W3280-12PG-535
W3280-12PG-535
    SWITCHCRAFT
    CONN PLUG MALE 12POS GOLD CRIMP
W3280-12PG-535 数据手册
GROMMET SIZE TO FIT CABLE O.D. 0.18 - 0.20 [4.6-5.1mm] 0.21 - 0.23 [5.3-5.8mm] 0.24 - 0.27 [6.1-6.8mm] 0.28 - 0.29 [7.1-7.4mm] 0.30 - 0.32 [7.6-8.1mm] 0.35 - 0.40 [8.9-10.2mm] KIT PART NO. W3280-1XPG-518(W) W3280-1XPG-521(W) W3280-1XPG-524(W) W3280-1XPG-528(W) W3280-1XPG-530(W) W3280-1XPG-535(W) NOTES: 1. PARTS TO BE BULK PACKED. 2. ALL DIMENSIONS ARE REFERENCE ONLY. DIMENSIONS IN BRACKETS [ ] ARE METRIC. 1.67 [44.8mm] KIT P/N DIA. "D" 0.77 0.77 0.77 0.77 0.77 0.83 W3280-10PG-5XX W3280-11PG-5XX W3280-12PG-5XX W3280-10PG-5XXW W3280-11PG-5XXW W3280-12PG-5XXW [19.6mm] [19.6mm] [19.6mm] [19.6mm] [19.6mm] [21.1mm] (10) (11) (12) (10) (11) (12) - #20 #20 #20 #20 #20 #20 ADD W SUFFIX FOR WINGED COUPLING RING OPTION (WING COUPLING RING OPTION) 1.67 [44.8mm] NO. OF CONTACTS W3280-1XPG-5XX(W) NO. OF CONTACTS GROMMET SIZE SEE P/N LIST .87 [22.2mm] NO. OF CONTACTS 1.13 [28.7mm] CUSTOMER PRINT .045 REF. [1.1mm] ASSEMBLED VIEW SHOWN WITH STANDARD COUPLING RING 2 1 O-RING MAT'L: RUBBER, BLACK TOP KEYWAY CONTACT INSERTION VIEW ASSEMBLED VIEW SHOWN WITH WINGED COUPLING RING .93 [23.6mm] .47 [11.9mm] #4 HI/LO SCREW MAT'L: STAINLESS STEEL .203±.016 [5.2 0.4mm] .43 [10.9mm] BACKSHELL STRAP MAT'L: UV THERMOPLASTIC, BLACK .38 [9.6mm] 1.03 [26.2mm] 3 10 2 TOP KEYWAY 1 3 11 11 10 4 9 D 9 4 5 5 8 6 7 #20 PIN CONTACTS CRIMP, GOLD PLATED 12 FACE VIEW CABLE INSERT, MALE MAT'L: UV THERMOPLASTIC, BLACK PART NUMBER: W3280-1XPG-5XX(W) W3280-12PG-5XX(W) 2 1 TOP KEYWAY 3 1 11 FILLED 10 9 4 5 8 6 7 12 FILLED FACE VIEW TOP KEYWAY 2 W3280-10PG-5XX(W) 3 10 6 12 SLEEVE MAT'L: THERMOPLASTIC, BLACK COUPLING RING MAT'L: UV THERMOPLASTIC, BLACK 7 WIRE VIEW BACKSHELL MAT'L: UV THERMOPLASTIC, BLACK COUPLING RING, WINGED (OPTIONAL) MAT'L: UV THERMOPLASTIC, BLACK 11 9 GROMMET, MAT'L: RUBBER, BLACK FOR CABLE O.D. SEE TABLE 8 4 5 8 7 12 FILLED 6 CUSTOMER APPROVAL THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. FACE VIEW W3280-11PG-5XX(W) ASSEMBLED VIEW SHOWN WITH STANDARD COUPLING RING ASSEMBLED VIEW SHOWN WITH WINGED COUPLING RING APPROVED BY: DATE: A PAK REV. INIT. 08/15/19 DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX DRAWING CREATED & RELEASED PER DOR 10-2523JS-1 DESCRIPTION ORIG. DRAWN BY: DATE: 10/01/14 PAK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE SHEET NTS B 1 OF 1 FILE: W3280-1XPG-5XX DIRECTORY: SLW CABLE CONNECTOR KIT #20 PIN CONTACTS (CRIMP), BACKSHELL CLAMP MULTI-CON-X, E-KEY, WEATHER RESISTANT CUSTOMER: STANDARD PRODUCT PART NUMBER: W3280-1XPG-5XX(W) REV A
W3280-12PG-535 价格&库存
很抱歉,暂时无法提供与“W3280-12PG-535”相匹配的价格&库存,您可以联系我们找货
