Additional Resources:
Product Page
date
08/25/2017
page
1 of 4
SERIES: MD-SGK │ DESCRIPTION: MINI DIN CONNECTOR
PCB mount
fully shielded
right angle
ground tabs with kinked pins
U
ED
FEATURES
N
RoHS
TI
PART NUMBER KEY
N
MD - X X SGK
O
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
80 = 8 pins
SPECIFICATIONS
conditions/description
min
IS
C
parameter
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
max
100
12
rated input voltage
rated input current
typ
Vac
Vdc
1
2
A
A
30
mΩ
50
insertion force
units
MΩ
1
250
Vac
4.5
kg
0.8
3
kg
operating temperature
-40
85
°C
D
withdrawal force
life
1,000
flammability rating
UL94V-0
RoHS
2011/65/EU
cui.com
cycles
Product Page
CUI Inc │ SERIES: MD-SGK │ DESCRIPTION: MINI DIN CONNECTOR
date 08/25/2017 │ page 2 of 4
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
plastic
PBT
silver
13.2 0.52
6
4
3
1
2
phosphor bronze
TI
5
13.0 0.51
tin
contact terminals (1~8)
N
7
PLATING
brass
U
14.1 0.56
8
MATERIAL
ED
earth terminal
6.5 0.26
3.7 0.15
3.5 0.14
N
0.3 0.01
2.0 0.08
0.3 0.01
(8 PLCS)
4.7 0.19
5.5 0.22
O
2.0 0.08
(3 PLCS)
0.7 0.03
(8 PLCS)
IS
C
13.9 0.55
MD-30SGK
8.5 0.33
11.0 0.43
MD-40SGK
4
3
2
1
D
5.5 0.22
(2 PLCS)
0.9 0.04
(3 PLCS)
1
13.5 0.53
13.5 0.53
5.5 0.22
(2 PLCS)
4.7 0.19
0.7X2.2
(3 PLCS)
0.9 0.04
6.8 0.27
PCB LAYOUT
TOP VIEW
2
1
2
3
4
5
3
1
8.5 0.33
(2 PLCS)
8.5 0.33
(2 PLCS)
0.7X2.2
(3 PLCS)
3
2
13.5 0.53
4.7 0.19
MD-50SGK
0.9 0.04
(4 PLCS)
1
2
3
4
6.8 0.27
PCB LAYOUT
TOP VIEW
cui.com
11.0 0.43
(2 PLCS)
5.5 0.22
(2 PLCS)
4.7 0.19
8.5 0.33
(3 PLCS)
2
0.7X2.2
(3 PLCS)
0.9 0.04
(5 PLCS)
1
4
11.0 0.43
(2 PLCS)
3
5
1.3 0.05
6.8 0.27
PCB LAYOUT
TOP VIEW
Product Page
date 08/25/2017 │ page 3 of 4
MECHANICAL DRAWINGS (CONTINUED)
MD-60SGK
MD-80SGK
5
2
5
1
4
2
5
8.5 0.33
(4 PLCS)
11.0 0.43
(2 PLCS)
5.5 0.22
(2 PLCS)
3
1
6
4
2
0.7X2.2
(3 PLCS)
6
2.6 0.10
7
6.8 0.27
2.6 0.10
6.8 0.27
N
D
IS
C
O
N
TI
PCB LAYOUT
TOP VIEW
cui.com
8
0.9 0.04
0.9 0.04
(8 PLCS)
PCB LAYOUT
TOP VIEW
11.0 0.43
(4 PLCS)
5
U
0.9 0.04
(6 PLCS)
4.7 0.19
5.5 0.22
(2 PLCS)
8.5 0.33
(4 PLCS)
0.7X2.2
(3 PLCS)
3
1
13.5 0.53
4.7 0.19
1
6
4
2
13.5 0.53
3
7
8
3
ED
6
4
Product Page
date 08/25/2017 │ page 4 of 4
REVISION HISTORY
description
date
02/23/2006
1.0
initial release
1.01
new template applied
1.02
updated pin dimensions
1.03
updated datasheet
ED
rev.
02/22/2012
03/07/2012
08/25/2017
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“MD-30SGK”相匹配的价格&库存,您可以联系我们找货
