soft copper wire Ø0.16 Ø0.16 20 /Ø0.18 mm dia. 20 /Ø0.26 mm dia. 7 /Ø0.16 mm dia. 16 AWG 26 AWG 20 AWG Sectional area 0.5 1.25 0.14 Diameter (mm) Ø0.98 Ø1.5 Ø0.48 Ø0.16 11 pos. Ø0.26 Ø0.16 7 /Ø0.16 mm dia. 7 /Ø0.16 mm dia. 26 /Ø0.26 mm dia. 7 /Ø0.16 mm dia. 26 AWG 26 AWG 16 AWG 26 AWG 0.14 0.14 1.25 0.14 Ø0.48 Ø0.48 Diameter (mm) Ø1.5 (Standard) Thickness (mm) 0.26 Ø2.1 (Standard) Ø0.88 (Standard) Ø0.9 (Standard) Ø0.9 (Standard) Ø1.5 Ø0.48 Ø2.1 (Standard) Ø0.95 (Standard) 0.3 0.2 0.21 0.3 Material Density 80% or more 85% Tin plated soft copper wire 80% or more 80% or more 80% or more Ø5.5 Ø3.4 Ø4.2 Ø5.1 Ø6.7 Ø7.3±0.2 Ø5±0.2 Ø7.3±0.2 Ø8.7±0.2 Ø8.7±0.2 Jacket Insulator Size (AWG) 20 pos. Shield Conductor No. of contact 85% Diameter (mm) Ø3.6 Diameter (mm) Ø5±0.2 0.21 0.24 Remarks : The cable satisfies required specifications for UL specification. Notes : The cable pull and twisting strength, waterproof tightness and other characteristics may differ, depending on the cable structure, please confirm before the use. ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
LF10WBP-12S(31) 价格&库存
很抱歉,暂时无法提供与“LF10WBP-12S(31)”相匹配的价格&库存,您可以联系我们找货
LF10WBP-12S(31)
    • 1+132.93753
    • 5+126.97238
    库存:5
    LF10WBP-12S(31)
      • 1+142.31133
      • 10+129.52887
      库存:45
      LF10WBP-12S(31)
        • 1+340.01329
        • 2+233.49283
        • 3+221.56254
        库存:275
