XLR CHASSIS CONNECTORS
5 PIN B SERIES - HORIZONTAL PCB MOUNT
Locking horizontal PCB Mount 5 pin chassis
connector with plastic body and metal faceplate
for audio and lighting control.
Other Available Mounting Option: Vertical PCB
Mount
IO-XLR5-M-BH
SPECIFICATIONS
MECHANICAL
IO-XLR5-F-BH
Lifetime: > 1000 Mating Cycles
PRODUCT
Gender: Male (IO-XLR5-M-BH)
Female (IO-XLR5-F-BH)
Wiring: Horizontal PCB Mount
Locking Device: Latch Lock
Mounting Direction: Rear
Contacts: 5
Solderability: Complies with IEC
60068-2-20
ELECTRICAL
Capacitance Between Contacts: ≤ 2 pF
Capacitance Between Contact and Ground: ≤ 2 pF
Contact Resistance: < 6 mΩ
MATERIAL
Contacts: Brass
Contact Plating: .05μm Au
Insulation Resistance: ≥ 5000 MΩ
Dielectric Strength: 1500V @ 60s
Current Rating: 3 A / 50 V AC
Grounding: Separate ground Pin. Grounds to shell of
mating connector and panel
Ground Terminal: Brass
Ground Terminal Finish: Nickel
Shell: PA
Shell Finish: Black
Push Button: Stainless Steel
ENVIRONMENTAL
Standard Compliance: IEC 61076-2-103
UL Flammability: Meets UL 94 HB
Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F)
Push Button Finish: Nickel
Latch: Stainless Steel
Latch Finish: Nickel
Faceplate Finish: Nickel
Product specifications may change without prior notification
Io Audio Technologies® is a registered trademark of Knight Electronics, Inc.
10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
www.ioaudiotechnologies.com
DRAWINGS
IO-XLR5-F-BH
IO-XLR5-M-BH
Panel Cutout
FEATURES & APPLICATIONS
B Series XLR chassis connectors offer the most cost-effective
solution for design-in applications where the termination
method is to a printed circuit board. The small footprint makes
this our XLR receptacle with the highest packing density
available. These connectors feature a compact, all plastic
housing with a nickel plated faceplate. Precision machined,
one piece, gold plated contacts are standard to help prolong the
useful life of the connectors. They also come with a separate nickel plated
ground pin that grounds the connector to the panel. The compact form factor of the
these connectors makes them perfect for situations where space saving is a priority
or space for a connector is limited.
Available in 3 or 5 pin, Male or Female variations with options for vertical or
horizontal PCB mounting.
PART NUMBER BREAKDOWN:
STANDARDS & CLASSIFICATIONS
IO-XLR5-M-BH
Series Identifier
IO-XLR5-M-BH
Number of Pins
IO-XLR5-M-BH
Gender
IO-XLR5-M-BH
Series Identifier
IO-XLR5-M-BH
H = Horizontal PCB Mount
V = Vertical PCB Mount
很抱歉,暂时无法提供与“IO-XLR3-F-BH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.924601+4.39255
