Panel thickness
8 max.
[0.31]
MAIN KEY
REFERENCE
22 0,3
[0.85-0.88]
AR
PPP1-0044A
PPP1-0045A
BR
PPP1-0046A
PPP1-0047A
6
VISUAL KEY
3
SIDE VIEW
PART LIST
ITEM
NO.
DESCRIPTION
MATERIAL
2
HEX NUT
PANEL SEAL
POLYAMIDE- PA6
SHELL RECEPTACLE
PEI_ULTEM
1
5
3
PPP1-0048A
15,3 0,2
[0.59-0.61]
1
2
VARIABLE KEYS
12,8 0,2
[0.50-0.51]
Jam nut - 22 on flats
Max. tightening torque 2.5 N.m
10%
POSITION
PPP1-0043A
14 0,2
[0.54-0.56]
7
14.25+0.3
[0.56-0.57]
B-B
8,5 0,2
[0.32-0.34]
M16
MASS
FRONT VIEW
SIDE VIEW
COUPE
A
B
REAR VIEW
+0.3
[ n 0.64- n 0.65]
C
D
E
F
G
H
8
E.15; Validé
Max. Panel thickness : 8mm
[0.31 inch]
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
FRONT MOUNT RECEPTACLE
WITH CRIMP CONTACTS
RECOMMENDED PANEL CUTOUT
6.8 g
AR
8
BR
A
45 $ 180 $
B
135 $225 $
C
45 $ 225 $
D
135 $315 $
E
180 $315 $
G
165 $195 $
G : Default key
7
6
WITH SOLDER CONTACTS
SILICONE
Extra compound
except crimp contacts
5
Color coding
4
ELECTRICAL:
INSULATION RESISTANCE :
MAX. CURRENT RATING :
CONNECTOR TESTING VOLTAGE :
CONNECTOR WORKING VOLTAGE :
PHYSICAL:
MAXIMUM WIRE SIZE USED :
ENVIRONMENTAL:
ENDURANCE:
SHOCK:
PROTECTION INDEX:
ROHS & REACH COMPLIANT
OPERATING TEMPERATURE:
>500M ^
PER ANSI-EIA-364-D
SEE INSULATOR DRAWING
Connector color coding
METHOD 21
REFERENCE
Color coding
2000 MATING CYCLES AS PER IEC
60512-5 test 9a
Dropping height 750 mm [29.53] per
IEC 60512 test 7b
PPP1-0036B
IP 68 AS PER IEC 60529 (1BAR
DURING 1 WEEK)
In mated condition
In unmated condition except crimp
contacts
PPP1-0037B
PPP1-0038B
-20°C +100°C (-4°F +212°F)
BIOCOMPATIBILITY: ALL SHELL PEI_ULTEM PARTS to USP Class VI / ISO 10993
PPP1-0039B
3
Connector coding
Basic type
PPP1-0040B
JMX
HH
1
X
XX
X
X
U
D
S
X
X
Stripping dimensions
C
Shell size
Contact style
Keying : POSITION G, A, B, C, D, E
2
Contact layout : SEE INSULATOR DRAWING
S (Solder)
Contact type : (M) Male, (F) Female
Layout
10, 12
Contact size
0.5
06, 07, 08 0.7
04, 05
02, 03
Contact style:
S (Solder), C (Crimp), P (Straight PCB contacts), Q (90° PCB contacs)
Material : (U) PEI_ULTEM
C (Crimp)
0.9
1.3
S : standard
1
04, 05
0.9
02, 03
1.3
P/N :
C
2 [0.079]
3 [0.118]
3 [0.118]
26/04/18
ISS
DATE
TITLE
>1.35 [0.053] 5.5 [0.217]
1.60 [0.063] 5.5 [0.217]
2/1
2.10 [0.083] 5.5 [0.217]
See color/keying table
G
E
Designed by:
3.5 [0.138]
很抱歉,暂时无法提供与“JMXHH1G05MCUDSP”相匹配的价格&库存,您可以联系我们找货
