AAA3MBYYLP
AAA3MBYYLP
    SWITCHCRAFT
    AAA3MBYYLP
AAA3MBYYLP 数据手册
HANDLE, BLACK AAA 3 M L P STRAIN RELIEF BLACK SERIES: Q-G CONNECTOR QT3MBZ CONNECTOR BLACK # OF CONTACT PINS: 3 1.40 35.6 GENDER: MALE 0.82 20.9 FINISH: BLANK - NICKEL CONNECTOR, & GREEN INSERT B - BLACK CONNECTOR, & BLACK INSERT AAA3MBLP SHOWN 0.28 7.1 CONTACT PIN PLATING: BLANK - SILVER AU - GOLD 0.75 18.9 HANDLE: BLANK - IF HANDLE & STRAIN RELIEF ARE BOTH BLACK B - BLACK, IF HANDLE & STRAIN RELIEF ARE DIFFERENT COLORS W - WHITE G - GREEN Y - YELLOW 0.71 FLAT 18.0 STRAIN RELIEF: BLANK - IF HANDLE & STRAIN RELIEF ARE BOTH BLACK B - BLACK, IF HANDLE & STRAIN RELIEF ARE DIFFERENT COLORS W - WHITE G - GREEN Y - YELLOW 0.215 CABLE HOLE 5.46 0.60 15.1 0.78 19.7 0.55 14.0 CUSTOMER DRAWING NOTES: 1. CONNECTOR, HANDLE AND STRAIN RELIEF ARE SHIPPED UNASSEMBLED ONE EACH PER BAG. UNLESS OTHERWISE SPECIFIED 2. MATERIALS: HANDLE PLASTIC - THERMOPLASTIC STRAIN RELIEF - THERMOPLASTIC HOUSING - ZINC ALLOY, NICKEL PLATED OR BLACK INSULATOR - THERMOPLASTIC, GREEN OR BLACK GROUND TERMINAL - SPECIAL COPPER ALLOY CONTACT PINS - COPPER ALLOY, SILVER PLATED OR GOLD PLATED 3. THESE PRODUCTS ARE RoHS COMPLIANT. THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A REV 28044 ECO NUMBER 07-06-18 DATE REVISIONS PC BY TJK APVD SIZE SolidWorks CAD File MULT FINISH DATE DRAWN 12-13-17 NAME B LBS/M TEMPER MATERIAL SPEC No. FIRST USED ON 3. REMOVE ALL BURRS DO NOT SCALE DRAWING WIDTH BY SPEC No. SCALE 1.5:1 CHKD SRC SRC 12-13-17 APVD SRC 12-13-17 MALE XLR, LOW PROFILE, RoHS RIGHT ANGLE SHEET PART No. 1 OF 2 AAA3M_LP_SERIES REV A SEE NOTE 2 SEE NOTE 1 SEE NOTES 3 & 4 SEE NOTES 5, 6, & 7 ASSEMBLY NOTES: 1. PARTS AS RECEIVED. 2. PUSH STRAIN RELIEF INTO HANDLE AS SHOWN. 3. FEED CABLE THROUGH HOLE IN STRAIN RELIEF. (3 CONDUCTOR 24 OR 26 GA. WITH OR WITHOUT SHIELD 0.145 TO 0.205 O.D.) 4. STRIP WIRES MINIMUM LENGTH AS NECESSARY (TWIST AND INSULATE SHIELD IF NECESSARY). 5. SOLDER WIRES TO CONTACT PINS AND GROUND TERMINAL. 6. PUSH HANDLE AND STRAIN RELIEF UP TO CONNECTOR THREAD, TAKE CARE TO ORIENTATE THE WIRE EXIT AREA TO YOUR LIKEABLE POSITION. 7. CAREFULLY SCREW THE HANDLE UNTIL TIGHT. CUSTOMER DRAWING SCALE 1.5:1 DATE DRAWN 5-24-18 DRAWN BY SRC SolidWorks CAD File SHEET PART No. 2 OF 2 AAA3M_LP_SERIES B REV A
AAA3MBYYLP
物料型号:AAA 3 M P 系列:Q-G CONNECTOR 引脚数量:3 性别:公 表面处理: - 空白 - 镍色连接器,绿色插入件 - B - 黑色连接器,黑色插入件
引脚镀层: - 空白 - 银色 - AU - 金
手柄: - 空白 - 如果手柄和应变释放都是黑色 - B - 黑色,如果手柄和应变释放颜色不同 - W - 白色 - G - 绿色 - Y - 黄色
应变释放: - 空白 - 如果手柄和应变释放都是黑色 - B - 黑色,如果手柄和应变释放颜色不同 - W - 白色 - G - 绿色 - Y - 黄色
尺寸: - 长度:1.40英寸 - 宽度:35.6毫米 - 高度:0.82英寸
型号:AAA3MBLP
功能详解: 1. 连接器、手柄和应变释放是分开发货的,每个包装一个。 2. 材料:手柄塑料 - 热塑性材料,应变释放 - 热塑性材料,外壳 - 镀镍锌合金或黑色绝缘体 - 绿色或黑色热塑性材料,接地端子 - 特殊铜合金,接触引脚 - 镀银或镀金铜合金。 3. 这些产品符合RoHS标准。
应用信息: - 组装说明: 1. 收到的零件。 2. 如图所示,将应变释放推入手柄。 3. 如图所示,将电缆穿过应变释放孔。 4. 剥去导线至最小长度(必要时扭曲并绝缘屏蔽)。 5. 将导线焊接到接触引脚和接地端子。 6. 将手柄和应变释放推到连接器螺纹上,注意将导线出口区域定位到您喜欢的位置。 7. 小心地拧紧手柄。
封装信息: - 该文档包括SolidWorks CAD文件。
AAA3MBYYLP 价格&库存
很抱歉,暂时无法提供与“AAA3MBYYLP”相匹配的价格&库存,您可以联系我们找货
