BM-A-8-M
BM-A-8-M
    SUBURBANEMBEDDED(Suburban Embedded)
    INSERT MALE SIZE A 8POS
BM-A-8-M 数据手册
Baromax Connector Family The Baromax Connector series is the smallest high power density underwater connector rated for continuous submersion up to 10,000psi. Wire sizes up to #18 AWG offers power capabilities up to 15 amps per contact. User configurable assemblies provide limitless configurations with one connector face. Features High Power Density Up to 40 amps per connector in a compact footprint Wire-to-bulkhead & Wire-to-Wire Configuration Connector faces are interchangeable Locking rings for secure mate and quick disconnection Gigabit Ethernet Ready Minimize un-twisted cable length for high speed differential signals Applications Data ● ● ● ● ● ● 10/100/1000Base-T Ethernet VDSL2 RS232 / RS485 CAN bus Analog Digital GPIO Power ● ● ● ● ● ● ● ROV thruster ROV tether Camera tether Light/strobe power Wet area quick disconnect Power over Ethernet ○ 802.3af, 802.3at, 802.3bt Relay, burn wire © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 1/7- Ordering Information Evaluation Kit Description Part Number Kit Contents Evaluation kit BM-EVAL-A 1x BM-A-8-M 1x BM-A-8-F 1x BM-BH-A-A-1 1x BM-IL-A-A-1 1x BM-A-LR-F-A-B-1 1x BM-A-LR-M-A-B-1 1x BM-EPOXY-KIT Connector Face Description Part Number Material / Desc Kit Contents Male 8-pin Connector BM-A-8-M Neoprene body, brass contact with 30u” gold plating, solder cup N/A Female 8-pin Connector BM-A-8-F Neoprene body, brass contact with 30u” gold plating, solder cup N/A Bulkhead backshell Part Number Material / Desc Kit Contents BM-BH-A-A-1 Brass O-ring BM-BH-A-B-1 SS316 O-ring BM-BH-A-C-1 AL 6061T6 O-ring BM-BH-B-C-1 AL 6061T6, M10 rear thread, standard front thread O-ring BM-BH-C-C-1 AL 6061T6, M10 rear thread, O-ring © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 2/7- low-profile front thread Inline backshell Part Number Material / Desc Kit Contents BM-IL-A-A-1 Brass Snap ring BM-IL-A-B-1 SS316 Snap ring BM-IL-A-C-1 AL 6061T6 Snap ring Accessories Description Part Number Material / Desc Kit Contents Locking Ring, female BM-A-LR-F-A-B-1 Standard locking ring, female Snap ring Locking Ring, male BM-A-LR-M-A-B-1 Standard locking ring, male Snap ring Locking Ring, female BM-A-LR-F-B-B-1 Low-profile locking ring, Snap ring female Item Part Number Description Epoxy Cartridge BM-EPOXY-A Recommended potting N/A compound for Baromax Epoxy Kit BM-EPOXY-KIT Epoxy and consumable mixing nozzles and needle tips Epoxy gun BM-DISPENSER-A Dispensing gun for 2:1 cartridge Accessories © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io Kit Contents 1x BM-EPOXY-A 5x 20 element luer lock mixing nozzle 5x 1.5” 14ga needle tip - 3/7- Part Overview For reference only. See detailed part drawings. Male Connector Female Connector Male Locking Ring Female Locking Ring © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 4/7- Inline Backshell Bulkhead Backshell Standard thread option M10 rear thread option M10 rear thread low-profile option © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 5/7- Specifications Electrical Current Rating, per contact (Amperes) 15 Current Rating, per connector (Amperes) 40 Voltage Rating, operating (VDC / peak VAC) 400 Dielectric Withstanding Voltage (VDC/ peak VAC) 500 Typical Contact Resistance (mOhm) < 1.0 Hot Plug Not rated for hot plug or live circuit interruption. Materials Connector Body Neoprene Connector Contacts Brass, 30u” gold plated Mechanical Wire Size Range AWG 24 to 18 Contact Termination Method Hand solder Max. Cable Diameter (Standard backshells) 0.40 inches Operating Temperature Air (degC) -40 - 60 Operating Temperature Water (degC) -4 - 60 Mating Cycles 500 Typical Mating / Unmating Force - Max ambient pressure (psi) 10,000 © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 6/7- Warranty Suburban Marine, Inc.’s products are subject to a limited warranty. Suburban