K10WAM-P09WMM0-0000
K10WAM-P09WMM0-0000
    ODU(欧度)
    CONN RCPT FMALE 9POS SOLDER CUP
K10WAM-P09WMM0-0000 数据手册
3 5 4 View in direction B 4:1 6 5 Keying indication 4 K10W Color coding A BM-P09WMM0-0000 SW 10 A M-P09WMM0-0000 Mechanical coding: A Color coding: light brown 0.8 A 0.8 2.5 B 19.5 C In-Line Receptacle Crimp sleeve 1) Backshell 1) C Keying indication Color coding Only insert View in direction A 8:1 D pos. 7 K10W C M-P09WMM0-0000 Mechanical coding: C Color coding: blue CAD: Creo Parametric 1 B K10W Nur rot gestempelte oder auf Laufkarte gedruckte Dokumente unterliegen dem Änderungsdienst und sind zur Fertigung freigegeben. Only red stamped or on jobcard printed documents are managed. These documents are approved for production. 2 B Mechanical coding: B Color coding: red 2:1 Technical information D pos. 1 pos. 8 Delivery condition pos. 9 - Max. cable n 7.0mm (Based on cable with one braided shield) - Power solder contacts: AWG 22 (pos.1/2/3/5/6/7) Current load: 5A (Single contact) E E - Signal solder contacts: AWG 28 (pos.4/8/9) Current load: 1A (Single contact) Test voltage: 750V (acc. SAE AS 13441:1998, Contact to contact) Rated voltage: 250V (acc. SAE AS 13441:1998) K10W D M-P09WMM0-0000 Mechanical coding: D Color coding: green 1 2 R 2) Maximal operating voltage at sea level up to 2.000 m. Rated voltage applies no other electrical safety standard. In case other standards rule a specific use of the connector, the application specific safety criteria shall be considered first. This must be evaluated in the frame of equipment engineering. Bei den hier dargestellten ODU-Steckverbindern handelt es sich nach DIN EN 61984:2009 um Steckverbinder ohne Schaltleistung (COC) ! /the pictured ODU-connectors are in relation to DIN EN 61984:2009 connectors without switching capacity (COC) ! 3 1,2,3,5,6,7 Discrete 4 Benennung/description: 1) For crimp information, torque, etc. see assembly instruction 010.650.001.000.002 (www.odu.de/downloads) F Power USB (D+ D-) 8,9 2) All Rights reserved, including possible patents or trademarks. Documents shall not be provided to a third party or duplicated in any form without prior written permission. 3 12 10.5 A 8 7 12.8 2 7.5 Additional coding Fuer Fall ohne noch diese Unterlage behalten wir uns alle Rechte vor, auch fuer den der Patenterteilung oder Gebrauchsmustereintragung. Sie darf unsere vorherige schriftliche Zustimmung weder vervielfaeltigt sonstwie benutzt, noch Dritten zugaenglich gemacht werden. 1 4 Allgemeintoleranz/general tol.: DIN ISO 2768-mH Tolerierung / Tolerancing: DIN ISO 8015 Status/state: Version: Approved revision: Erstellt/prepared 28.11.2014mforster KABELTEIL CPL. - CAD-Nr.: design-ID: Teile-ID: part-ID: Oxaion-Nr.: ODU-MUEHLDORF Ursprung/origin.: Datum/date Name/name see BOM Maßstab: scale: Geaendert/revised 28.11.2014mforster Freigabe/released 06.04.2016jweigand Werkstoff: material: 00058862 K10W.M-P09WMM0-0000 Format: size: 1:1 Einheit: dim.: Bl.: A3 mm sheet: 1
K10WAM-P09WMM0-0000 价格&库存
很抱歉,暂时无法提供与“K10WAM-P09WMM0-0000”相匹配的价格&库存,您可以联系我们找货
K10WAM-P09WMM0-0000
  • 1+1198.279211+155.80930
