Additional Resources:
Product Page
date
08/25/2017
page
1 of 3
SERIES: MD2-ST-SMT │ DESCRIPTION: MINI DIN CONNECTOR
fully shielded
right angle
surface mount
slim style
U
ED
FEATURES
N
RoHS
TI
PART NUMBER KEY
N
MD2 - XX ST - SMT
Pin Options
40 = 4 pins
60 = 6 pins
O
Base Number
SPECIFICATIONS
conditions/description
min
IS
C
parameter
rated input voltage
rated input current
typ
100
12
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
max
units
Vac
Vdc
1
2
A
A
30
mΩ
50
MΩ
insertion force
250
Vac
4.5
kg
0.8
3.5
kg
operating temperature
-25
85
°C
D
withdrawal force
life
1,000
flammability rating
UL94V-0
RoHS
2011/65/EU
cui.com
cycles
Product Page
CUI Inc │ SERIES: MD2-ST-SMT │ DESCRIPTION: MINI DIN CONNECTOR
date 08/25/2017 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: X.X ±0.2mm
PCB Layout: ±0.05mm
0.40 0.016
0.1
2.0 0.079
D
2.3 0.091
2.0 0.079
(TYP)
2.30 0.091
(2 PLCS)
6
2.20X1.00
(2 PLCS)
3.00 0.118
2.20 0.087
0.9X3.5
(4 PLCS)
6
3
2
2.30 0.091
(2 PLCS)
4
1
2.20X1.00
(2 PLCS)
2.20 0.087
0.9X3.5
(6 PLCS)
6
4
9.0 0.354
5.4 0.213
12.8 0.504
1
2
1
9.0 0.354
5.4 0.213
3
3
5
9.9 0.390
(4 PLCS)
9.9 0.390
(6 PLCS)
PCB LAYOUT
TOP VIEW
PCB LAYOUT
TOP VIEW
cui.com
9.0 0.354
5.4 0.213
4
5
4
1
12.8 0.504
2
MD2-60ST-SMT
3
2
1
BOTTOM VIEW
MD2-40ST-SMT
4
3
2.3 0.091
(2 PLCS)
8.9 0.350
0.3
2
5
0.3 0.012
(TYP)
N
2.0 0.079
0.1
12.8 0.504
3.00 0.118
silver
0.45 0.018
(6 PLCS)
TI
1
IS
C
2.2±0.3
0.087
(2 PLCS)
LCP
1.7 0.067
1.6 0.063
0.1
2.4 0.094
0.1
3
2
housing
3.0 0.118
O
5.4 0.213
0.15
phosphor bronze
7.8 0.307
0.3
4.0 0.157
0.1
5
4
tin
contact terminals (1~6)
U
5.0 0.197
0.1
11.0 0.433
PLATING
brass
N
13.1 0.516
6
MATERIAL
ED
earth terminal
1.8 0.071
1.8 0.071
Product Page
date 08/25/2017 │ page 3 of 3
REVISION HISTORY
description
date
02/23/2006
1.0
initial release
1.01
new template applied
1.02
updated datasheet
ED
rev.
02/09/2012
08/25/2017
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“MD2-40ST-SMT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.583651+2.72495
- 10+20.5089810+2.47462
- 25+19.4269225+2.34406
- 50+18.9754550+2.28958
- 100+18.07221100+2.18060
- 250+15.81329250+1.90804
- 500+15.36134500+1.85351