Marine, Inc. warrants Baromax connectors will meet the specifications listed in their respective datasheets and be free of defects in material and workmanship for a period of 1 year. This limited warranty does not cover damage resulting from misuse, abuse, accidents, alterations, or improper installation/assembly. This warranty extends to the original purchaser or ultimate consignee and is not transferable. The exclusive remedy under this limited warranty will be at Suburban Marine’s option to replace or refund the purchased items. Under no circumstances will Suburban Marine, Inc. be liable for any indirect, special, incidental, or consequential damages or loss caused by the failure of an item covered under this warranty. Under no circumstances will Suburban Marine, Inc.’s liability under this warranty exceed the purchase price paid for the products. Suburban Marine, Inc.’s products are not designed for use in medical, life-saving, life sustaining applications, or applications where the failure of a Suburban Marine Inc product could result in personal injury or death. Customers using products in such applications do so at their own risk and agree to indemnify Suburban Marine, Inc. from any damages resulting from such improper use. © 2021 Suburban Marine Inc. All Data Subject to Change Without Notice. Baromax Datasheet Rev A1.0. www.suburbanmarine.io - 7/7- 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D C C 15.7 23.0 B B UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: 8-PIN FEMALE CONNECTOR SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-8-F-WEB SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INIITIAL RELEASE 3/19/2021 D C C 15.7 31.0 B B UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: 8-PIN MALE CONNECTOR SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-8-M-WEB SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D M20 X 1.5-6g 19 7/16-20 UNF-2A C C 6.4 2-014 O-RING GROOVE 17.7 B B 40.0 UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: BULKHEAD BACKSHELL, SIZE A, 7/16-20 THREAD SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210107 3 SCALE: 2:1 2 REV A BM-A-BH-A-X SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D LOW PROFILE SQUARE THREAD C C M10X1.5-6g 10.0 R9.0 17.0 B B 4.5 25.0 2-014 O-RING GROOVE 47.3 UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: BULKHEAD BACKSHELL, M10 THREAD, LOW PROFILE SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-BH-C-X SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D 11.5 MAX CABLE OD C C 15.9 35.1 B B UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: INLINE BACKSHELL, SIZE A SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-IL-A-X SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D M20X1.5-6H C C B B 45.0 R10.9 UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: LOCKING RING, FEMALE, STANDARD SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-LR-F-A-X SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D C C B B 18.5 45.0 UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: LOCKING RING, FEMALE, LOW PROFILE SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 REV A BM-A-LR-F-B-X SHEET 1 OF 1 1 A 8 7 6 5 4 3 COPYRIGHT 2021 © SUBURBAN MARINE D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SUBURBAN MARINE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SUBURBAN MARINE, INC IS PROHIBITED. ZONE REV. DESCRIPTION DATE A INITIAL RELEASE 3/19/2021 D M20X1.5-6H R10.92 C C 9.50 23.50 B B UNLESS OTHERWISE SPECIFIED: A DIMENSIONS ARE IN mm DRAWN ANGULAR 1 X 1.0mm .X 0.4mm .XX 0.1mm CHECKED APPROVED APPROVED INTERPRET GEOMETRIC TOLERANCING PER: ISO 2768- mK MATERIAL FINISH 7 6 5 4 THIRD ANGLE PROJECTION: NONE TITLE: LOCKING RING, MALE, STANDARD SIZE DWG. NO. B NONE DO NOT SCALE DRAWING WEIGHT: 8 NAME DATE MM 20210319 3 SCALE: 2:1 2 A REV A BM-A-LR-M-A-X SHEET 1 OF 1 1
BM-A-8-M 价格&库存
很抱歉,暂时无法提供与“BM-A-8-M”相匹配的价格&库存,您可以联系我们找货
